12-31-2021, 02:19 AM | #1 |
Rep 24
Whining on cold start
Hello, ever since it started getting colder I noticed when its 35 degrees or less my wifes F15 N55 driving from a cold start has a whining noise which fluctuates with RPM but tends to go away once the car is warm. I've had my transmission pan/fluid replaced a few months ago as well my serpentine belt along with idler pulley so I can pretty much rule out 2 common possible issues. Anyone else who reside in colder climates have this as well?
12-31-2021, 04:53 AM | #2 | |
Rep 611
If it's a loud squealing sound you need to re-adjust your belt. You could be hearing the power steering pump trying to move cold fluid, especially if you hear the whine change pitch when you turn the steering wheel, and since you recently replaced the belt it may need some tension adjusting to help the pump. That usually happens when it's much colder though. If it's a whine through the speakers then you have a ground issue somewhere on the vehicle. You can usually rule that out by turning the stereo completely off and see if it stops, but with the iDrive system I don't know if that works.
My Diesel Information Thread | My Wheels, Tires, and Fitment Thread | My Teardrop Camper Build | My F15 Suspension Lift Thread |
G05V85.00 |
12-31-2021, 12:14 PM | #3 | |
Rep 24
01-02-2022, 11:52 PM | #5 |
Rep 611
Ah good point. Depending on options some F15 have hydraulic steering. Active Steering and DHP options will come with it.
01-03-2022, 12:00 AM | #6 |
Rep 611
The N55 uses an auto-tension pulley, meaning it's spring driven and we can't "adjust" it, but you can check belt alignment and adjust as needed. If you feel the tension is out of spec than you may need to replace the tensioner.
01-03-2022, 09:20 AM | #7 | |
147
Rep 334
G05V85.00 |
01-05-2022, 12:01 AM | #8 |
Rep 24
Checked my invoice and it seems both have been replaced #11288604266 and #11288673720. Started to get a whirring howling noise anywhere from 20-60mph doesn't seem to be tire related as they have only about 3k miles on them (Conti DWS). Although my warranty expired about a month ago did make an appointment at the dealer next week hopefully it's nothing serious.
01-05-2022, 06:49 AM | #9 |
Rep 297
Is it an X drive?. Could be transfer case/differential issue. Wheel bearings are also a possibility. Just because tires are newish doesn't mean they were balanced properly or don't have a manufacturing defect from new.
