07-17-2019, 08:57 AM | #23 |
Rep 2
Battery charging X5M F85
I’ve been charging my X5M F85 for each day for the last 4 days now on Ctek 7.0. Every time set the mode to AGM the charger shows bulk charging, takes >6 hours to get full charge but toggle back to AGM mode it’s starts over. I noticed the recharge icon comes up on the iDrive under coasting or breaking; it never did before. So, hard to find what battery (two batteries in rear) is the problem one. Stop / start rarely worked, no other issues I.e. car starts fine. Thought high temp (close to 50c) here caused the stop / start issues but it’s working now after two days of charging. No expert but believe one of these batteries needs replacing as I can’t hold a charge because of continual charging? Or do I keep charging until the Ctek charger stabilises with a full charge?
11-12-2019, 08:59 PM | #25 |
Rep 21
I have this BMW branded charger that I got with my E46 M3 that plugs into the cigarette outlet. Any thoughts on if this would work on an F85 if plugged into the cigarette outlet by the front cup holders?
11-12-2019, 09:28 PM | #27 |
Rep 21
Are you talking about this one?
11-12-2019, 10:53 PM | #28 |
288
Rep 325
+1 for the Deltran. I've used them on multiple cars for years with no issues and great results. Both M's are sippin' on a charge for the winter.
E92 Alpine 6MT/Premium/Tech/Cold Weather/Enhanced Sound/Extended Leather/ESS 625
Eisenmann Race Black Series/Dinan/Active Autowerke/ Morr VS52/H&R/Arkym Front lip/Arkym Rear diffuser/Blacked out exterior trim/Custom Mirror's/ Performance CF spoiler/Huper Optik 20%/Lux H8/ DD- F85 Donington/Mugello, FI DP, BootMod, KW V3 |
11-13-2019, 07:19 AM | #29 |
Rep 1,391
Using the engine bay terminal, the trickle charge only seems to charge the big battery the secondary batt needs to be directly hook up to charger in the trunk.
I haven't tracked down what the secondary batt is for so maybe that's ok |
11-13-2019, 07:25 AM | #30 | |
Rep 2,411
Drives: E30 M3 Cecotto, F85, G05, G07,
Cigarette lighter charge is not recommended.
BMWM5NYC496.00 |
11-14-2019, 04:44 PM | #32 | ||
Rep 7,477
Also, you may want to check the manual/paperwork because that charger may not work well with AGM & Lithium batteries...it may only work with regular wet cell lead acid batteries.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 11-14-2019 at 04:51 PM.. |
