01-31-2022, 12:45 PM | #925 |
Rep 43
Good info. Thanks. So next question becomes where do the center of the pistons sit relative to the center of the hub? Meaning if they sit in the same spot as say the M5 calipers, having the bigger 400mm rotors won’t be much of a gain (at least on the street)
01-31-2022, 02:26 PM | #926 | |
Rep 462
01-31-2022, 03:22 PM | #927 |
Rep 213
I'm guessing the pistons weren't out during measurement. The faces usually measure a little under actual diameter. I found these specs.
The Porsche rear calipers I have are 32mm as well. It seems that the piston diameters are much larger than the f85 or 50i. Using the whole system from the Porsche would likely feel balanced if the smaller diameter 350mm rotors were used in the rear. The 50i uses a slightly larger piston (34mm) rear caliper. With the 345mm rear rotor, this should work well with the F85 Front calipers and larger 395mm rotors. Best bang for the buck would be just upgrading the front brakes to F85 calipers and rotors. The from to rear bias would stay close to stock. Cosmetically, not so great with the single piston floating caliper in the rear. With the larger F85 or F10 rear rotors, it would be optimal to use the smaller piston F85 rear caliper or a 30mm Porsche caliper if one exists. Due to the smaller surface area of the F85/F10 6 piston calipers, using a 32mm 4 piston rear caliper will reduce front bias quite a bit. It would start making sense to use Porsche front 6 piston calipers at that point to keep forward bias. Panamara and VW Toureg: Front 36mm 6 piston Rear 32mm 4 piston Front rotors 380mm Rear rotor 350mm Next big question, is there a 30mm 4 piston caliper out there? 996 Porsche have a 28mm/30mm rear, but that increases front bias when used with the F85 Front caliper. Front bias would be similar to the MPB which is heavily Front biased. 30mm really is the sweet spot for the rear caliper. Last edited by notslow; 01-31-2022 at 03:30 PM.. |
01-31-2022, 03:33 PM | #928 |
Rep 43
IMO I wouldn’t worry about rear pistons/rotors being too “big”. I doubt one can notice the difference in front to rear braking performance change. A very easy solution would be to run very conservative/harder pads in the rear. We do this on racecars all the time without changing the “actual” bias. Also I’m assuming when you say “bias change” you referring to coding the computer. Just changing pads/rotors won’t change the bias unless you get into the abs.
Only way to change bias from what I know about this car when not in the abs would be to code it into the computer |
01-31-2022, 04:09 PM | #929 | |
Rep 213
The Brembo systems on just the front were well balanced, but the front and rear Brembo systems would lock the rear wheels first at threshold breaking or trigger Abs way too early, not good in a turn. I'm sure these modern BMWs are more forgiving with all the computer controls keeping the wheels from locking. |
01-31-2022, 04:10 PM | #930 | |
Rep 462
01-31-2022, 06:27 PM | #931 | |
Rep 43
Well it depends on your definition of brake bias I guess. Without going to deep into the weeds, we don’t have a great way to measure braking force or braking torque (some cars or racecars have torque sensors on the axles but that’s a topic for another day). So typically when you say brake bias we are referring to line pressure. On ABS cars, line pressure is typically fixed unless you get into the ABS. On some cars and almost all GT3 racecars now, you have both a brake bias adjustment knob as well as an ABS map knob. So the driver could adjust both fixed bias as well as how the abs responds when the driver does get into the abs. Then add in different styles/brands of rotors/pads, calipers etc.
In either case, the question becomes how do you slow the car down the fastest? On a street car, it’s actually harder to optimize bc of varying brake temps. For example, it’s totally silly to have carbon or carbon ceramic rotors/pads. On the street, you will never keep them in the proper operating window (unless you just want the weight out of the car, unsprung mass is another topic for another day) Hope that helps. Again, we’re not on the track so other than driver “feel” I doubt any of the combos in this thread are night and day better compared to each other. Quote:
07-25-2022, 08:39 PM | #932 |
Rep 213
For anyone who has installed the F85 front calipers. Did you change the dust plates and brake lines? I know that the f85 has different part numbers, so not sure if my 50i pieces will work. Sometimes the dust covers are a negligible difference, but want to be sure for this application.
I'd like to order parts this week. Already have the calipers. Just need pads, rotors and maybe dust plates and brake lines. Last edited by notslow; 07-27-2022 at 01:38 AM.. |
07-26-2022, 09:13 PM | #933 | |
Rep 462
07-27-2022, 12:26 AM | #934 |
Rep 213
Thanks, I compared some photos and it definitely looked a lot larger diameter. I also found out the brake lines for the 50i are an inch too short for the X5M calipers.
10-20-2022, 09:28 PM | #935 |
Rep 1,859
Drives: 23' X7 40i M Sport
Question - are the caliper guide pins and caliper bracket bolts the same between stock 50i and the ones that come with the MPBK? Before I start taking apart my brakes I want to make sure they are the same since I can't find the original stock hardware.
https://www.pelicanparts.com/More_In...41-M4&fc=Y https://www.pelicanparts.com/More_In...4-BOE&fc=Y
10-23-2022, 12:22 PM | #936 | |
Rep 1,859
The bracket bolts are the same as stock.
10-23-2022, 08:03 PM | #937 |
Rep 6
10-26-2022, 02:47 AM | #938 |
Rep 4
10-26-2022, 02:48 AM | #939 |
Rep 4
10-26-2022, 08:47 AM | #940 |
Rep 1,859
Just remove the rotors to access the dust shields. They are secured by a few small bolts.
10-28-2022, 07:14 AM | #941 |
Rep 462
Sole of our recent work 👍👍👍👍
12-30-2022, 03:22 PM | #942 | |
Rep 113
Drives: X63.0D, 911C4S
source of Brembo refurbished calipers
thanks in advance. Richard |
01-10-2023, 09:00 PM | #943 |
Rep 462
You can either email me at dentprotony@gmail.com or text me directly at 6016181023, ill get you a set 👍👍👍
01-11-2023, 09:29 PM | #944 | |
Rep 7,160
classic_erik2811.50 BlackBeans75.00 |
01-31-2023, 11:04 PM | #945 |
Rep 9
Hi all, recently did a full retrofit on a BMW X5 F15 using F85 X5M BBK parts, 6 pot front callipers, 395mm rotors etc.. rears seems just rotors are bigger and callipers are the same.
I noticed no difference, actually performance felt worse and I had bled the brakes twice. Feels really soft on pedal. Do I need to code anything? There is an option to code m performance brakes as a retrofit, would this improve? Thanks |
02-01-2023, 08:06 AM | #946 | |
Rep 1,859
