09-23-2018, 12:33 PM | #1 |
Rep 4
BMW conversion from US to EU
Hey,
I need your help. I bought my X5 in the USA. Model F15. I managed to convert the radio to the EU version and change the language version to PL with iPad. Now I'm struggling with navigation. I downloaded navi "BMW NBT Road Map Europe Europe NEXT 2018-2". After unpacking 24 winrar files, I have a directory with 5 folders (numerically named - 1,2,3,4,5) and three files named "config.nfm", "NBT_ECE_101173.3.111.pkg" and "NBT_ECE_101173.3.111.sig" . I'm losing everything on 64GB pendrives. I put the pendrive into the USB port on the clipboard and nothing happens. I've tried with 3 other pendrives - the effect is the same. Originally I have uploaded maps "Road Map NORTH AMERICA Next 2014-2A" code "NBT_H14202A". |
09-24-2018, 10:00 AM | #2 |
Freude am Fahren.
801
Rep 1,286
Drives: F15 X5 xDrive35i
Format the USB drive the right way and try it again.
Freude am Fahren.
09-24-2018, 12:20 PM | #4 | |
Rep 2,194
OP, after you extracted with WinRar, then you should copy everything from folder called NAVXXXXXXX to the root of your USB stick. (not the full navxxxxx folder just the content from inside). Insert and it should start automatically. Last edited by Violator; 09-24-2018 at 12:33 PM.. |
09-27-2018, 04:52 PM | #7 | |
1148
Rep 2,426
2015 BMW X5 xDrive50i
BMW CCA 509766 |
09-27-2018, 05:04 PM | #8 | |
Rep 2,194
I loaded European maps on both my F16 an F15, it can be done with a usb and the correct files. Then later when they were shipped to the US, NA maps were installed. |
alphaod1148.00 |
09-27-2018, 05:18 PM | #9 |
1148
Rep 2,426
Thanks, that's good to know. I do have one of these trips planned for the future.
BMW CCA 509766 |
Violator4587.50 |
09-27-2018, 05:51 PM | #10 |
Rep 2,194
07-12-2022, 11:24 AM | #11 | |
Rep 26
Conversion to Europe from USA
Thank you. |
07-12-2022, 04:22 PM | #12 | |
Rep 247
https://f30.bimmerpost.com/forums/sh....php?t=1778890 I'm guessing that there's probably some type of coding under HU_NBT for it. |
07-12-2022, 06:10 PM | #13 |
Rep 26
Thank you very for your reply and for sharing!
Your experience with the radio might mean that actually a physical replacement of the radio is not needed probably? I am slowly preparing for my move to Europe. How easy would the switching on the navigation would be with Europe maps? Would there be coding involved or just installing European maps? My vehicle is actually a 2020 X1. Thanks again. |
07-12-2022, 08:34 PM | #14 | |
Rep 247
It seems that you can do it through something like bimmercode. I haven't read of anyone ever needing to physically change out the stereo when making the move overseas. As for the maps, I don't have any experience with that, but you should just be able to just load the European maps on a USB drive and update that way. If you get the maps, I would make sure you have both and just test it, if it works, just reload the us maps after until you make the move. |
07-13-2022, 03:45 PM | #15 | |
Rep 26
The Telematics Unit, if I want it also working in Europe (because of Connected Drive), will be another ordeal. Those units here are related to AT&T and it will not be a matter of just putting another SIM card. For the Navigation maps, do you know how and where I can buy European maps with the code and also how would I get a copy of my currently installed USA maps? Thank you again for being so helpful! Best! |
