      02-16-2025, 04:41 PM   #177
titanjc
Drives: 2017 X5M
Digging up an old thread, specifically regarding the differential drain plugs.
I'm planning on taking my new-to-me 2017 X5M in for service and a full fluid change in the coming weeks. I already ordered one of the MMX Performance Magnetic Differential Oil Drain Plugs from IND, but am now reading that there are three drain plugs. Would it be beneficial to have a magnetic plug at each location? Are all three of the drain plugs the same size?
This is the plug I ordered: https://ind-distribution.com/collect...l-plug-m22x1-5
      02-18-2025, 10:01 AM   #178
Yuille36
Yuille36's Avatar
Drives: X5M, M3 ZCP 6MT, MB E63 AMG
2015 BMW X5M  [9.87]
2017 BMW/M3  [9.92]
Yes, absolutely. I have actually have five on my F85 X5M; three for the rear differential. One on the transfer case and one of the front differential.
titanjc77.50
      02-18-2025, 09:05 PM   #179
Chilled
Chilled's Avatar
Australia
593
Drives: F85 X5M
Just be careful about using those on the drain plugs for the outer clutch packs. Use them on the fill plugs instead, more info below.
https://f15.bimmerpost.com/forums/sh....php?t=1951992
titanjc77.50
      02-19-2025, 07:30 PM   #180
titanjc
Drives: 2017 X5M
That's great information, thank you for the heads-up. I'll make sure that my shop uses them as the fill plugs on the outer chambers.
      02-20-2025, 05:43 AM   #181
Yuille36
Yuille36's Avatar
2015 BMW X5M  [9.87]
2017 BMW/M3  [9.92]
I'm trying to understand why you stated to use these magnetic plugs as fill plugs instead of drain plugs? Any metallic particles will always sink to the bottom where they will be collected onto the magnetic plug.
I personally have magnetic plugs on both diffs front and rear, and the transfer case. That is five in total.
      02-20-2025, 10:14 PM   #182
Chilled
Chilled's Avatar
Australia
593
Drives: F85 X5M
Have a read of the thread, some of the magnetic plugs are longer than the OE ones. You run the risk of them contacting the clutch baskets. On one side I didn't have any issues, on the other I was touching/within like a couple of mm.
Per the pics, it looks like one of Tony's plug made contact with one of the baskets.
      02-21-2025, 10:34 AM   #183
Yuille36
Yuille36's Avatar
2015 BMW X5M  [9.87]
2017 BMW/M3  [9.92]
Thank you for clarification.
Search this Thread:
Advanced Search
Copyright ©2000 - 2025, vBulletin Solutions Inc.
