      10-01-2018, 10:49 AM   #1
bms5
Drives: 2010 335d, 2018 540d
F16 X6 Smart Opener question
Has anyone with an X6 with Smart Opener done any e-sys coding?
I’ve retrofitted the sensors, control module to my X5 (BDC module is identical)
so I’m just needing the BDC file to complete the job. There are too many variables to guess at.
Any help is greatly appreciated!
      10-01-2018, 11:04 AM   #2
CatalinP
Drives: BMW X5 F15 2014 3.0xd
You mean Comfort Access?
      10-01-2018, 11:06 AM   #3
bms5
No, Smart Opener is the touchless 'kick to open' for the back hatch.
      10-01-2018, 11:09 AM   #4
CatalinP
If you say so.
      10-01-2018, 11:25 AM   #5
bms5
      10-01-2018, 11:41 AM   #6
perry8912
Drives: bmw x5
Originally Posted by bms5 View Post
So your x5 has this function? I don’t think my msport has it.
      10-01-2018, 11:50 AM   #7
Russmov
Russmov's Avatar
2015 BMW X5  [0.00]
So your x5 has this function? I don't think my msport has it.
Pretty sure it was a retrofit.
2016 BMW X4 xDrive 28i-Sold
2014 Lincoln MKX-Sold
      10-01-2018, 04:05 PM   #8
bms5
This is what I am retrofitting. The hardware is in place; I'm simply needing the coding from an X6 that has it.
      10-01-2018, 07:51 PM   #9
TheUltimateDrivingManiac
Freude am Fahren.
Drives: F15 X5 xDrive35i
CAH_SMART_OPENER_COD_FAHRZEUGTYP = 5e
VAM_SMART_OPENER = activ
Freude am Fahren.
      10-02-2018, 10:15 AM   #10
bms5
Thank you! The '5e' is probably the key one that I needed. I'll get it done today and report back.
      10-02-2018, 01:49 PM   #11
Wasa
Drives: E46 M3 E60 M5 F82 M4 F85 X5M
Where did you get the kit from ?
      10-02-2018, 01:57 PM   #12
bms5
Only 3 separate main parts needed:
61-35-7-391-042 sensor -upper $28. Dealer
61-35-7-391-043 sensor -lower $27. Dealer
61-35-7-422-700 control unit $249. Dealer or used from eBay (my choice)
61-13-2-359-997 connector. Dealer
Wiring:
.35mm Yellow/Green(pin 1), Red(pin 2), and Brown(pin 3)
Pin 1 to LIN Bus for LF mirror and driver's door switch block.
-Soldered into blue/yellow behind LF kickpanel wire leading to pin 42 on connector 258*4B on BDC
I haven't completed the coding and final wiring yet so don't jump on this until I have it completed😊!
      10-02-2018, 02:15 PM   #13
Freude am Fahren.
Wiring:
To do it "OEM Style" you need a new connector for the PDC/Smart Opener and repin PDC to the new one.
61 13 8 387 220 - male
61 13 8 373 632 - female
61 13 0 005 200 - pins male х3
61 13 0 005 201 - pins female х3
Freude am Fahren.
      10-02-2018, 02:16 PM   #14
Freude am Fahren.
As well you need the pins for the ground and fusebox.
61 13 8 377 731 - fuse contact
61 13 1 387 140 - ground contact
Freude am Fahren.
      10-02-2018, 02:19 PM   #15
bms5
Thank you for those connector part numbers. You mention connecting it to the PDC (PMA) module but that doesn't seem to apply for the F15,16 chassis according to the wiring diagrams in ISTA+. Can you clarify, please? Thank you!
      10-02-2018, 04:08 PM   #16
Freude am Fahren.
Nope, you do not connect it to the PMA.
There's a connector under the bumper, which is used to disconnect the PDC sensors from a car when you remove a bumper. It's a 6 pin connector on the F15.
On the F16 PDC + 3 wires from Smart Opener go through this connector. So a 12 pin connector is used instead. You can pretty much ignore it, but if you want to make it "OEM", you have to repin PDC to the new connector + run SO wires through it:
Freude am Fahren.
      10-02-2018, 04:20 PM   #17
Freude am Fahren.
I've promised to to write a DYI on Smart Opener some time ago, but looks like this thread contains all required information, so I'll add something else.
One of the challenges of retrofitting SO on the F15 is to attach sensors to the bumper, as F15 doesn't have clamps for them.
I've used weather resistant cable tie mounts and cable ties. Tie mounts are Panduit ABM1M-AT-M0, I've got them from arrow.com.
You just glue them to the bumper and attach the sensors with the cable ties. I've used 4 per sensor + 2 to attach SO module.
Freude am Fahren.
goate22.00
      10-02-2018, 05:37 PM   #18
bms5
I attached the upper (flat) sensor with contact cement and attached the lower (round) sensor with adhesive backed clips from Lowe's (sorry, I didn't record the part number).
I used two sided tape to attach the module to the bumper and oriented it so the connects were facing downward for natural drainage of the electrical connectors.
      10-02-2018, 05:44 PM   #19
bms5
How did you come up with the necessary coding? I'd messaged some of the E-sys gurus but they weren't able to help.
I'd almost resigned myself to having to add the emulator module that eliminates the need for coding but I REALLY didn't want to do it that way.
      10-02-2018, 06:21 PM   #20
Freude am Fahren.
Looks like your E-sys gurus are not gurus enough
There's a wonderful tool from TokenMaster - NCD / CAFD Tool, which allows you to track what parameters are changed by the different options. So you just plugin F16 instead of F15 and check what parameters are changed in BDC. Easy!
One more thing - closing by kicking motion is not enabled by default, you have to change couple of parameters. One is vam_enable_smart_close in BDC and there's another one I do not remember in HKL, but it's easy to track down.
Freude am Fahren.
      10-02-2018, 06:48 PM   #21
bms5
I have the tool but haven't used it yet. No one I asked could supply the F16 file; how did you find one?
      10-02-2018, 07:12 PM   #22
Freude am Fahren.
You use the same file, just apply a different "type key".
Freude am Fahren.
