05-23-2024, 09:28 AM | #1 |
Rep 33
H&R Spacers Issue
I noticed a difference between these 2 wheel spacers:
- 15mm Product code 3075742. They have an external bezel that ensures that the wheel hub is perfect. - 20mm Product code 4075741. They do not have any pronounced external bezel, this means that there is a mm of play (in fact only with this spacer does the wheel create vibrations) I imagine the code 3075742 15mm is newer model, but how do I purchase the same model for the 20mm spacers? Thanks and sorry for my english |
05-23-2024, 02:57 PM | #2 |
Rep 33
r33_RGSport13506.00 |
05-23-2024, 04:16 PM | #3 |
Rep 19,005
They make the design as necessary as the car need.
Those bezel is to create extra mm for the updated front hub. While the rear don't need it since it will clear the hub lip.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEAL!! | Akrapovic 10% Off SALE until Oct 15th 2024 MSS iSweep RaceChip Sterckenn AutoTecknic Akrapovic Vossen Wheels Eventuri Active Autowerke KW H&R Ohlins Remus and more... |
05-24-2024, 12:44 AM | #4 | |
Rep 33
I have only 2 questions: All 20mm spacers H&R doesnt have a bezel? The spacers 15mm (with bezel model) could be a problem for the rear wheels? at least in my case, those bezel is also very important for the rear wheels, as it eliminates that half millimeter of gap between the 2 parts (cause of vibrations at 100kmh) Thank for the help. |
05-24-2024, 01:20 AM | #5 | |
Rep 19,005
They will be able to answer you down to the detail on why the 15mm has it, while the 20mm doesn't. Based on all of my installation, both work perfectly fine.
05-28-2024, 07:28 AM | #7 |
Rep 33
r33_RGSport my F15 made from 10/2014, for the front rear is correct new spacers 15mm (3075742) or i will buy the old model?
Thanks |
05-28-2024, 08:41 AM | #8 |
Rep 19,005
The 3075742 supersedes the old model and will fit all MY.
giustyle11.00 |
