04-15-2016, 02:37 PM | #1 |
Rep 56
Heavy vibration from car/steering wheel when letting off the throttle
Greetings,
My car has roughly 3000 miles and this morning it began to vibrate when letting off the throttle at low speeds. The vibration is felt through the steering wheel and in the seat. The closest thing I can describe it to is braking with warped rotors.fIt makes a similar sound and it is felt in the cabin. My wheels and tires are perfect. When initially pressing the brake pedal, there is an unfamiliar feeling and a slight vibration but not as pronounced as when simply letting off the throttle. Please share your thoughts as I am concerned. I read the post about the wheel bearings and I dont hear a clicking or clacking sound. |
04-17-2016, 04:25 AM | #5 |
Rep 493
Similar steering wheel wobbling happened to me years ago in a Grand Cherokee.
In my case the reason turned out to be my stupid insistence to often strongly pump the brake when stopped, to catch up with the longer pedal travel as brake pads got thinner. This once brought one front pad to remain slightly but constantly pressed against the rotor: at sustained highway speed the rotor finally overheated, warped somewhat and the steering wheel started to wobble more and more, quite disconcerting. Stopping the car, I was lucky to see a little smoke from the brake. I removed the wheel, levered the brake pad a little away from the rotor and drove off. The rotor kept a little permanent warp, but I lived with it until the next brake & rotor change. |
04-17-2016, 07:17 AM | #6 |
Rep 455
Warping can occur after heavy braking (hot rotors) and then keeping the pads pressed on the rotors. Has this happened? One reason not to apply parking brake after heavy braking and to let rotors cool if one decides to bed down the brakes.
2016 X5 M - Sapphire Black/Aragon Brown, IND Black front/side grilles/side markers 2014 C63, Klassen M52Rs, Eurocharged tune - Gone |
04-17-2016, 01:41 PM | #8 |
Rep 455
