01-17-2019, 11:35 PM | #1 |
Rep 944
High mileage X5m
Have around 43k miles and normally time for a new ride but I really enjoy every aspect of the x5m. Never owned a car out of warranty and wondering for those that have higher mileage cars out of factory warranty what type of issues they are running into
01-25-2019, 10:25 PM | #2 |
Rep 944
Nobody can chime in
01-26-2019, 06:16 AM | #4 |
Rep 900
I hear that the S63 is a solid engine if taken care of. From my experience with my other BMW's, issues typically crop up due to negligence and extreme abuse (e.g. gunning it to WOT while the engine is cold). Keep up with fluid refreshes and other scheduled maintenance items, and you should be fine. I've learned never to follow BMW's mileage maintenance. Always do it sooner, especially oil changes. And do not believe in the so called BMW life-time fluids! Always refresh the fluids!! When my X6M hits 50k miles, I plan to drain and refresh all the fluids - transmission, differentials, coolant and break fluid.
01-26-2019, 07:44 AM | #5 |
Rep 639
Hard to say, but properly maintained it should last a long time. Buy an extended warranty and keep on truckin'!
01-28-2019, 11:00 AM | #6 |
153
Rep 342
Drives: 2015 F85 X5M
53k miles here and outside of warranty items it's been a beast. Now, I wouldn't have wanted to pay for the items that broke under warranty but hopefully they are good to go now.
01-28-2019, 08:04 PM | #7 |
Rep 736
Just did a full over hull on mine, please change oil much sooner then 10k, and change it to a better quality oil, I went with bardahl, at 34k my rod bearings were Almost shot. I've also changed all fluids regardless of what the dealer says that it's lifetime.
www.mgruppe.org
01-28-2019, 09:50 PM | #8 |
1640
Rep 2,995
Wow. Was your engine knocking? Able to change bearings with engine in car?
01-28-2019, 09:52 PM | #9 | ||
Rep 736
I had a different issue, but no, had to pull it out, I not a Mechnic but I doubt you'll be able to change those without pulling it out
www.mgruppe.org
01-28-2019, 10:35 PM | #10 |
1640
Rep 2,995
01-28-2019, 11:36 PM | #11 |
Rep 944
I already had my diff replaced at 35k miles. Had several issues with the car so far but didn’t think too much of it as it was covered. I would be pretty pissed if I had to pay
01-29-2019, 01:46 AM | #12 | ||
Rep 736
Nope bmwna denied the claim stating after market parts were installed
www.mgruppe.org
01-29-2019, 01:49 AM | #13 | |
Rep 62
I'm not so keen on some of the more niche oil/lubes companies. My wife is high up in Exxon, my dad was a Chemical Engineer at Shell for nearly 30 years so between them I've heard pretty much everything a lay person would want to know. Even a lot of the Exxon people will tell you off the record that Shell V-Power gas is a little better than the Exxon equivalent. For oils/lubes I just don't understand the logic thinking a small company like Bardahl with $20m turnover can be better than something like Mobil oil which probably spends 100's of times more on R&D each year. I like supporting small companies normally but when it's related to science and R&D, money makes a big impact. |
01-29-2019, 02:44 AM | #14 | ||||
Rep 736
Point taken but tests don't lie, although this video is in Russian, which I speak, please take a look, results speak for them self
www.mgruppe.org
01-29-2019, 05:12 PM | #15 |
1640
Rep 2,995
01-29-2019, 05:38 PM | #16 | |
Rep 900
01-31-2019, 10:38 PM | #18 |
Rep 607
I had a F86 x6M with 68k mikes. Drove it 5k miles with no issues other than oil pan leak ($1700 repair). Had fun but didn't abuse it. It's all about the maintenance. Good luck
2017 F86 X6M
2014 F10 M5 2015 F85 X5 M 2015 F86 X6 M (Retired) 2014 F10 M5 (Retired) 2010 E70 X5 M (Retired), 2010 E92 M3 MT (Retired) 2006 E60 M5 (Retired), 2000 E39 M5 MT (Retired) 1999 E39 328i (Retired), 1995 525i (Retired) 1987 325i (Totaled - that was fun!) |
09-25-2019, 11:43 PM | #20 |
Rep 8
BUMP
ladies and gentleman lets update this thread to have an idea where everyone is sitting at with miles... I do have my eyes on a F85 with 60000km - 2015. deciding if I should add factory warranty right off the bat or wait a bit |
09-26-2019, 02:55 AM | #21 | |
F86, G05, E91
455
Rep 778
Enjoy the ride. Don't worry about potential repairs. Stay up to date on fluids. Jesus. Don't be cheap and take care of a mechanical piece of equipment built to 10 thousands of an inch tolerance. Don't like it? Get a Tesla or a Honda and have fun. Gross. |
09-26-2019, 07:23 AM | #22 |
Self-Deprecating Narcissist
7266
Rep 6,561
if the only thing holding you back from not keeping it is warranty then buy a warranty. if you dont have money for a warranty then you don't have money for any potential out of pocket repair. problem solved. /thread.
P111573.50 |
