05-17-2019, 10:37 AM | #1 |
Rep 234
How to drain transfer case?
I am trying to replace the transfer case fluid in my X5. I see on realoem and newTIS there is a fill plug. I took it off and tried to put my transfer pump in to pump out the fluid, but cannot seem to get it into the fluid. Is there a drain plug I am not seeing? How has anyone who has performed this maintenance drained it?
05-17-2019, 11:11 AM | #3 |
1636
Rep 2,995
Ok. Looked up a pic of the transfer case and maybe there is no drain. Do you have a fluid extractor?
I use this for taking fluids out of differentials and t cases. Mityvac MVA6851 Automotive Accessories https://www.amazon.com/dp/B00MPQ8RBG..._kZT3Cb0QFHEZG |
happydude136.50 |
05-17-2019, 12:47 PM | #6 |
Rep 234
Thanks. It worked with getting a smaller tube in there. Just wanted to make sure there wasn’t an easier way I was overlooking. I guess it was also a little tighter since I didn’t remove the cross member.
05-17-2019, 04:01 PM | #7 |
Rep 1,061
Transmission Oil change is a PIA. You need to fill while the engine is running and use ISTA to do the final fill (and keep trans below a certain temp) so be careful to make sure you get a complete fill.
05-17-2019, 05:16 PM | #8 |
1636
Rep 2,995
05-17-2019, 06:06 PM | #10 | |
Rep 536
05-17-2019, 06:27 PM | #11 | |
Rep 234
https://www.realoem.com/bmw/enUS/sho...diagId=27_0068 |
05-17-2019, 08:28 PM | #12 |
Rep 1,061
Trans final fill needs to be at a specific temperature (which is fairly low) and ista makes it easy to verify this temp to ensure correct oil level.
05-17-2019, 10:34 PM | #13 |
1636
Rep 2,995
Meh. I doubt that matters. Just start the car and go thru the gears. Fill it and put plug in before fluid gets hot.
05-17-2019, 10:37 PM | #14 |
480
Rep 317
Only one fill/drain plug, you'll need to use a clean tube to extract the old fluid, and fill with BMW Power Divider oil TF 0870 part# 83220397244, no need for ISTA or perform readaptation on the transfer case after fluid change unlike the previous generation X5 E70's where you have to. You'll also need to replace the fill plug.
M302_imola842.50 |
05-18-2019, 03:40 AM | #15 | |
Rep 1,260
The one with critical temperature is the gearbox / transmission. Last edited by CatalinP; 05-24-2019 at 12:18 AM.. |
markslc1183.00 |
06-03-2019, 02:30 PM | #16 |
Rep 536
I just finished up my transfer case fluid change. I'm happy to report that the procedure does NOT require you to remove the support crossmember. Though the fitment is tight, you can remove the plug, drain and fill by running your hand over the top of the crossmember rear-to-front to access the plug. Using a suction device, and a piece of rigid brake line (bent at 300 degrees), I was able to get deep down into the xfer case to get the fluid. It really starts making sense once all the splash shields are off. Overall not a bad job if you have the right tools.
04-18-2021, 10:05 AM | #17 | |
Rep 3
I checked 83222409710KT and get the same info. So far, I haven't found anything definitive stating what the correct fluid is for my transfer case.
Tim in Indy
2014 X5 xDrive35i Sport and Cold Weather Package |
04-18-2021, 11:08 AM | #18 | |
1636
Rep 2,995
07-06-2021, 11:05 AM | #20 | |
147
Rep 334
You are good with one bottle. Small 8" piece of brake line that fits the ID of whatever suction gun you are using goes a long way to get the fluid out. Bend it like a candy cane with the long part being what goes into the TC. Last edited by scotty339; 07-06-2021 at 11:24 AM.. |
dn325ci20.50 |
07-06-2021, 12:56 PM | #21 |
Rep 147
Thank you for the help, Scotty. Will a small flexible hose be good enough for the TC vacuum, or does it need to be rigid?
07-06-2021, 01:44 PM | #22 | |
147
Rep 334
I used a 200cc suction gun, so I had to make about 4 trips to suck out and empty. You'll have to come straight up and then manage to get it to come back down towards you. With the plastic tube not having memory, this can be tough. I had my brake line bent like a candy cane, fished it up and into place. Had my 200cc suction pump and catch pan underneath. I'd conect the pump to the brake line, suck out what I could. Leave the brake line in the TC. Detach the suction pump plastic line from the brake line, one hand to cover the end of the brake line so fluid does not drain on your floor, or have a drain pan, then dump your gun, hook it back up and rinse and repeat. Just be careful poking around inside with the metal brake line. Ensure the ends are clean with no burs or shavings ect. Good luck. Let me know how it goes if you try without the plastic. |
dn325ci20.50 |
