      12-10-2018, 04:02 PM   #1
HJ
Drives: F16 X6 CLS63 S
question regarding rear cig socket!!
Hello tried searching but couldnt find anything in regards to the F16.
Does anyone know if the rear right side of the trunk cig/accessory socket is a constant charge even when the car is shut off?
      12-10-2018, 04:18 PM   #2
diesel733
Master of one
diesel733's Avatar
Drives: 2018 BMW M3 ZCP IMOLA RED
It only has power for about 10 minutes once ignition is turned off. It's not constant power. It turns back on when you wake the vehicle up.
HJ478.00
      12-10-2018, 05:57 PM   #3
HJ
Thank you
      12-11-2018, 03:59 PM   #4
Johnr3524
Drives: 2018 X5
2012 BMW e92 M3  [0.00]
Yes, as described above (10 minutes), it's perfect and you can easily access the wiring behind it by removing a couple of plastic plugs on the right side (when facing the outlet). I used it to hard wire mount an AT&T router gateway for WiFi in the car. I wired it in so nothing shows and tucked the router into an open slot in the fuse box adjacent to outlet. Works well.
HJ478.00
Search this Thread:
Advanced Search
