      08-14-2018, 11:55 AM   #1
M302_imola
M302_imola's Avatar
843
Drives: '15 X5 35i Xdrive Mineral Whit
35i Approaching 60K Service
'15 purchased in May with 54K miles. Just performed an oil change as well as air filter replacement. I know that spark plugs are recommended at 60K but what else? Fluids (tranny, transfer case, diff, brake, etc.)? Trying to keep her in tip top shape
      08-14-2018, 12:39 PM   #2
puckybadger
Drives: 2024 X6 M60i LCI TBII/Tartufo
Have the dealer do a key read
      08-14-2018, 01:27 PM   #3
M302_imola
M302_imola's Avatar
843
Ok, I try to avoid the dealer but I suppose you're correct.
      08-14-2018, 02:05 PM   #4
positiveions
positiveions's Avatar
Lebanon
961
Drives: 19 Tacoma, 16 Golf wagon
As a general rule of thrums for me, 60k service includes belts water pump and thermostat. With the exception of one car, never had to pull over for overheating. I would slap on some spark plugs as well.
      08-14-2018, 03:42 PM   #5
Mr.47
Mr.47's Avatar
480
Drives: F15 X5 35d
Brakes: Any DOT 4 brake fluid should suffice however, Pentosin DOT 4 LV is what I personally use with no problems
Transmission: Use OEM Fluid ie Lifeguard 8, and OEM ZF PAN, you can get this from FCP Euro ZF 8HP TRANSMISSION SERVICE KIT
Front & Rear Differential: 75w90 Liqui Moly
you'll need 2 one for each axle also need to replace oil fill and drain nut's
Transfer Case: Use BMW Transfer Case oil or ATC fluid by shell only!
Waterpump: 60k miles is about when BMW electric water pump failures occurs replace it with thermostat.
Brake pads: probally a good idea to inspect your brake pads and lube slide pins.
Appreciate 4
Remonster824.00
SCA564.50
HJ478.00
      08-14-2018, 04:16 PM   #6
Chef NOLA
Drives: 2021 X5 4.0i
Don't forget power steering fluid and brake fluid if they've not been done since purchase.
2021 X3 M40i, 2021 X5 xDrive 4.0i
2016 X5 3.5i, 2017 X4 M40i, 2006 330i E90, 2004 X5 3.0i, 2000 528i MT, 1986 535is MT , 1985 528e MT, 1985 325e MT
      08-14-2018, 04:24 PM   #7
Mr.47
Mr.47's Avatar
480
Drives: F15 X5 35d
All F15 X5's are electric power steering, no power steering fluid need.
      08-15-2018, 11:55 AM   #8
M302_imola
M302_imola's Avatar
843
I really appreciate your highly detailed post...huge help!
I had heard about the electronic water pump failure from a mechanic buddy of mine before the purchase. Are there any signs before failure?
Also, I've been hearing a very faint whine at low speeds in my parking garage at work. Sounds like low power steering fluid. Since ours is electric would this be an indication it will fail soon. Haven't been on here long but power steering failure doesn't pop up much.
      05-03-2019, 10:32 AM   #9
M302_imola
M302_imola's Avatar
843
I'm now just below 70K miles and I'm still hearing a faint whine at low speeds. In particular in the parking garage at work. I guess it's a good thing that the wine hasn't gotten louder over the 10K miles or so. Since there's no fluid, there's no maintenance to be had on the power steering. I guess I should prepare to replace it soon.
Chime in if you've had to replace yours and at what mileage guys.
      05-03-2019, 02:28 PM   #10
JC1979
Drives: '14 F15 X5 xDrive 50i M-Sport
Are you sure about what you are hearing? Could it be the turbos spooling up making that faint whine?
      05-03-2019, 05:55 PM   #11
Florida-X3
Drives: '24 X3 x30i / '12 Infiniti M37
My Indie guy told me 60k was cabin filters, brake fluid change, plugs and coils. Did cabin filters myself (one of the easiest cars I have ever done, someone at BMW screwed up). Dealer did plugs and coils under CPO for an issue I was having. Indie guy did brake fluid, rear brakes and rotors (brakes needed it).
      05-04-2019, 04:21 AM   #12
Jason73
Drives: 2022 X3 M40i
Just had mine done at BMW. Oil, plugs, brake flush and cabin filter. I did cabin filter myself. Total cost in Columbia SC for the rest was around $600.
      05-06-2019, 10:48 AM   #13
M302_imola
M302_imola's Avatar
843
I don't think the turbos spoil at 5mph cruising in the garage. It's exaggerated when I turn the stirring wheel.
      05-06-2019, 10:26 PM   #14
nOEMm
nOEMm's Avatar
166
Drives: 2011 M3 e92
This is wild lol
'11 E92 M3 ZCP Mineral White - Fox Red Extended
‘15 F85 X5M Mineral White - Aragon Brown Full
      05-07-2019, 03:15 PM   #15
mrfochon
Drives: X5 F15 M package
Went to dealer today for same maintenance.
Will post the receipt
      05-07-2019, 05:14 PM   #16
Stamps
Stamps's Avatar
Drives: 2017 F85
Don't want to be the one who points out the obvious, but my tires squeal in almost every garage. It gets more pronounced when turning. I hope, for your sake, that is all it is.
      05-08-2019, 10:36 AM   #17
M302_imola
M302_imola's Avatar
843
In a perfect world, but it's not tires squealing in my case.
      05-08-2019, 11:10 AM   #18
MrTookies
MrTookies's Avatar
Drives: 2011 E90 328i, 2015 F15 35D
Waterpump: 60k miles is about when BMW electric water pump failures occur to replace it with the thermostat.
Brake pads: probably a good idea to inspect your brake pads and lube slide pins.
I thought the Front and Rear Differential are 75w85 either Redline or Ravenol if not BMW? (83222295532)
https://www.amazon.com/Ravenol-J1C11...r=8-3-fkmrnull
https://www.fcpeuro.com/products/75w...red-line-50104
Also why do you need to replace fill and drain nuts?
