      08-13-2019, 05:48 PM   #661
Fast400
Fast400's Avatar
Germany
686
Drives: iX M60
2014 BMW  [0.00]
Originally Posted by ziptwang View Post
So I have the clicking on my '18 F85 now as well - started at around 11K Miles.
I have an appointment this Friday. It will be interesting to see if the fix is handled the same way here in Germany.
Was it the same fix?
      08-14-2019, 12:30 AM   #662
Mitch P.
Drives: '17x5M
So I've been watching this closely as I just purchased a '17X5m local here in Seattle. I have noticed the ticking noise and have repeatedly noticed that the noise is not present in the mornings after sitting overnight. Once I drive for a bit and either heat the bearings or brakes up the sound returns. Just another data point for what it is worth...cheers.
Mitchell Phillipi, CCA#189329
'01540ias, '17x5M
past:'96Dinan3, '11M3 ZCP, '11X5d, '15X5 5.0, '07AMdB9
      08-29-2019, 07:37 PM   #663
gqgambler
gqgambler's Avatar
Drives: Fast & Furious
Anyone know the cost for this repair out of warranty?
No. Try not. Do. Or do not. There is no try.
-Yoda
      08-29-2019, 07:50 PM   #664
StatenEye
Drives: X5M F85
2016 BMW X5M  [0.00]
2011 BMW X5M  [9.00]
Take the wheel off, remove the hub pins, put the wheel back on and torque the wheels down. Worked for me.
      09-01-2019, 10:22 PM   #665
DgjoX6M2016
F86, G05, E91
DgjoX6M2016's Avatar
Drives: F86 X6M
I was just quoted $890 for left front hub replacement. They said it was damaged from a pothole or something as the inner wheel was a bit out of round.
      09-27-2019, 10:29 AM   #666
enzom
Drives: 18 X5M/20 720S/20 992 C4S
Dealer just performed the hub repair and the clicking is gone. Also replaced the rotors, and the brake squeal is gone.
18 BMW X5M
20 Mclaren 720S Spider
19 X7
20 992 C4S
15 458 Speciale
      10-04-2019, 01:44 AM   #667
gizmo958
gizmo958's Avatar
United Kingdom
51
Drives: Evo IX, 17 X5M
My dealer just added spacers last week and my issue has gone totally for now. It use to click bad on full lock to the left. So far so good
Faith
      10-08-2019, 06:57 PM   #668
carks
carks's Avatar
Drives: 2017 BMW X5 M
so my X5M was fine until approx 15-16K miles
noted clicking sound when turning to the right.
Dealer fixed it without issue-no more clicking. They have the service bulletin, it's a known "issue" (likely benign, just annoying and mildly embarrassing)
      10-04-2021, 12:30 PM   #669
fertigulator
Drives: BMW X5 (2016)
I’ve followed this thread for over a year now. Anyone ever have permanent success? I have an 16’ x5 (f15) with the clicking. It doesn’t do it turning the wheel, only straight runs at low rpm’s (2000-4000).
I had my turbos replaced (the service center thought it was the waste gates but it did not solve the problem.
I suspect it’s something In the exhaust flow but it sounds external, almost like a baseball card in the spokes.
