02-15-2015, 11:59 PM | #45 | |||
Rep 7,063
02-16-2015, 08:56 AM | #47 | |
Rep 2,353
02-16-2015, 01:43 PM | #48 | |
Rep 710
02-19-2015, 01:34 AM | #49 | ||
Rep 875
It's true that the "feel" of the brakes with stainless braided lines will create a sense of better modulation under hard driving. If you are daily driving the car though, in my opinion the original rubber lines are the way to go. Cross drilled rotors have no place in serious motorsport. Most racing teams are using the modified slots or J-hook style of slotted rotors. If anything, cross drilled should only be on street going cars for the look and possible benefits of evacuating water better under wet conditions, but that is all. Even Porsche's "drilled" rotors are actually cast with the holes in them, so they are not really drilled. They, too, are more susceptible to cracking than a quality standard solid or slotted rotor in motorsport. For street, I'd say anything goes depending on the look you want. In any case, since we are on the subject of brakes, the M Performance brakes are merely for 1. Looks and 2. Better fade resistance due to the larger rotor sizes (ie. better braking under heavier braking circumstances like towing heavy loads or going up & down steep grades over long distances/time). The real braking performance is determined by the quality/compound of the tires since even the stock braking system can lock the brakes easily on these platforms. That being said, I LOVE these M Performance brakes. Look at the size difference of the rotors! Wonderful! |
02-19-2015, 09:22 AM | #50 | |
Rep 710
I'll share your comment that drilled (or we'll agree to call them "holes") has no place in motorsports with my track buddies. They need a smile coming out of winter hibernation. Three quarters of the field will have to park their cars. If failures were somewhat frequent, you would never see BMW or AMG or Brembo, or or or, manufacture these rotors due to liability. This is like another which oil is better debate... As for stainless steel braided, you'll notice I used the term DOT approved. I have been doing this a long time and have not had one SS line come back. I agree that regardless of the material, you need to do regular maintenance. I've seen rubber split far more often than braided leaking or failing. Look for DOT approved. Rubber lines are fine for you. I like the "feel" of braided. Dollar for dollar, if you are looking for a better brake feel, braided is the way to go over spending $$$ on new brake system. If you tow, then the bigger rotors, calipers and pads are a good option, but not completely needed if you maintain your braking system and use the correct fluid to, at least, raise the temperature of the boiling point of the brake fluid, and tow within the weight limits given by BMW. I agree that stock will stop the car just as fast as the M - but you definitely loose the wow factor. The irony here is that I am leaving my brakes bone stock, rubber lines and all...
02-19-2015, 11:34 AM | #51 |
Rep 875
Agree to disagree I guess regarding rotors. Unless your track buddies and you are running the carbon ceramic type of rotors which usually have the holes pressed into the mold, "holed" cast iron rotors are more prone to cracking under hard use than a comparable slotted/standard one. Anyone who wants to find what is not hearsay or myth can easily do a search on something like F1 or DTM brake rotors, for example, and see for yourself how many teams are using "holed" rotors (carbon ceramic is exception as mentioned). HPDE and autocross are not serious motorsports, in case that's what your track buddies are participating in. In those instances as I stated in my previous post, cross drilled are just fine.
As far as why AMG, Brembo, BMW, etc. are using cross drilled rotors on their vehicles, it is merely for the racing look and it is what people want/like. I stated that it does have its merits on the street. But it does not prove as reliable or durable as slotted/standard rotors in serious motorsport. Make no mistake that I have no qualms about cross drilled, I'm just trying to help with myth vs. reality. The mutual irony is that my brakes are completely stock, too. |
02-19-2015, 11:46 AM | #52 | ||
Rep 2,353
Here's a quick google... |
02-19-2015, 12:06 PM | #53 | |||
Rep 2,353
03-02-2015, 02:54 PM | #54 |
Rep 1,805
and we're 100% these will fit on the E70?
2014 F30 335i / 2014 F31 328d / 2014 F22 m235i
2019 G05 5.0 / 2012 E70 X5 50i / 2007 X5 3.0is 2011 e93 M3 / 2009 E60 M5 / 2004 E46 M3 2017 Alpina B6 22 Ram Trx / 22 M5 CS |
03-02-2015, 03:07 PM | #55 |
Rep 18,780
03-08-2015, 09:15 AM | #56 |
Rep 2,353
BMW GT3 and DTM cars running J-hooked AP Racing brakes.
http://bmwusaclassic.tumblr.com/post...2011-2012-alms |
03-08-2015, 10:33 PM | #57 | |
Rep 710
03-09-2015, 08:14 AM | #58 | ||
Rep 2,353
Essex packages AP racing brakes for consumers- they're quite popular on M cars. I imagine they could find a set up for the F15 if there was enough interest. Best thing about AP is they're considerably lighter than OEM/StopTech, etc. Not quite as flashy- though. One color, small, two piece. All business. |
