12-01-2022, 06:00 PM | #1 |
Rep 8
Rear Suspension Issue
I have an issue where the back of the truck sags somewhat randomly, but has been happening more frequently. Last week I had to drive ~100 miles with the issue happening and every single bump felt like I was in a honda civic on cut springs.
I can't really pinpoint when it happens but the rear bags go flat overnight, usually with cargo in the back (but I mean light, less than 50 pounds). Last 2 weeks it hasnt happened at all so my initial idea of a bag leak is making me think now. Are there any 'valves' or sensors on the active suspension that could be allowing air out for whatever reason? 2016 x5m, no codes on the dash. |
12-01-2022, 08:23 PM | #2 | |
OEM CSL Whore
1249
Rep 1,474
12-02-2022, 07:44 AM | #3 |
Rep 8
Currently at 45k. Leaky bags was my initial thought and probably the cheapest to try first. I am just confused by how intermittent and random it seems.
12-02-2022, 10:14 AM | #4 | |
Rep 1,233
Full Evaluation
12-02-2022, 06:33 PM | #6 |
Rep 58
Spray soapy water and it's very easy to see if there's a leak, then u can buy Arnott A-2642 Air Spring from amazon for about $300 for 2 and DIY replacement, or bring it to a shop for extra $300 for installation
12-17-2022, 12:15 AM | #10 |
Rep 111
I have had the same issue - intermittent sagging in the rear of the truck - for almost 2 years now. Haven't replaced the bags yet. It is so strange how intermittent it is, mine's almost always sags under colder conditions; far less sagging in warm climate. Sometimes it'd also always sag if the truck's in the garage (maybe dust issues?).
What I don't understand is this - if there's a leak how come the issue is so intermittent? Maybe there is a falty valve that lets the air out depending on the environment? |
12-17-2022, 05:10 AM | #11 | |
Rep 105
The leaks happen in the folds in the bags. Sometimes the hole will be sealed by the fold and it won't sag and other times it's open and air leaks out. When they test them at the dealership the car is off the ground and the bags fully extended so no folds to block the air from leaking.
2017 f85 X5M | Donington Grey | Aragon Brown
2009 e90 335i | Black Sapphire Metallic | Saddle Brown 2004 e46 330ci ZHP | Silver Gray | Black (RIP) |
yasavguy39.50 |
12-17-2022, 09:00 AM | #12 | |
Rep 1,233
$6K
yasavguy39.50 |
12-18-2022, 10:28 AM | #13 |
Rep 106
2016 X6M Rear Suspension
I bought a new to me X6M in Apr with 36k miles. I didn't drive it a lot but noticed the same thing - intermittent sagging. I had it towed to the dealer as i don't have one in my area and they diagnosed one faulty bag but because the compressor had been trying to keep up(hence the intermittency), it burned that out as well. Long and short $3,700 to replace all components as BMW recommends always changing the rear bags in pairs, so don't delay or it WILL get more expensive. If you are handy, you can pretty easily replace them yourself in 1-2hrs per side. Videos are out there.
A bit for more info for those interested. I towed mine to the dealer because i bought endurance aftermarket warranty to cover the history i didn't have on the car. It was maintained by a BMW dealer in FL. My insurance wasn't accepted by the dealer which is where i thought it had to go so i had it towed back to my regular shop where they work on everything European. Endurance kicked in $1,200 because they would only pay for one bag and partial on the compressor. Still better than a kick in the rear. I am having both bags replaced per BMW recommendation because I don't want to see the same issue again which I probably would with the other bag. I haven't got the car back yet because whoever put the wheels on massively over torqued them to the point where it broke two wheel lock tools and my shop is now having to drill the left rear off If it wasn't a shop i trusted, I would be wondering but idiots somewhere who thought tighter was better. Don't hang about - it won't fix itself. At the very least get it diagnosed and good luck Last edited by crunchingnumbers; 12-18-2022 at 10:32 AM.. Reason: spelling |
12-18-2022, 05:36 PM | #14 | |
Rep 1,233
Wheel Torque
12-18-2022, 10:40 PM | #15 |
Rep 111
If the compressor goes bad - that means that the rear suspension won't raise at all?
In any case, after reading the above posts I decided to replace those bags. Arnott A-2642 Air Spring - two of these, correct? |
12-19-2022, 02:38 PM | #16 | |
Rep 106
My cost was $317 ea. but when i get the manufacturer I'll let you know. |
yasavguy39.50 |
12-19-2022, 07:30 PM | #17 | |
Rep 106
Wheels were torqued to correct values as well, they took the front off for me post bag repair on the rear to make sure i wouldn't be stuck anywhere with seized wheel lugs should i get a flat. Whoever put those wheels on must have been an over zealous numb-nut with a super charged air compressor who worked on mining excavators in his day job. |
yasavguy39.50 |
