      03-22-2022, 10:32 AM   #1
blackoutF15
351
Drives: BMW X5 x35i
TPM issue, help please
Hi, I got a TPM warning this morning. So I tried to reset the sensors. Tired 3 times and it got stuck at 49% completion all 3 times. All tires seem to be inflated and fine. Is there anything I can do besides taking it to dealer? I have aftermarket 22" wheels if that matters. Never had an issue before. Thanks
      03-22-2022, 11:49 AM   #2
1norseman
Drives: X5 50i
Just to eliminate one possible issue, but you might already know this...
How far did you drive? It takes my car 10-15 minutes of uninterrupted driving, before they complete the reset. If stop and go traffic, even longer.
Violator4587.50
      03-22-2022, 11:50 AM   #3
RED_Y_
Drives: 2014 X5 3.5d
And you drove around after reset, right?
Violator4587.50
      03-22-2022, 01:54 PM   #4
blackoutF15
351
Drives: BMW X5 x35i
I drove for awhile. Non stop in a section of the street where there's no traffic light making U turns. The % goes up until it hits 49% every time then it stops. After awhile the error message comes back. It's annoying.
      03-22-2022, 01:55 PM   #5
blackoutF15
351
Drives: BMW X5 x35i
Yes I did
      03-22-2022, 02:07 PM   #6
RED_Y_
How old are your sensors?
      03-22-2022, 02:29 PM   #7
blackoutF15
351
Drives: BMW X5 x35i
About A year. I got new ones when I got the aftermarket wheels
      03-22-2022, 02:30 PM   #8
blackoutF15
351
Drives: BMW X5 x35i
I'm starting to think maybe the sensors gone bad
      03-22-2022, 02:44 PM   #9
MH20jy
Drives: 18 X5 35i
Did you have readings from all 4 sensors?
2018 X5 35i
      03-22-2022, 02:57 PM   #10
blackoutF15
351
Drives: BMW X5 x35i
Yes. Before this morning I had readings on all 4. The warning says it's not able to detect. What are chances that all 4 failed the same time?
      03-22-2022, 04:07 PM   #11
MH20jy
Drives: 18 X5 35i
When reset TPMS, you need to keep driving without stop. Just start it and then drive on a highway for several minutes. It should go away. If not try ISTA to reset it.
2018 X5 35i
      03-22-2022, 04:12 PM   #12
blackoutF15
351
Drives: BMW X5 x35i
I tried many times, it gets stuck at 49% then warning is back on. What's ISTA reset?
      11-07-2022, 01:41 PM   #13
steve1221
Drives: BMW X5
I'm getting this issue on my 2014 40d. Select reset whilst stationary and drive away, the reset %age counts up but fails. Sometimes this is after 20%, sometimes 29%.
Any hints where to start looking? Tyres are all correct pressure
      11-07-2022, 03:23 PM   #14
RED_Y_
Might be time for new TPMS sensors.
      11-07-2022, 04:35 PM   #15
steve1221
Drives: BMW X5
Thanks, found this thread as well that helped. Probably need to find someone to test the batteries
https://f15.bimmerpost.com/forums/sh...TPM+reset+fail
