02-19-2022, 11:48 PM | #1 |
Rep 175
Parts number for oil Maintenance
Hello
I would like to ask all of you what they have already done. I'm getting ready to change the oil in the front axle, transfer case, rear axle and transmission. What oils should I use? how much to fill each component oil? I found the following oils probably dedicated to my X5 F15 (I would like to ask for confirmation): 1. Front Axle > Hypoid Axle Oil G2 - one bottle 0.5L - 83222413511 2. Rear Axle > Hypoid Axle Oil G3 - one bottle 0.5L - 83222413512 3. Transfer Case > DTF 1 (SAE 75W GL-4) - one bottle 1L - 83222409710 4. Transmission ZF > Automatic Transmission Fluid (ATF) - 3+ - one bottle 1L - 83222289720 (the same parts number I have on sticker on oil pan ) can I apply this kit on my X5 F15 x35i? https://www.bimmerworld.com/Fluids/D...P-F22-F3X.html If I'm wrong please correct me. Thank you |
02-20-2022, 12:20 AM | #2 |
Rep 234
You need 2 bottles of the .5L for each the front and rear diffs. Not sure which rear differential you have but my standard rear diff called for 83120445832 - carbon mod 75w-85 unless bmw changed the fluid in the past couple of years.
02-20-2022, 05:06 AM | #3 | ||
Rep 1,021
You will need 2x0.5L bottles per diff. Just double check on your rear diff type. If its the M Dynamics, it will have 3x oil sections that needs 2x different types of oils Also real OEM says the regular rear diff take Hypoid axle oil G3 (83222413512), not sure if that's past a certain year range or just an update. The G2 should be fine. The transfer case will take approx. 600ml. Depends on how much you siphon out. Quote:
An old screenshot I found for the Dynamic Diff oil. Last edited by Chilled; 02-20-2022 at 05:29 AM.. |
happydude139.50 |
02-20-2022, 09:53 AM | #4 | |
Rep 175
Thank you for your help. I don't want to change anymore. But I want to buy and when the mileage is closer to 60k miles (MY 2016 - 10/2015), I'll want to do maintenance in all components. I have more time now so I am looking for information and I want to be ready I only have Adaptive M chassis (S2VF). I don't have the dynamic. then which one to use for rear axle? Hypoid axle oil G3 (83222413512) or G2 83222413511? Last edited by spit; 02-20-2022 at 10:13 AM.. |
