12-07-2019, 10:07 PM | #1 |
15
Rep 35
Keeping the tunes playing w ignition off
My 2015 X5 35i would keep playing tunes if I had the car running and I opened the drivers door and then cut the engine. You could then open the trunk and have music playing for three or four minutes even if you closed the front door.
The music would then turn off if you hit the lock button on the trunk lid. Problem is my 2018 won’t do this. Music cuts off whenever front door is closed even with other doors opened. Is there a setting someone knows that can be like the 2015 or has programming changed? Thanks for your comments. |
12-08-2019, 05:29 AM | #3 | |
Rep 1,221
Now my 2018 is not coded at all, but perhaps there is some configuration in the iDrive that enables this option. |
12-08-2019, 10:42 PM | #4 |
15
Rep 35
Thank you both for your comments. I don’t have much experience with coding and have read a lot of posts here about it.
I was hoping it was some setting in iDrive but I can’t find it. I like the tunes playing with the trunk opened as I get my golf cleats on.. |
