      10-17-2020, 03:05 PM   #221
Klienfeld303
Klienfeld303's Avatar
Drives: 2018 x5 M
Originally Posted by 640ijims View Post
My 18' @ 35k is on third set of pads, have been down the chamfering route, "pad lube" ( whatever that is) & as stated three sets of pads( all warrantied). In all the research I've done on this, the trade off can CAN be braking effectiveness. Now, I drive hard, (not crazy as exhibited by gettinG 26k+ out of a set of MPSS's), and I occasionally find myself praying bite BITE dammit & I'm on BMW OEs...just sayin!
I'm in NYC and I drive my shoshanna every day and that brake squawking is kinda wack even tho she does brake pretty well. I was thinking of doing that brembo upgrade upfront just because that noise is killin me but then m rears squeak too. It's lose lose.
ACID.
      10-19-2020, 01:09 PM   #222
Yuille36
Yuille36's Avatar
2015 BMW X5M  [0.00]
Just have the pads changed to Ceramics, and be done with it.
      10-21-2020, 03:30 PM   #223
SupersixM
SupersixM's Avatar
202
Drives: Bmw X6M
Nothing more embarrassing than pulling up at the light and you're the one squealing. All kinds of things is running through people heads at that moment, including yours. As your fellow New Yorker, do like the last guy said and change pads to ceramic and be done with it. Squeal free. Stopping power tad bit less and that jerky brake bite is less but adapt your driving habits and you'll adjust. Not to mention. No more brake dust. And 80% of us are using PowerStop. Good luck.
      10-21-2020, 10:18 PM   #224
Klienfeld303
Drives: 2018 x5 M
Thank you brother man. Appreciate the advice.
ACID.
      10-21-2020, 11:17 PM   #225
sheepwow
Drives: F85
Do you change both front and rear? Mine pads still have ton of life but I dont want the squeal noise anymore. What's the powerstop pad part numbers? Thanks.
      10-22-2020, 07:26 AM   #226
jab23
224
Drives: 2017 X5M
My OEM pads have a lot of life left in them, but I can't take the squeal. Powerstop Z23 front and rear are going on today. Here are the part numbers from my order. Will report back in the thread I started after I bed them in and drive with them for a bit.
POWER STOP Z23919B (Z23-919B) Brake Pad (rear)
POWER STOP Z231738 (Z23-1738) Brake Pad (front)
PAGID 355251731 Brake Pad Wear Sensor (2)
PAGID 355251751 Brake Pad Wear Sensor (2)
      10-22-2020, 02:36 PM   #227
SupersixM
SupersixM's Avatar
202
Drives: Bmw X6M
It all depends on how long you can stand the squeal. From my experience it seemed to squeal more in the winter, so. For the most part all who have changed they pads were because of the squeal and the dust. OEM Pads just had to go lol.
      10-22-2020, 02:45 PM   #228
jab23
224
Drives: 2017 X5M
Cut and paste from my brake thread....
Alright, pads are on. Initial impressions after bedding in are positive. I honestly didn't have a lot of seat time on the stock pads as I've only had my car for a few weeks, but I think these are equivalent in pedal feel. MAYBE a tad less initial bite, but that may be just because of what others have said here making me biased.
Anyway, not a peep out of them so far which was amazing in the stop and go traffic on the way home and pulling into my garage like a ninja. Obviously need to get some miles on them to see if the squeal stays away, but I'm ecstatic so far!
      10-23-2020, 08:26 AM   #229
Yuille36
Yuille36's Avatar
2015 BMW X5M  [0.00]
Good to see a satisfied customer, I'm just waiting for the old rotors and pads to wear out, so I can install all new hardware on my X5M.
      10-23-2020, 11:33 AM   #230
KCTiger
Drives: 2016 X5M
Originally Posted by Yuille36 View Post
Good to see a satisfied customer, I'm just waiting for the old rotors and pads to wear out, so I can install all need hardware on my X5M.
Don't wait lol
      10-31-2020, 12:42 PM   #231
Bobby_Drake
Bobby_Drake's Avatar
390
Drives: '16 X5M
Any consensus on which is the better ceramics : Powerstop vs Hawk?
