      12-24-2020, 06:59 PM   #837
classic_erik
classic_erik's Avatar
Drives: 23' X7 40i M Sport
Originally Posted by scotty339 View Post
Originally Posted by classic_erik View Post
So any concerns with putting new pads on used rotors? Still a lot of life in the rotors measuring at 11mm. I figure it will take a couple hundred miles to break them in with a new sweep pattern but should be fine.
Not sure what the min depth for service life on the rotor is, but Id look and see what it would cost to get them cut / machined down. May be worth it depending on how they look now / best life with thew new pads.
Great call.
Does anyone have any details on the stock F85 rear rotor?
      12-24-2020, 08:41 PM   #838
scotty339
Drives: 2015 BMW X5 x35i M-Sport
Great call.
Quick google shows its a 385x24. Diameter in MM. When you said you have 11mm, I assume you mean one side as its an internally vented rotor. I'd peg your rotor then as measuring out to approx 22mm, or 2mm down from new spec.
I'd double check your measurements, but from what it sounds like you should be fine if you chose to cut it if it makes sense cost wise.
      01-01-2021, 11:21 AM   #839
classic_erik
Boom!
Appreciate 4
1norseman398.00
1230vani652.50
TheWknd10.50
      02-09-2021, 10:06 PM   #840
djrabbi
djrabbi's Avatar
Drives: G05 M50i
Are all you guys with the porsche rear calipers getting them from tronik?
      02-10-2021, 05:18 AM   #841
blue dragon
Yes.
      02-10-2021, 10:34 AM   #842
djrabbi
djrabbi's Avatar
Drives: G05 M50i
Yes.
Damn. His prices for rears is crazy. I could probably sell same set up for just price of his rears. No idea how much he shaves off though
      02-10-2021, 10:41 AM   #843
blue dragon
My buddy just ordered a set, we can measure when they come in before they get mounted
      02-10-2021, 10:46 AM   #844
djrabbi
djrabbi's Avatar
Drives: G05 M50i
That would be sweet. I will pay him just to know how much was milled off.
Not trying to draw business away from Tronik but $1600 for rear calipers and adapters is just stupid.
      02-10-2021, 02:17 PM   #845
fr_tz
fr_tz's Avatar
Drives: F90/G05 50e
2024 G05 50e  [9.50]
As I understood it that is the price for new calipers. You can get them cheaper from him if you went the used and unfinished route.
      02-10-2021, 02:51 PM   #846
blue dragon
Thats what I did https://f15.bimmerpost.com/forums/sh...&postcount=810
      02-10-2021, 10:11 PM   #847
djrabbi
djrabbi's Avatar
Drives: G05 M50i
Ohhhh maybe I'll ask that instead
      02-12-2021, 12:46 AM   #848
scrubs89
Drives: audi r8 v10 spyder
Hi all, searched but didnt find the answer:
I have a 2017 X5 xDrive35i, I just bought lightly used 2010 X6M calipers and rotors to put on my car. Couple questions:
1) What brake sensor do I need? The one that's compatible with E71 or F15? Seems they're different.
2) Apart from new piston seals and pads, what other materials do I need to make this all work? I know there's coding involved which I can handle. Just want to drop it off at a shop and have them have everything they need.
Thanks all! Love this forum, such great info available.
      02-12-2021, 06:46 AM   #849
sammyapache
Puerto Rico
21
Drives: 2017 BMW X5
I have the same vehicle and also installed E70m brake calipers. I went with this sensor from the E70 from rockauto and these pads. They stay relatively clean and no squeal
      02-12-2021, 09:20 AM   #850
scrubs89
Thanks I anticipated needing pads compatible with X6M (e71) calipers but wasn’t sure about the pad sensor. Hopefully whatever I bought includes everything necessary to get things mounted properly. Everyone says they’re reverse-compatible so it’s plug-and-play but just my luck I’ll be missing some critical piece that I should have ordered in advance. Thanks again.
      02-13-2021, 03:39 AM   #851
1230vani
1230vani's Avatar
653
Drives: G05 40i LCI
Boom!
More pics of the exhaust pretty please
      02-13-2021, 06:55 AM   #852
classic_erik
Boom!
Here you go. Including a shot of the tips pre-powdercoat.
Appreciate 5
      02-13-2021, 09:40 AM   #853
NYBulldog
Specialist
1310
Drives: Nikes
That's a pretty ride.
      02-13-2021, 09:42 AM   #854
classic_erik
Thanks brother
      02-16-2021, 12:49 AM   #855
1230vani
1230vani's Avatar
653
Drives: G05 40i LCI
Boom!
Looks great! Thanks
      02-17-2021, 08:20 AM   #856
scrubs89
Another question I searched and havent found an answer to-
Bought some E71 calipers from a 2012 X6M- planning on replacing all the seals and maybe getting them powdercoated another color. Where can I buy new seals and caliper rebuild stuff for this caliper? Found several caliper rebuild kits with seals but they appear to be more generic for BMW and it's not clear if they'll fit or not. Link or part numbers would be helpful!
Thanks
EDIT:
These are the part numbers I've found? Can't really confirm anywhere else or find records of part numbers people have used successfully.
EDIT again: ordered. we'll see how it goes
front: 143.34032
rear: 143.34021
      03-27-2021, 05:15 PM   #857
NeRkO20
BMWfreak
Austria
Drives: F15 30d
Is it possible to use the X5M F85 Brake on a ordinary F15? I want the caliper with 6 pots. Did someone try this?
      03-27-2021, 05:17 PM   #858
blue dragon
Jesus, why don't you read the thread you just posted in
