11-01-2019, 10:17 PM | #1 |
Rep 271
Tank never fills 100%
Anyone else find the pumps always stop short by quite a bit? I was running low the other day where the computer said 15 miles of range left. Filled up and it stopped at 19 gallons. I see this pretty much every time I fill up. I haven't tried setting the fuel pump to fill at the slowest rate...maybe that would work?
11-02-2019, 01:45 PM | #3 |
Rep 199
Same for my F86 except the gauge under the Speedometer isn't full while the actual fuel gauge on the left shows full.
excu6me on Instagram.
OEM X6M Build |
11-02-2019, 06:38 PM | #4 | |
Rep 7,468
That display (under the speedometer) can increase if your range increases due to better MPG. For example, if your daily driving is mostly urban/city...and your avg MPG is say "17 MPG"...but you fill up and start on a long trip that is mostly highway and your MPG goes up to lets say 22 MPG...while you're driving and your MPGs start going higher...your "range' will increase and you will also see that display under the speedometer increase. Again, that display is an approximation of range based on your current avg MPG and amount of fuel in the tank.
11-02-2019, 07:09 PM | #5 | ||
Rep 199
OEM X6M Build |
11-04-2019, 05:18 PM | #6 | |
Rep 7,468
There's also other "range" related things that gauge will show..which again...is not about "fullness" of the tank...but about a visual indication of how far you can drive in miles/kilometers on the amount of gas in the tank and your current avg MPG. By not going all the way to the right on a full tank...it allows for a visual representation of increased range if your MPG changes. For example, if you have a navigation location programmed into the OBC (OnBoard CPU..I'm going back to old BMW lingo ) ...that gauge will place a DOT that indicates the range of fuel needed to make it to your destination. And if you pull up ROUTE INFO (in iDrive)...it can also show you approx where you'll need to refuel...and then you can also look for fuel stations using the POI (points of interest) feature of iDrive:
11-04-2019, 05:21 PM | #7 | ||
Rep 199
OEM X6M Build |
