01-11-2020, 09:53 AM | #1 |
Rep 165
Oil pan gasket
I’m at the mechanic now changing both my differential fluids and the transmission pan. I noticed oil on the engine motor screw where you loosen to change the engine oil and asked him if that was normal. He checked it out and told me my Oil pan gasket needed to be replaced. I checked for the part and it was 36.00 dollars on FCP euro. The mechanic told me he would charged me 1,000 dollars to change it. Is this a normal price for this? Seems a little much for such a simple piece. He continued to tell me that he would have to take apart the whole suspension in order to get to the spot to change it and it would take 2 days for the job to be done. Should I go somewhere else? I’m in NYC.
01-11-2020, 11:06 AM | #3 |
Rep 161
You need to figure out if it's your upper or lower oil pan gasket that's leaking, because that is a HUGE difference in labor. Lower pan gasket should be maybe a couple hours total, the upper is about 12 hours. BMW quotes around $4200 for upper oil pan.
01-11-2020, 11:08 AM | #4 |
N00B
94
Rep 210
I would absolutely get a second opinion. It could have been loose, or stripped, etc. Did he show you the oil on the bolt or did you notice and ask? Suspension has nothing to do with the lower oil drain plug/oil pan/etc.
The owls are not what they seem!
01-11-2020, 03:38 PM | #5 |
Rep 165
01-11-2020, 03:48 PM | #6 |
Rep 165
I didn't know their was two separate one but he told me it was "Seals oil pan to engine block" the car was lifted so he was able to show me from under the car where the seal was. I looked at it and it was wet with oil.
01-11-2020, 03:53 PM | #7 |
Rep 165
I noticed and asked then he looked around with a flashlight and spotted wet oil around the gasket. The car was lifted so you could see from standing under the car where the seal was and how it was wet with oil. I'll try to get a second opinion, I asked him how urgent was this to replace and he told me that shouldn't mess other parts of the car but I should keep a look out for the measurement of oil since it's leaking.
01-11-2020, 05:50 PM | #8 | |
Rep 2,736
You'll get the oil pan gasket and the oil filter housing go at some pint. Yea it's a big job and 1000 is normal. I paid 800 for mine but that was a discounted rate. Depending where you are and your shop hours has an effect of price but he's not pulling your chain. You need to drop the whole subframe to get to it properly. Theirs a few that can do it without dropping the subframe but it's a huge PITA and risk of damaging your gasket. The leak will gradually get worse as the oil is actually above the gasket line so it starts slow. I've had it happen to me on two N55 products. It's a matter of when not if. |
01-12-2020, 10:18 AM | #9 | ||
Rep 165
01-14-2020, 01:21 PM | #10 |
1148
Rep 2,426
I asked my dealer to check for oil leaks before warranty expired and this is one of the leaks they found along with the rear main seal. They had to keep my car for a couple days; the transmission and everything needed to be dropped.
2015 BMW X5 xDrive50i
BMW CCA 509766 |
01-14-2020, 06:50 PM | #11 | |
Rep 2,736
Good catch! |
06-24-2020, 01:46 PM | #14 |
Rep 2
Sorry to hear...
I'm sorry to hear about your oil leak. I just had a similar situation. I was having KWs installed on my 2016 X6 and the mechanic pointed out the underbody pan was covered in oil. Took it to the Dealer to and found out the rear main seal was leaking. Took 4 days to get the part and have it installed. Thankfully it was covered by the warrantee.
I wish you the best with your issue. |
01-21-2021, 08:24 AM | #15 |
Rep 79
Drives: 2016 BMW X5 35i M Sport
Oil Gaskets / Lower and Upper
Well, Just took my 2016 X5 35i MSport in for regular service and i mentioned the smell of burning oil. The tech did the inspection and found the upper oil pan gasket, lower oil pan gasket, both oil lines to the turbos needed to be replaced. $6,000!!! Yep! I have Veritas Global Protection -Premier Plan. Waiting to hear back from my BMW SA to make sure all of this is covered. From what I could tell in the fine print, it stated all gaskets and seals were covered. Let's Pray this is correct.
I have 66,000 miles on it. It was delivered in August 2015. It was one of the first builds for 2016. Other than this the car has been flawless. Love it. Let me know if any of you have had any experience with Veritas. Thx!
“We at BMW do not build cars as consumer objects, just to drive from A to B. We build mobile works of art.”
Chris Bangle (former head of design, BMW) |
01-31-2022, 05:54 PM | #16 | |
Rep 63
02-03-2022, 05:17 PM | #18 | |
Rep 79
