11-13-2019, 10:03 PM | #1 |
Rep 2,716
Drives: M3
Garage List 2016 BMW X5M [0.00]
08 BMW M3 [0.00] 14 BMW X5 50i - sold [0.00] 09 BMW 335i - Sold [0.00] 09 BMW 328i - Sold [0.00] 07 BMW 328i - Sold [0.00] |
I guess first F15 X5 50i OEM exhaust mod attempt....
So out of boredom I went ahead and cut my OEM muffler open - it's a 50i M sport muffler. It actually sounds good all stock but I wanted a little more sound. I also have e92 m3 with a fulle exhaust and it's a screamer I figured people were doing OEM mod and that sounds great so why not give it a shot...
I ended up cutting it open but got stuck there, if you look at the picture the dead end pipe is 3" wide and it would elbow into the perforated one but that one is 2.5" so after all I ended up packing the fiberglass back in (fiberglass was only in the middle baffle), welding it all shut and it's back on the car... Honestly if I were to replace the 2.5" perforated pipe it would end up being a straight piped muffler... I tried that and used a straight pipes instead of muffler but it was way too much drone and the crackers and pops that you can hear sometimes were pretty bad - sounded like my luxurious X5 was taking a shit while flooring it... I ended up welding the muffler back on and wishing I never started this because I wasted all day just to be back where I started.... oh well. I hope this helps...
12-10-2019, 01:26 PM | #2 |
MR. Rocket
46
Rep 398
Drives: 2010 E92 335i M-Sport
I’ve been searching and wanting to the same to my 50i stock exhaust as well. Really interested to see your result. I’ve had OEM BMW performance exhaust on my N54 335i before and also done PE mod to stock exhaust for comparison and I loved the modified exhaust version more because you get the option of valved exhaust. Only issue I see with the X5 exhaust is that the valve system is a little bit more complex but nothing you can’t modify or alter. This to me is probably the best exhaust setup by far. It’s really aggressive in tone without the boomy and drony exhaust system like the muffler deletes and etc.
But....this setup is very loud with downpipes and by no means subtle without either. I would keep all the resonators for that reason if you go catless or at least an X pipe in place. |
12-10-2019, 01:29 PM | #3 |
MR. Rocket
46
Rep 398
Can you take some more pictures please? Trying to see what perforated pipes to actually replace.
12-10-2019, 08:45 PM | #4 | |
Rep 2,716
Drives: M3
it's hard to alter this since the pipes don't connect and also one is 3 inch and one is 2.5 inch...
12-10-2019, 10:07 PM | #5 |
MR. Rocket
46
Rep 398
Haha never looked at exhaust yet, might need to get under there. Lol
So what you’re saying is this? The perforated pipe that dead ends is 3” and the perforated pipe that connects to a solid stainless steel pipe is 2.5”? Just trying to confirm what to tell the muffler shop to weld together with a solid stainless steel pipe. Might need to do a reducer form a 3” to a 2.5” to make this work. My only concern is now knowing there’s no valve to keep one side closed for the wife and babies. It will be quite loud with this modification, might just go with catless downpipes to enhance the sound instead. |
12-10-2019, 10:10 PM | #6 |
MR. Rocket
46
Rep 398
Unless I can only modify one side to have a straight pipe in the muffler.
12-10-2019, 10:15 PM | #7 |
Rep 1,062
Drives: F15 xDrive50i M-sport
There's an extensive 50i muffler delete thread.
12-10-2019, 11:28 PM | #8 | |
MR. Rocket
46
Rep 398
12-11-2019, 01:45 PM | #9 |
Rep 1,062
Probably because it's easier to cut it off and put something else on. And when we're done playing "zoom-zoom" we can put the muffler and tips back on and bring the car back to stock; you can't easily do that once you've hacked the stock muffler to bits.
12-11-2019, 04:32 PM | #10 | |
Rep 1,354
Drives: 2022 X5 m50i
Also the OEM rear muffler is very heavy.
2022 BMW X5 m50i
2024 MB S63 on order '18 X5 50i / '16 BMW F10 550xi / '13 BMW F10 535i / '07 BMW E64 630i / '03 BMW E65 745i / '95 BMW E34 540i / '89 BMW E30 M3 |
pennsiveguy3552.00 |
12-11-2019, 04:46 PM | #11 | |
MR. Rocket
46
Rep 398
Also, planning to add an X pipe after the resonators to divert some of the air flow. But don’t think extra packing within the muffler is necessary tho. |
Cbozz688.50 |
