04-26-2022, 09:37 AM | #1 |
Rep 74
93500 mile maintenance
hey guys
15 f15 here up until now the car has run fine on just oil changes. what are some maintenance I should have done / should do soon as im running upwards of 93500 (151,000km) Ive done oil changes, coolant change, brake fluids, brakes (pads+rotors) Should i do Diff? Transfer Case? Transmission? BMW Dealer tried to sell me on Fuel Filter? But i dont see anyhing about the f15 requiring a fuel filter? |
04-26-2022, 10:47 AM | #2 |
Rep 1,687
Drives: 2014 428i and 2018 X5
Drive belt and tensioner
Transmission fluid and filter pan Differential fluid Transfer case fluid Spark plugs and coil packs You can get kits for the drive belt, transmission, plugs and coil packs at fcpeuro.com. They're even having a sale right now On kits.
04-26-2022, 06:04 PM | #3 |
Rep 1,532
You should definitely change your fuel filter, in addition to the above.
04-26-2022, 09:41 PM | #4 |
Rep 68
Thinking of picking up a used 15 x35i dealer said the car is in good condition, but I still need to take it to a mechanic. I am planning on putting aside some monies for things like this. How much will all of this set me back?
2019 M2 Competition Manual
2018 M3 Competition Manual (sold) 2018 C63S AMG coupe (sold) 2017 m240i (sold) 2014 Scion FR-S (retired) |
04-26-2022, 09:55 PM | #5 |
Rep 1,687
I DIY'd all those for about $500
04-26-2022, 10:28 PM | #6 |
Rep 297
04-27-2022, 09:51 AM | #7 | |
Rep 42
I've heard the belt and tensioner horror stories and will probably get the kiels plate to prevent a catastrophic failure. I feel like plugs and coils would come before trans, diffs and transfer case. Would that be accurate? |
04-27-2022, 01:02 PM | #8 | ||
Rep 1,687
04-27-2022, 02:40 PM | #9 |
Rep 1,532
Huh...looks like the 35i does not have a serviceable fuel filter. Thanks for the info.
OT but makes me question why it is integrated into the HPFP, wouldn't a replaceable filter prolong the life of the HPFP?
04-28-2022, 11:20 PM | #12 |
Rep 19
I would replace everything on this list except the transmission oil. If this is the first replacement on such a large mileage, there is a risk that the transmission will be damaged. Replacement should be carried out from the beginning of the operation of the car, every 25-30k miles, replacement on a large mileage is a risk. In this case, it is better to drive, I know cars that have traveled 170k miles without changing the oil in the transmission and everything is fine, all the other fluids on the list need to be replaced ..
04-29-2022, 05:07 AM | #13 | |
Rep 1,687
Hell, even ZF…who makes the transmission…recommends changing the fluid at 80k miles.
04-29-2022, 09:56 AM | #14 | |
Rep 19
At first it was good to check the pressure in the transmission and in each clutch. (A,B,C etc ..) and compare with adjustments from the factory. This will help you understand the condition of the transmission before oil change. You can do this in the program ista rheingold + enet |
05-02-2022, 10:44 AM | #15 | |
Rep 1,497
05-02-2022, 10:30 PM | #16 |
Rep 19
M302_imola842.50 |
05-03-2022, 11:03 AM | #17 |
Rep 1,497
Concerns me a bit as I have 112K miles on mine, and plan on doing a tranny pan and fluid replacement. Like others have said, they've had no probs after the tranny service, but then you have anomalies like yourself.
05-03-2022, 02:44 PM | #18 |
Rep 297
I know on the older 6spd ZF trans changing the fluid at such a high mileage was a bad idea. I know that's a different trans, but I still wouldn't if it was my car.
M302_imola842.50 |
05-03-2022, 04:10 PM | #19 |
Rep 79
M302_imola842.50 |
05-07-2022, 10:00 PM | #20 | |
Rep 123
05-16-2022, 11:20 AM | #21 | |
Rep 1,497
07-13-2022, 12:53 AM | #22 |
261
Rep 733
Yes, bad idea.
M302_imola842.50 |
