11-25-2018, 11:26 PM | #1 |
Rep 92
Annoying speed vibration anyone?? F85
Ever since I drove thru a pothole I’ve had a vibration that won’t go away! Hoping anyone having the same issue. Even after New tires Michelin SS, Scorpio P Zero and pirelli snow. dealer can’t find the culprit. They said wheel bearing are fine! Starting at 40mph to anywhere to 90mph.you can hear a Sound when it’s goin to start.Any input will be cool! Thanks!
11-26-2018, 07:52 AM | #2 |
Rep 1,455
OP, I had a vibration at 70 mph and it was annoying as hell. I swapped out my summers for winters and vibration is gone. I need new summers when I swap them back. It sounds like the alignment is off after hitting pothole. I don't understand the shop not being able to find it. What the hell is that? Did they take it for a drive ? Bring it back to them and have them fix it. Alignment, balance all tires, check for a bent rim from pothole?
11-26-2018, 08:47 AM | #4 | |
Rep 1,066
Drives: 2015 X5 50i M Sport
2019 Cayenne Turbo
11-26-2018, 09:35 AM | #5 | |
Rep 92
11-26-2018, 03:50 PM | #6 |
F86, G05, E91
455
Rep 778
Has to be a wheel out of round. Some weird things balance. Like my recent defective snow tire. Completely defective but it spin balanced. Put on the spare at the wheel you hit and see what happens.
11-27-2018, 07:43 AM | #7 |
Rep 493
OP, on your first post you mentioned that vibration starts with a (separate?) noise, can you elaborate? Maybe there's a clue there.
Were you braking while hitting the pothole? Could you lift the front wheels, grab each one at the tire and compare the bearing plays, both East-West and North-South? Do you feel the vibration mainly on the steering wheel or through the seat? |
11-28-2018, 07:25 PM | #8 |
Rep 812
Get a ROAD FORCE balance. This will find unbalance that "static" balance will not. Have them check the "wheel run out" when you get the Road Force balance. This will tell if rim or tire has been warped/egg shaped out of round. You must find a COMPETENT shop that actually knows how to use the Road Force machine.
Formally known as BMWM3NYC
ajob456.00 |
