      07-28-2017, 10:55 AM   #243
nicros
Drives: 2017 X5 xDrive50i
Originally Posted by Almaretto View Post
B.C. is the button on the end of the turn signal stalk. You have to cycle through available choices to find digital speed. Personally, I find it useless on my car as I have HUD.
Awesome! Will give this a shot. The HUD is great, but the polarization on my sunglasses makes it useless during the day. Next pair or glasses wont be polarized.
      07-28-2017, 11:29 AM   #244
d_v_o_1
A little OT, but out of curiosity can the road speed limit be coded to the HUD (driver assist) even though you do not have drivers assist plus which displays the road speed limit?
No it can not via the app. I have found and used one guy for that exact purpose of adding the speed limit. The individual will need to be able to generate fsc in the BMW network - thus not many people do it. I think I paid about $200cdn for it and has worked well. It also doesn't get wiped with coding flash at the dealer either as it is a registered. If you want the contact just pm me. Hope that helps
      07-28-2017, 12:36 PM   #245
motex
2020 Mineral White 30d MSport
motex's Avatar
Costa Rica
524
Couple of questions;
1. Anyone knows how restrictive is the Bimmercode app for an 2016 F15 30d (diesel engine)?
2. Does the Bimmerlink app comes in english or just german?
      07-28-2017, 01:56 PM   #246
d_v_o_1
What exactly do you mean about restrictive? Unfortunately it is only in German at this time - and didn't seem to be something on the horizon either when I was in contact with the Developer.
      07-28-2017, 04:32 PM   #247
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
SLI requires an FSC code or emulator and coding, but can be done.
      07-29-2017, 11:28 AM   #248
motex
motex's Avatar
Costa Rica
524
I recall reading something about the engine management restrictions for diesel engines, other than that is the same no matter what engine you have.
      07-29-2017, 06:51 PM   #249
Almaretto
Almaretto's Avatar
2374
You should not really be coding the engine ECU. The rest will be the same for petrol and diesel vehicles.
      07-29-2017, 08:48 PM   #250
motex
motex's Avatar
Costa Rica
524
Thanks a lot will get the Vgate II this week
      08-04-2017, 07:43 PM   #251
motex
motex's Avatar
Costa Rica
524
Thumbs up
Originally Posted by Dirty Cash View Post
I only coded the following:
- Turn Signals in HUD (which also gave me seatbelt warning and door open warning, unless I just never noticed it)
- Switch on LEDs in door handles in reverse
- Mirror folding (locking) w/key fob
- Mirror folding (comfort access)
- M Startup Animation
Worked w/no probs thus far, with the exception of having to remember to update the time after each code attempt.
For some reason I can't code the HUD Turn Signals, I coded in both places and still not working, any tips?
      08-04-2017, 10:11 PM   #252
Kr0m3assass1n
kr0m3assass1n
Kr0m3assass1n's Avatar
Drives: 22 X7 M50i
What's the maximum number of clicks you're seeing in the list? 3? 5? 6?
      08-05-2017, 09:55 AM   #253
aleksaleks
Drives: F15 50i (2014)
can anyone help me to to code the air suspension on rear axle please?
(Bimmercode App)
thank you in advance
      08-05-2017, 10:27 AM   #254
motex
motex's Avatar
Costa Rica
524
I don't see a choice of clicks, just active and not active, do I have to go into expert mode?
      08-05-2017, 10:54 AM   #255
Kr0m3assass1n
kr0m3assass1n
Drives: 22 X7 M50i
What are you using for reading the ECU? I use BimmerCode and under the sub-menu, it allows me to select the number of clicks from between 1 to 6 in increments of 1.
My coding worked flawlessly but I know several people had issues. Read previous posts.
Good luck!
      08-05-2017, 11:52 AM   #256
motex
motex's Avatar
Costa Rica
524
Good luck!
It seems that my problem is that my car has the 6WB (digital cluster) and it doesn't work if you have that option. Do you have digital or analog cluster?
      08-05-2017, 11:52 AM   #257
ramsal
Drives: 2017 X5 & 2018 M3
greyed out modules
hey guys,
trying to code my 2017 35d using the app and i'm having some challenges:
1. HUD turn signal (1/2) & (2/2) = Active ....but not showing up in HUD
2. When trying to code the trunk lid close with key fob, the entire "Rear Functions Module HKFM2" comes up greyed out and I can't access any of the options within it (see photo)
Short of reverting to the E-Sys method of coding, I'm stumped.
I look forward to your thoughts.
FSociety3812.50
      08-05-2017, 12:02 PM   #258
Kr0m3assass1n
kr0m3assass1n
Drives: 22 X7 M50i
Good luck!
Analog.
Seems like everything analog just works better than digital these days
FSociety3812.50
      08-05-2017, 12:08 PM   #259
motex
motex's Avatar
Costa Rica
524
Originally Posted by ramsal View Post
hey guys,
1. HUD turn signal (1/2) & (2/2) does not work if you have digital cluster (6WB) installed in your car, check the cheat sheet row 25, it hapened to me too, I own a 2016 30d F15 with 6WB
      08-05-2017, 12:15 PM   #260
motex
motex's Avatar
Costa Rica
524
Ambient light doubts:
Hey guys, I need to understand more about how the ambient light feature works.
For example, I coded as a test the factory default orange color to hellrot (bright red) and it seems that it worked (no errors at least but I need to wait till night to see the real difference), my question is about what happens with the default orange and if I would have chosen "hellblue", what would have happen with the orange?
Hope I made myself clear enough with my poor english
      08-05-2017, 02:32 PM   #261
Almaretto
Almaretto's Avatar
2374
IDrive words never change. Only what the represent. You can replace all nine or some of the groups with desired color combinations.
      08-05-2017, 02:45 PM   #262
motex
motex's Avatar
Costa Rica
524
Thanks I knew the names will not chang but how do I change the default blue to hellblue?
When I did the orange, orange was the word that appear, so if change to hellblue I will still have the hellrot available?
      08-05-2017, 02:49 PM   #263
Almaretto
Almaretto's Avatar
2374
By changing dropdown menu. If you change orange to hellblue, then hellblue will now display not hellrot.
      08-05-2017, 03:34 PM   #264
motex
motex's Avatar
Costa Rica
524
Ok got it, so I just have to choose another color on the iDrive Dropdown menu and code it with the new color?
