02-07-2020, 12:54 PM | #1 |
Rep 449
Lock the car with running engine
Is it normal for our cars to have this option? I can close the car with remote when the engine is ON. Not sure if I activated this with Carly but I dont think so.
The only negative is that the cars horn will sound twice when you close the doors and its loud Last edited by PhillyX5M; 02-07-2020 at 09:12 PM.. |
02-07-2020, 01:08 PM | #2 |
Rep 1,062
Drives: F15 xDrive50i M-sport
Close the car? Or lock it? Obviously you can close the door, but I don't think you can lock it.
02-07-2020, 01:16 PM | #3 |
Rep 449
02-07-2020, 01:24 PM | #4 | |
Rep 1,062
I've had it running and taken it to the car wash in my building to rinse some slush and snow of it, with the key in my pocket, and hit the exterior lock button with the stream of water and had the horn go off. Scared the pee out of me. But I don't know if it actually locked or not.
02-07-2020, 01:49 PM | #6 | |
Rep 1,247
I use it almost daily.
02-07-2020, 03:32 PM | #9 |
Rep 135
You can definitely lock the doors from the remote or handle while the car is running and in park. However if you have people in the car and you lock it... The car will flash its emergency lights and make noise very often to let you know people are in there
02-09-2020, 11:51 PM | #11 |
Rep 1,449
yep, do it plenty of times either from the comfort access door handle or the remote. Can't remember if mine sounds the horn. Would imagine you could change that in the profile without need for code, because you have the option to sound horn or flash lights when car is locked/unlocked. Will have to double check what mine does.
No. Try not. Do. Or do not. There is no try.
-Yoda |
02-10-2020, 11:48 AM | #12 |
528
Rep 2,822
Drives: X5M F85
LOL i did this on my E70.... locked the keys in the car too, with the engine running. So i had a catless X5M with an exhaust rumbling for an hour until the locksmith came and popped it open. I immediately found the spare set in my workout room on the bench after he left. This "feature" was an option i enabled via coding... Something like; lock doors after a certain time time passes with the car started.
