      04-14-2021, 01:06 AM   #1
DaRealist 2
Drives: 2016 BMW X6
22 inch tire help
Just bought a set of 22 inch rims for my 2016 f16 22x10 front 22x11 back offsets are +40 for the front +35 for the rear and I’m trying to come up with a tire combination that is as close to stock as possible. I don’t want to add spacers or anything and I don’t want to affect the xdrive any help would be greatly appreciated.
      04-14-2021, 06:43 AM   #2
1norseman
Drives: X5 50i
https://tiresize.com/calculator/
      04-14-2021, 07:36 AM   #3
M302_imola
M302_imola's Avatar
843
Drives: '15 X5 35i Xdrive Mineral Whit
If you're after a flush look more than likely you're going to need to add spacers. With the sensitivity of the transfer case you have stay within 1% overall circumference of OEM wheels/tires. 295/30/R22 front 335/25/R22 rear. I don't think spacers will void your warranty and even if so simply yank them off before you take into the stealership for work.
      04-14-2021, 08:54 AM   #4
DaRealist 2
Drives: 2016 BMW X6
ThatÂ’s the set up that I was looking to do but really trying to avoid the spacers. What set up will keep me within the 1%?
      04-14-2021, 09:01 AM   #5
DaRealist 2
Drives: 2016 BMW X6
Or what size spacers should I be looking to get to avoid any issues?
      04-14-2021, 09:48 AM   #6
CatalinP
Drives: BMW X5 F15 2014 3.0xd
In terms of warranty, running 22" wheels is not allowed, so spacers will not make any difference.
      04-14-2021, 04:27 PM   #7
M302_imola
M302_imola's Avatar
843
The mentioned setup is right around 1% and the most common 22" tire sizes used on this forum so rest assured it should work just fine w/ your transfer case.
Depends! Are you m-sport, x-line, or luxury? I'm assuming all 3 trims come in the X6 as in X5.
      04-15-2021, 04:16 PM   #8
DaRealist 2
Drives: 2016 BMW X6
Im a m sport
      04-16-2021, 07:04 AM   #9
M302_imola
M302_imola's Avatar
843
Im a m sport
Which means you have the flared wheel arches so more than likely you're going to need spacers for that flush look. Now if you're ok w/ them being sucken in a bit then no spacers required. I believe what you listed are the same offsets as my 22's and I went w/ H&R 15mm front and 20mm rear spacers and it's perfectly flush.
      04-16-2021, 07:34 AM   #10
sergiyny
Drives: BMW X5 M Sport
I have this setup on my rims and as far as I know i'm above that 1%, actually at 1.4%. I'm actually trying to get rid of this setup.
      04-16-2021, 08:30 AM   #11
DaRealist 2
Drives: 2016 BMW X6
How is it that you come of with percentages ? And what issues are you having with this set up? I’ve ordered my tires already with this set up trying to prepare for any issues. Researching spacers now which I tried to avoid
      04-16-2021, 08:33 AM   #12
CatalinP
You can calculate all this you know...
      04-16-2021, 08:49 AM   #13
sergiyny
For the winter I had my 20 inch rims on, now I switched to 22s and started getting the ticking noise during the acceleration. I'm not sure if it's because of 22s but i will be putting back on my 20s to see if the problem goes away.
      04-16-2021, 09:22 AM   #14
sergiyny
as an option i'm thinking of just switching the front tire from 295/30/22 to 285/30/22, that way i'll be getting 0.5% difference which is within the 1% margin.
      04-16-2021, 09:30 AM   #15
DaRealist 2
Drives: 2016 BMW X6
Thanks for the chart finally hit the correct tab new to this rim thing i usually just keep mines stock lol. Will the .4 cause issues not so much warranty I know to they won’t cover that but anything else that’ll cause a headache?
      04-16-2021, 09:40 AM   #16
DaRealist 2
Drives: 2016 BMW X6
Already ordered the tires don’t even want to think about the headache of sending them back
      04-16-2021, 10:03 AM   #17
M302_imola
M302_imola's Avatar
843
You shouldn't have an issue. Very few do.
      04-16-2021, 10:40 AM   #18
DaRealist 2
Drives: 2016 BMW X6
At this point I’m just gonna run add the spacers and hopefully it’ll be fine
      04-16-2021, 11:11 AM   #19
M302_imola
M302_imola's Avatar
843
It will turnout great, just like mine did, but beware you'll prob not like the wheel/fender gap so be prepared to buy springs or coilovers in the near future. I've had my wheel/tire combo 1.5 yrs and just now getting around to coilovers. Can't wait to get them installed.
