      07-28-2016, 11:04 AM   #45
stewy604
stewy604's Avatar
290
Additional feedback on the Carbotech 1521 pads I went with, following two weeks of driving...I washed my X5 last night, and the wheels were barely dusted at all. Very happy with these over what I've seen on the BMW OE side with these kits. Would highly recommend these pads to anyone looking for a great performer with low dust. Mike Puskar Jr. is the guy I dealt with @ Carbotech, he was great...very easy to deal with.
2007 Suzuki GSX-R 750
      07-28-2016, 03:05 PM   #46
Mohamed-Kwt
Drives: "15 X5 50i M Sport
Originally Posted by admranger View Post
Just to be clear, what I called the "rear edges of the brake pads" would be at the bottom of the caliper. It's actually the part of the brake pad that the rotor hits first (perpendicular to the direction of the rotors movement).
If my description is confusing, just bevel them all, a little bit won't hurt performance. If I had any skills at making marks on a picture to point it out I would. However, I don't...
I kind of understood what you're referring too, as you said a little bit won't affect the performance, thanks though for the enlightenment, really do appreciate it.
I'm looking forward into swapping my pads with carbotech if this try ends up to a fail in reducing the squealing noise, I'll report on the outcome in due course.
      07-28-2016, 03:15 PM   #47
Mohamed-Kwt
I'm glad to read your feedback stewy, you won't believe the amount of the brake dust my OEM pads are generating every couple of days, not to mention the enormous squealing noise every time I'm pulling to a stop infront of the house in our quite neighborhood, it's almost sounded like a damn trailer!!
      08-12-2016, 12:10 PM   #48
alphaod
alphaod's Avatar
I'm thinking of getting these installed on my car. I'm not a fan of cross drilled rotors on an SUV so most likely will just go with the kit. But I have one concern: will these clear the factory 18" spare donut?
      08-12-2016, 12:41 PM   #49
1230vani
1230vani's Avatar
653
Drives: G05 40i LCI
Yes. U need at least 19" for these brakes
      08-12-2016, 01:29 PM   #50
Alan l.
Alan l.'s Avatar
5450
You will need to factor in ordering a E70/F85 spare if you get these brakes. I think the stock spare fits over the rear brakes just not the fronts so if you get a flat up front you might be able to swap the rear wheel up front first then swap the spare on the back. Twice the work. Someone should confirm if this actually works though. Don't take my word for it because I never actually tried.
Alan
      08-12-2016, 02:26 PM   #51
knepsterd
Drives: 2018 M3 BSM
You can get the rim for 250-350 on eBay
Only problem is the tire on them are usually 10-15 years old. So even if never used, DOT suspect and expired. Also not sure it needs special hardware, sellers never have that. And finally a jack. All new materials are like 550-600. Crazy. Cheaper to get plug and spray. And pay for hire party tow service.
      09-23-2016, 12:46 PM   #52
aroach04
Drives: '14 F15 50i M Sport
Originally Posted by Alan l. View Post
I coded my car myself with the help of shawnsheridan. Once we new what value to code the process takes less than 10mins.
Alan
Do you remember the coded values? I'd like to verify my setup is still coded correctly.
'14 X5 50i M Sport
MPBK | Meisterschaft GTC exhaust | H&R | V1 | IND | RG Sport |
      09-23-2016, 01:23 PM   #53
SMC23
Drives: Subaru XTrek / X5 40e
**UPDATES**
Picked up my X5 this afternoon from the dealer, all coded, pedal feel is much stronger than prior to coding, and have driven about 50 kms since pick up. Apparently the coding raises the pressure in the "vacuum accumulator", and thus alters pedal feel and effort. Very happy customer with these brakes. Now, to find touch up paint that will be a close match to the blue calipers.
I too wonder if the standard brake kit can support the coding.
I feel like the only issue with our 40e is the brakes!
      08-15-2017, 01:47 PM   #54
beachcomberx5
Drives: X-5
Having this installed tomorrow by dealer. Will report back.
      08-15-2017, 09:26 PM   #55
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
What are you reporting back?
'06 C55 AMG (sold)
'14 X5 50i (wife’s now)
      10-03-2017, 10:18 AM   #56
Yaw
Drives: Many
Can anyone share the steps to get these coded. The kit is currently installed, not coded yet.
      10-03-2017, 02:24 PM   #57
Yerbol
Drives: BMW M3 G80 Competition
here is my BBK for my X6
Appreciate 4
      10-03-2017, 02:47 PM   #58
beachcomberx5
Drives: X-5
FYI the dealer did mine and it also required a software update....they said the update took several hours.
      10-03-2017, 03:56 PM   #59
Yaw
Drives: Many
Believe that is the X5/6M brakes. M performance BBK is 4 piston front, single piston sliding caliper rear. Also just noticed radial pins for floating discs are different design than what I have.
iconoclast7265.50
      10-04-2017, 12:27 AM   #60
Yerbol
The front brake from M5 and rear one from F86 except the caliper. Rear caliper is Brembo adopted and painted to this brake system.
      10-04-2017, 08:12 AM   #61
Yaw
Drives: Many
Sweet, well done!!
Yerbol55.50
      10-04-2017, 12:49 PM   #62
monkiboy
Dominican Republic
535
Drives: '17 x5 3.5i w/MPPK & MPE
only one photo of installed MPBK in this thread three pages long? let's see 'em!
Chadmatic660.50
      10-04-2017, 02:16 PM   #63
Yerbol
as requested
Appreciate 5
Chadmatic660.50
DuSh2113.50
monkiboy534.50
surfcali245.00
iconoclast7265.50
      10-04-2017, 10:22 PM   #64
DuSh
DuSh's Avatar
2114
Drives: F15 X5 50i
as requested
That looks sweet man
Yerbol55.50
iconoclast7265.50
      10-08-2017, 09:57 AM   #65
radrads203
Drives: 2014 F15 X5 30d
as requested
Btw Yerbol, wanna ask what’s the treadwear on those tires? I am thinking of changing mine to these...
      10-22-2017, 10:30 AM   #66
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
That sounds like a $5000 brake job lol but exactly what I want to do.
'06 C55 AMG (sold)
