11-12-2019, 03:57 PM | #1 |
Rep 406
Drives: BMW 328xi BMW X5 F15 BMW M2
xHP Flashtool
Has anyone done this?
X5 xDrive35i SAV Stage 1 - Gear Display in all modes - Torque Limiters removed X5 xDrive35i SAV Stage 2 - Gear Display in all Modes - Torque Limiters removed - Reworked Shiftmaps - Altered Shift-Strategy. Choose from 3 different Shift-Speeds with the DEC Switch. Also fully compatible to cars without DEC - True Manual in M/Sport and M/Sport+. (no automatic upshift at RPM limiter) - DSC OFF and DTC now use Sport+ shift program - Adjusted line pressures above 400 ftlb for tuned cars X5 xDrive35i SAV Stage 3 - Gear Display in all Modes - Torque Limiters removed - Reworked Shiftmaps - Altered Shift-Strategy. Choose from 3 different Shift-Speeds with the DEC Switch. Also fully compatible to cars without DEC - True Manual in M/Sport and M/Sport+. (no automatic upshift at RPM limiter) - DSC OFF and DTC now use Sport+ shift program - Adjusted line pressures above 400 ftlb for tuned cars - More aggressive Launch Control. Approx. 0.2 to 0.5 seconds quicker from 0-62 mph - More aggressive Throttle Blips in Sport and Sport+ (in S and M Modes) - Faster/harder upshifts in Sport+ mode
11-13-2019, 10:48 AM | #3 |
Rep 406
I have scheduled to get the stage 3 flashed this weekend by a dealer. Its $50 cheaper if you get a dealer to flash it. Ill share my thoughts.
11-14-2019, 07:06 AM | #4 |
Rep 460
Is this available for the f15 35d yet? They said it would be done by the end of summer.
I used it on my 11 335d and it was a great mod. Very easy DIY flash. |
07-05-2020, 11:29 AM | #5 |
Rep 4
Jey guys how are you?
I am intersted too. But can anyone tell me which obd tool to use with the xhp .i tried to buy the thore obd2 but it mentioned that this is for f30 m3 etc. Not for f16/f15. Any clue. Thanks |
07-05-2020, 11:45 AM | #6 |
Rep 439
Drives: 07 E92 335 / 17 F16 X6 35i
I bought the MHD WIFI ENET from burgertuning and it works with E-sys / MHD / xHP for our cars.
@mikecentola
07 335i SG / CR - LOTS OF MODS - BUILD THREAD 17 X6 SG / LCSW - ZMM/ZCW/ZDA/ZDB/ZLP/ZPP/MPPK - H&R VTR / Vossen 22x10.5/22x12 18 Ford Raptor |
07-05-2020, 03:44 PM | #7 |
Rep 546
Drives: 2018 M5 / 2011 X5 35d
The Thor WiFi obd from bimmergeeks also works with xhp.. at least it does on the E series
10-17-2020, 01:49 AM | #8 |
Rep 156
10-17-2020, 07:39 AM | #9 |
Rep 546
You need a direct connection to the car with your cellphone thru either Bluetooth or wifi using an OBD adapter.
10-17-2020, 09:54 AM | #10 |
Rep 156
So I have BM3 tune, I tune it with obd ethernet jack to iPhone adapter. Will that work the same for xhp app on IOS? it works on BM3 IOS. I'm assuming if it will work the same way?
10-17-2020, 12:14 PM | #11 |
Rep 546
You can try but I know the xHP software is picky about the adapter you use to connect to the car. Go ahead and connect it with the adapter you have and see if xHP detects and connects to your car, if it does then you should be fine, otherwise you will need to get one of the adapters they recommend using for the upgrade.
10-22-2020, 08:50 PM | #12 |
Rep 43
Drives: 2017 X5 35i
I flashed xHP using my iPhone with ENET cable and iPhone network adaptor, worked fine.
05-26-2022, 09:16 AM | #15 |
Rep 804
Drives: BMW X5 XDrive35i
Been running XHP for over a year, no issues whatsoever. Makes driving much more pleasant.
05-26-2022, 01:14 PM | #16 |
873
Rep 345
Been running stage 3 for a while now. Love it! Def. Worth the money
sukhk5272163.50 M302_imola842.50 |
06-12-2022, 11:24 PM | #18 |
Rep 182
06-13-2022, 08:57 AM | #19 |
873
Rep 345
With faster shifts it's less wear.
Think of a manual car, if you slowly let out on the clutch it wears your clutch plate out faster. Same with automatics, fast and firm shifts wear less due to less slipping before fully engauged |
06-13-2022, 12:52 PM | #21 |
Rep 178
This may be a stupid question but I'll ask anyway.
To do the trans tune with Xhp, does the dme have to be unlocked?? |
06-13-2022, 08:31 PM | #22 |
873
Rep 345
It can CatalinP, if your full throttle shifting all the time. But for everyday driving is crisper but not jarring or even close. Just a more positive shift.
Only time I can feel it being "jarring or a shock to the transmission" is in manual shifting and high rpm I run stage 3 tune, love the higher line pressure and confidence in holding power. Pairs great with MHD stage 2 plus tune. |
