01-30-2020, 10:01 AM | #1 |
Rep 271
Long term storage/suspension sag
Having had my '02 m5 as a daily beater since '09, I've seen what the road salt and crap does to it, so I've kept the m5 as a daily beater and parked the f85 for the winter. It's been parked since the end of November and I noticed a couple of weeks ago that the rear was low. I'm assuming this would happen over time since the car hasn't been started and the suspension system hasn't been charged since then. Should I start the car to get the suspension pumped up? Should I place the car on jackstands so that they support the car once it starts to sag a big? Or just leave it alone until I start driving it regularly?
TIA! |
01-30-2020, 10:28 PM | #3 |
Rep 1,449
No issues with mine in the winter. Put some winter rims and tires on it an have fun, that's why I got mine. I park my M3 for the winter and start it up every few weeks and let it run for 30 minutes or so to keep the fluids flowing and the battery fresh, I would recommend the same for your f85. Even do a little road driving it the conditions are to your liking.
No. Try not. Do. Or do not. There is no try.
-Yoda |
02-02-2020, 04:36 AM | #4 |
188
Rep 364
Drives: M2C X5M M4
I wouldn't have thought you have a major leak but maybe just natural leakage through the air system. If it's completely down after 8 weeks I would say maybe a small leak above natural leakage. Mine will sit for 4 weeks and doesn't drop but I've never left it for 8 weeks.
I would start it up to refill the bags and maybe spray some soapy water on the bags and see if you can see bubbles forming as I would suggest it has the start of perishing. Leaving leaky bags is a false economy as the compressor works overtime and you still have to replace them but possibly the compressor too. |
02-02-2020, 06:17 AM | #5 | |
Rep 271
I realized i left the window cracked when I parked it because I just washed it, so either when I opened the door or pressed the start button to turn the electric on, I heard a small pump go off and watched the rear of the car go up, so no need to start the engine. Will keep an eye on it to see how fast it sags again.
02-06-2020, 01:34 PM | #6 |
Rep 1,004
Yes, if you plan on starting up your stored vehicle, bring the engine up to operating temperature before shutting it off. That way, you can burn off any moisture that has developed inside the engine. And parts/seals will be well lubricated. And after a first few seconds your suspension should start to raise up.
