      10-04-2014, 08:47 PM   #1
paicapo
paicapo's Avatar
265
0-100/0-60 BMW X5 F15 RaceChip
Tested it whit Torque app witch is spot on when measuring speed/time, had RaceChip on the E2 setting, the time is pretty good, 6,2 sec is better than the 40d, also tried 80-120kph and 4,4 sec is pretty good for the car, my old M3 E46 did it in 3,4 sec a couple of years ago. RaceChip truly delivers for the money. The car is a 30d.
[u2b]
[/u2b]
[u2b]
[/u2b]
      12-31-2014, 12:21 PM   #2
greentrbo95gst
greentrbo95gst's Avatar
1244
Drives: 21 M5 Comp
Where did you get this app? How does it work?
      12-31-2014, 12:59 PM   #3
paicapo
paicapo's Avatar
265
you will find the app here
https://play.google.com/store/apps/d...g.prowl.torque
and then you will need a OBD connector whit bluetooth like this one:
http://www.scantool.net/obdlink-mx.html
basically it’s a scan tool that works via the OBDII port of the car reading all kinds of stuff like sensors etc., whit the app it has some more features like timing 0-60 times etc., it’s also very accurate, lots of test of this online.
To do video you just download a plugin to the app and den mount the telephone and go.
      12-31-2014, 01:42 PM   #4
LatinBimmer
Peru
135
Maybe a similar app for iPhone with BMW apps:
BMW M Laptimer by BMW
https://appsto.re/us/oIQYO.i
      12-31-2014, 01:52 PM   #5
greentrbo95gst
1244
Drives: 21 M5 Comp
Sweet. Thanks
      12-31-2014, 02:17 PM   #6
paicapo
paicapo's Avatar
265
will try this one, looks like you can get all the info on the idrive display in realtime. thanks
      12-31-2014, 02:44 PM   #7
c3uo
Drives: 3 Series
That's awesome! Have you made similar measurements with no chip for comparison?
      12-31-2014, 03:32 PM   #8
paicapo
paicapo's Avatar
265
no i havent but thats a good idea, will try it shortly!!
      01-03-2015, 12:11 PM   #9
Bimar
Bimar's Avatar
802
Drives: Bmw X
Would be interesting to see un chipped for bmw do under rate their engines
      01-03-2015, 05:06 PM   #10
paicapo
paicapo's Avatar
265
Yes that is a common notion or rumor but i doubt they do it, here in EU we have strict regulations and certifications on emissions etc. for new cars and there’s no case that I now about where a car manufacture has deliberately defrauded the EU authorities by passing false engine specs.
      01-03-2015, 08:10 PM   #11
opasha
opasha's Avatar
1329
Drives: 2014 BMW X5 50i
In a perfect world, yes, no one can get away with anything. However, government pockets are deep. BMW does underrate their engines. I forget the article I read a while back, but it's true. Here's a recent article that proves it: http://www.motorauthority.com/news/1...akes?fbfanpage. That's also the reason why they can be modified so heavily.
      01-04-2015, 03:03 PM   #12
paicapo
paicapo's Avatar
265
No I don’t think so; you can’t compare expected wheel dyno output to BMW benchmarked engine dyno. Turbo engines are very volatile to external factors. Heat soak, fuel grade, air flow to the engine. They are more likely to have larger swings on a dyno and its known in insideinfo from manufactures that they are producing an engine dyno rating that can be consistently achieved using lower quality fuel, some heat soak, and non-ideal air flow or air density etc. In short if you use the exact standard method BMW is using to grade there engines you will end up whit the same results.
      01-04-2015, 03:14 PM   #13
paicapo
paicapo's Avatar
265
And in regards of claimed 0-60/0-100 bmw is known to have spot on claimable numbers so the "underrated" theory isn’t an issue or factor measuring 0-60 etc.
      01-04-2015, 03:28 PM   #14
opasha
opasha's Avatar
1329
You are right to an extent. A lot goes into the dyno tests, but a lot is also "lost" during these tests, which is why they can get away with their numbers without so much as raising an eye brow. I did further reading as well based on your info.
      01-04-2015, 04:41 PM   #15
paicapo
paicapo's Avatar
265
yes but to prove the claim of wrong horsepower specs from manufacture the dyno/setup/technical environment must meet BMW benchmarked method by 100% and show different numbers not inside the margin of error, don’t forget the manufacture set there one standards how to measure engine specs and that is the correct one, and the only method to use if the measurements are supposed to be credible in regards of doubting the official engine specs. I haven’t seen this, so I’m not very convinced, seems to me it’s more of a PR gimmick to promote the car/tune shop etc. fired up by enthusiasts
      01-04-2015, 04:46 PM   #16
opasha
opasha's Avatar
1329
I can't argue with you on that. I also have no reason to, lol. I hope you did not take any offense to my statements. If anything, I love to be corrected and learn more. Despite what is claimed or not, we are lucky to have such powerful/modifiable engines in the first place. Audi owners with stock engines get screwed in this department unless they have an S or RS model .
      01-04-2015, 05:27 PM   #17
paicapo
paicapo's Avatar
265
you are a kind soul opasha no offense taken whats so ever buddy
      01-05-2015, 03:07 AM   #18
Bimar
Bimar's Avatar
802
Drives: Bmw X
Get your points, but if you have time we could mythbust this with your app and see really how much RC is giving you and how much BMW is giving for free extra in the first place using this non scientific approach.
      01-05-2015, 06:25 AM   #19
JensM
Germany
68
Drives: BMW X4 M40D 2019
I do not have any firm numbers to prove the extra performance from RC, but here is a bit of picture I have experienced.
I'm running a 2012 MSport 30D (245HP and 8 speed auto box) with a RC box with default setting (from RC) which they claim add 20% => 295HP.
BMW claim 0-100KM/h (0-62 I believe) at 7.6 sec.
My buddy has an X6 40D (306HP - 8 speed) - BMW claim 0-100 at 6.6 sec.
In a race my 30D with RC is spot on as fast as the std X6 40D. Additionally the time for overtaking is reduced and I feel speeder response is better
But as said, no true measurements to back up
JensM
      01-05-2015, 06:28 AM   #20
paicapo
paicapo's Avatar
265
Il give it a try tonight whit a couple of runs whit and without RC and we will see what kind of numbers we get
      01-05-2015, 07:44 AM   #21
Bimar
Bimar's Avatar
802
Drives: Bmw X
Can't wait, thanks for giving it a shot!
      01-05-2015, 10:02 PM   #22
paicapo
paicapo's Avatar
265
gave it a shot got some exes wheigt out of the car witch I had last time, about 70-80 kg. I made to runs whit racechip and when i was upluging the connectors and stuff to try whitout it started snowing so id hade to abbort, its preety cold here but im gonna try to do a run if it dries upp but from to looks of things it could be a while, its to bad i realy wanted to be able to compare the engien whitout the tune, but the diesel whit raceship seems to love colder temps, hade about -9 celsius and the car hauld ass!
did 0-60 in 5,4 sec and 0-100 in 5,8 sec! thats impressive underated or not in my last run in october the outside temp was about +10 celsius
Piggyback rules!!
[u2b]
[/u2b]
Appreciate 4
