11-10-2020, 04:12 PM | #309 |
Rep 296
11-11-2020, 12:25 PM | #310 |
Rep 41
This thread has been really useful, I was finally able to code ambient lighting on my iDrive 6. I will be posting pictures later on today when it gets dark. My only question is, does anyone know the numbers for the 9th colour, I was only able to get the 8th colour [8 color in nbt (sring number 150-158)].
11-18-2020, 11:52 AM | #311 | |
Rep 7
Note that this only changes a single color profile and you must select 'Orange' in iDrive for this to work. |
11-18-2020, 05:40 PM | #312 |
Rep 76
Thanks for the tip, I coded a color but couldn’t figure out why it wouldn’t show up. Selecting orange works!
11-19-2020, 06:25 PM | #313 |
Rep 476
I just did this, pretty simple ... however, now my ambient lights don't turn off unless I lock the car. Anyone else experience this?
OK, the ambient lights turned off …. guess I wasn’t giving it enough time. The Triangle Light on the hazard button stays lit and so is a LED that's part of our car phone charger plugged into the cigarette lighter. Never noticed this before but it could be normal. Last edited by Florida-X3; 11-19-2020 at 06:42 PM.. |
11-22-2020, 03:18 AM | #314 |
Rep 2
Hello Guys
Thank you for this wonderful thread it came in so handy. However, i have a question, my ambient lights are so dim comparing to photos i see here and even before seeing photos I always felt it was very dim despite having the settings all the way up and tried decoupling it from dimmer switch but no luck. Does anyone have the same issue or anyone knows how to crank the brightness up? F15 MY 2018 50i |
11-22-2020, 06:51 AM | #315 | |
Rep 476
11-24-2020, 11:37 PM | #316 |
Rep 2,713
Thanks for the tip, love it!
12-03-2020, 09:03 AM | #318 |
Rep 63
I also just tuned with the mppk. I did receive the updated software with the tune which erased my existing coding. Once I got home, I coded some things again but I feel that the tune is still in place. I really want to update these cool colors next.
12-03-2020, 09:18 AM | #319 |
Rep 74
hey guys im having issues connecting to my vgate icar pro it wont connect to my phone i only see the red light on ... how do i get the bluetooth connectivity light to blink?
12-03-2020, 09:42 AM | #320 | |
Rep 2,713
Thanks! |
12-03-2020, 10:05 AM | #321 | |
Rep 7,522
What are you trying to connect to your vgate icar pro...and WHAT phone? If you're trying to connect the Bimmercode app to your phone...then again, what phone? There are two versions...Android or IOS...and the IOS version connects differently. The BC app site used to have specific/detailed instructions on how to connect to the app when using the IOS version. You don't pair the same way you do with the Android version.
12-03-2020, 01:55 PM | #323 | |
Rep 74
what is the exact proceedure? Turn off Bluetooth from idrive (its an 15' F15) |
12-03-2020, 02:29 PM | #324 | |
Rep 7,522
See the instructions below from the support page from the Bimmercode website ( https://www.bimmercode.app/support/ ). If you're using a bluetooth OBD II adapter and an IOS device...then DON'T try to PAIR your IOS device to the adapter...just OPEN the Bimmercode app and connect to the adapter through the selection in the app.
12-06-2020, 08:18 AM | #325 | |
Rep 74
Hey so i tried this like 10 different times. The car I had in "accessory" or rather 1 push in without the break and then i tried with it just being turned on. I followed all the other steps to a T minus carplay i couldn't disable carplay in the settings on iOS (there was no option) but i had airplane mode on. I also brought the device close to the adapter and noticed red light was on and stable, green light was on and stable and blue light was blinking when i was trying to connect to it. I tried this with the BimmerCode App on my iPhone 11 Pro on iOS 14.2 and i tried it with the BimmerCode app on my girlfriends iPhone 11 on iOS 14.2 and no cigar |
12-07-2020, 10:14 AM | #326 | |
Rep 7,522
Again, with an IOS device...you don't pair the OBD II adapter...you connect to it THROUGH the app. Open the app and look for your OBD II adapter, then select your adapter from inside the app. If it still doesn't work, then contact Bimmercode Support. Connecting with a Bluetooth adapter (iOS)
12-10-2020, 10:07 AM | #327 |
Rep 296
Can anyone else confirm that coding this does not mess up the MPPK tune? I just got it the other week and wanted to ensure that it won't override it for whatever reason when changing the ambient lighting. Thank you!
12-10-2020, 10:19 AM | #328 |
231
Rep 369
That shouldn't mess or override your MPPK, I'm coding my x5 quite often and playing with ambient colours a lot and that never mess with anything or any other coding in my car, you are just changing that specific area, but maybe someone has different experience
Current
2018 F15 M sport x35i Past 2017 GMC Sierra Denali 2017 GMC Yukon Denali 2016 GMC Yukon SLT 2015 GMC Sierra All Terrain |
