11-27-2019, 12:53 AM | #1 |
Rep 586
Exhaust valve...
Stupid question, but when is the exhaust valve open? For some reason I expected there to be an exhaust button to control the valve, but I see nothing...?
Is it just when the throttle response is set to sport plus? Or is is the drive logic setting? Or perhaps everything must be set in the max mode?? Thanks for the help.
2021 Mercedes G550
2015 X5M 2020 Supra-JB4, DP 2008 M5 with muffler delete-sold 2007 650i-sold 2008 335i-JB4, DP, Meth-sold |
11-27-2019, 12:38 PM | #4 |
Rep 26
https://www.cgprecision.com/#!/VSC-2...egory=17975158
Allows you to control the valves regardless of engine settings. Had this on my F80 M3 and now on my F86 X5M. Works great. Easy DIY install. Can even use the HomeLink buttons on your rearview mirror to control open/closed/factory settings. |
335i10179.00 |
11-27-2019, 02:34 PM | #5 | ||
Rep 1,025
Drives: Mein F Fünfundachtzig Einhorn
11-28-2019, 06:46 AM | #7 |
Rep 18
12-03-2019, 09:06 PM | #9 | |
Rep 18
Thank you. What kind of adapter are you talking? I have a similar 'kit' to control a 911's exhaust valve on/off via key fob or homelink button. It is a bit complicated to wire and install (for a newbie). |
12-05-2019, 08:08 AM | #10 |
Rep 71
I set my M1 button with these settings: Engine Sport + everything else: normal/efficiency. So when I click M1 and then I touch the pedal (or when driving), the exhaust valve opens and stays open.
With this setting my M1 button is my exhaust button. |
12-07-2019, 09:43 PM | #11 |
Rep 859
it's one of the adapters recommended by the app, and sits in the OBD port
12-08-2019, 11:16 AM | #12 |
Rep 18
