      07-09-2022, 12:43 PM   #1
whoismorggan
Bimmer Nut + Software Dev
whoismorggan's Avatar
Drives: 2018 Audi S3 IE Stage 1
Have had H&R lowering springs on for about two months. I wonder if something came loose?
The sound towards the end of the video is my elbow pressing into the center armrest 😅
Current: 2018 Audi S3 IE Stage 1
Past: '08 Infiniti G37S, '87 Porsche 944 Turbo, '13 328i, '15 M235i, '15 F80 M3, '16 M235i, '15 335i, '17 X5 xDrive35i
@whoismorggan
      07-09-2022, 02:02 PM   #2
whoismorggan
Took the wheel off to see if I could pinpoint where it's coming from... Tightened the lower strut pinch bolt but that didn't help. I don't think I have right tools to do much else.
https://youtube.com/shorts/igCXcOyCnqM?feature=share
@whoismorggan
      07-09-2022, 05:52 PM   #3
lht5059
Drives: F16 50i, F15 35d
I am like 85% to 95% sure your control arms and/or wheel bearings are shot lol... I had exactly the same thing happen and it was a pain in the butt; control arms failure is a known issue, so do some searches in the forum (listed some links at the very bottom for you).
If you put your wheels back on and do the typical wheel-bearing shake test (jack the car up), I'm comfortable in betting it will make a clunking sound and play when you shake it from side to side, but not likely to make the same sound or play as much when you shake it holding top and bottom... In case you are not familiar, there should be zero play (this is different than turning the actual wheels like when you turn left/right). I can't tell you which exact control arm has issues since I did all 4 fronts (there are 2 per side), though, but the bushings are what go bad... No point of replacing the bushing alone as the cost thereof is higher than replacing the whole arm. Wheel bearing-wise, this shake test wasn't indicative for me and the only way I knew was a humming sound around 75mph+ (even down to 60s once in a while) that very slightly changes against the direction the car is steering towards (think changing lane or big highway curve). Bringing this up because the sound could also be indicative of wheel-bearing problems... If you want to go with elimination, I'd rather fix the arms first since those go out early anyway, and see if the sound is still there...
Below is a brief breakdown of how mine happened:
https://f15.bimmerpost.com/forums/sh...68&postcount=8
These are some threads on control arms I bookmarked when mine made the same noise:
https://f15.bimmerpost.com/forums/sh....php?t=1832110
https://f15.bimmerpost.com/forums/sh....php?t=1509222
      07-10-2022, 11:37 AM   #4
whoismorggan
https://f15.bimmerpost.com/forums/sh...38;postcount=8
Thank you so much!! I should've searched the forum better.
It's most likely the lower control arm then, since I don't have any vibration or humming at high speeds.
@whoismorggan
      07-10-2022, 12:25 PM   #5
parthpatel1
Drives: 2015 X5 M Sport
Buy both the control arms and replace both on each side while you're at it. From FCP
      07-10-2022, 01:56 PM   #6
whoismorggan
This is the correct part for the passenger side, correct? https://www.fcpeuro.com/products/bmw...863170#fitment
@whoismorggan
      07-10-2022, 11:24 PM   #7
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
100% lower control arm. Search. My diy is here. Buy from FCP euro as it'll happen again if you own long enough. Known poor design on bmw for this heavy car to be "sporty". Bushings can't take the stress.
'06 C55 AMG (sold)
'14 X5 50i (wife’s now)