      10-31-2020, 02:45 PM   #232
JRock80
JRock80's Avatar
456
Drives: 2016 BMW X5M F85
Did you do the install yourself or was it done by local shop? Also, regarding the sensors is it required for those pads? Can we utilize the OEM sensors? I recently had my brakes done by dealer but I can't take the squealing and dust anymore.
2016 BMW X5M F85 | 2019 - Present
2015 BMW X5 F15 5.0i m-sport | 2016-2019
2001 BMW X5 3.0i Sport | 2005 - 2008
      11-01-2020, 07:44 AM   #233
jab23
224
Drives: 2017 X5M
I had my BMW indy do it. I'm guessing it's a pretty stright forward job, but it's been a long time since I've wrenched on a car. He chargered me $400. Pads and sensors were like $180. I would have paid $1k to get rid of the squeal. Still haven't driven more than a few hundred miles, but not a peep out of them and stopping power is great.
Note: You only need one sensor per axle. One of each part number I listed.
Can't speak to using the OEM sensors, but they are cheap, so I'd replace them.
      11-01-2020, 07:53 AM   #234
JRock80
JRock80's Avatar
456
Thanks for the feedback!!! Change is coming!!!
      12-06-2020, 07:00 AM   #235
JRock80
JRock80's Avatar
456
Finally got around to doing the brakes myself. Started with the passenger side - took longer than I wanted. However, the driver side was a breeze after figuring out the correct process.
Also, I was able to do a decent bedding process. 80-20 8 times without coming to a complete stop.
It's been about 2 weeks and I'm very happy I did this! Dust is barely noticeable and squealing GONE.....
      12-13-2020, 09:33 PM   #236
MikeM6
Drives: M6GC, X5M, M3, X7, X5
Which screws did remove to disassemble the front caliper? I've seen people remove the 2 internal Torx screws that pass through the caliper (fasten caliper to mounting bracket), which is a no-no according to TIS, or the 2 external Torx screws that attach the mounting bracket to the steering knuckle (TIS procedure).
Did you use BMW recommended Plastilube on the front pads or something else? Thanks.
      12-13-2020, 10:18 PM   #237
JRock80
JRock80's Avatar
456
11 - External Torx-Bolts
09 - Bracing Spring
06 - Guide Pins
I used the Brake-Pad paste provided by PowerStop.
      12-14-2020, 08:25 PM   #238
Btt335
BETTO
Btt335's Avatar
Drives: BMW f85 X5M-BMW F15
Can you say where do you bought and what is the reference for the pads ?
      12-14-2020, 08:34 PM   #239
JRock80
JRock80's Avatar
456
Power Stop (Z23-919B) Z23 Evolution Sport Brake Pads, Rear https://www.amazon.com/dp/B00O6PVEHS..._uRMLdrAltT6ce
Power Stop Z23-1738,Z23 Daily Driver Front Carbon Fiber ... https://www.amazon.com/dp/B086M7J4DV...UTF8&psc=1
You need only two - 1 for each axle
Hella Pagid 355251731 Disc Brake Pad Wear Sensor An elec... https://www.amazon.com/dp/B01IP984EG...UTF8&psc=1
GODZLLA13.00
      12-15-2020, 06:29 AM   #240
Klienfeld303
Drives: 2018 x5 M
Hyped to do mine. Tired of train sounds at stop signs.
ACID.
      12-21-2020, 11:33 AM   #241
RomeoXantos
Drives: 16 X5M
Power Stop Z23-1738,Z23 Daily Driver Front Carbon Fiber ... https://www.amazon.com/dp/B086M7J4DV...ing=UTF8&psc=1
Hella Pagid 355251731 Disc Brake Pad Wear Sensor An elec... https://www.amazon.com/dp/B01IP984EG...ing=UTF8&psc=1
Thanks for the links. I just got my f85 Saturday and the brakes are already making me not want to drive it. It’s super embarrassing.
      03-31-2021, 08:04 PM   #242
AK M3
Montenegro
15
Drives: E92 M3
Thank you so much for this info!
Just to confirm, these brakes will fit a F86, correct?
