06-09-2021, 10:36 AM | #5369 |
Rep 41,104
PM sent.
06-10-2021, 02:43 PM | #5371 |
Rep 41,104
You can use all 3.
06-10-2021, 03:31 PM | #5372 |
Rep 60
Dual Posted because I forgot this thread existed....
Excuse me if this has been covered but I couldn't find it in search. My F15 50i did not come stock with the towing hitch or towing wiring although it says "Preparation For Trailer Tow Hitch" (Code 8SL) in the bimmer.work report. I recently installed a curt hitch and a simple 4 pin wiring harness (forget the brand, non-splice but has sensors over wires) on the car. I added the zoom for trailer hitch in bimmercode but I was wondering if there is a way to add the towing mode that comes with the OEM trailer harness? I think in this mode it changes shift points some and also disables rear PDC and blind spot monitoring while towing. I know this normally activates when a 7 pin connector is plugged into the harness but I believe (not 100% sure on this) it also adds an option to the menu to activate it when something like a bike rack or small trailer is attached as well. Does anybody know how/if this can be coded in (via bimmercode or other) or is only accessible with the OEM harness? Original thread: https://f15.bimmerpost.com/forums/sh...0#post27685190 |
06-11-2021, 10:18 AM | #5373 |
Rep 41
I searched this thread, but I am not finding the answer. Forgive me if this has already been answered...
How do I set the seat ventilation settings to NOT reduce from high to medium after 15 minutes or whatever that threshold is? For heated seats, I understand the value of such programming (prevent the seat from getting too hot), but for ventilated seats, I want them to basically stay on high all the time if I have them on. Mark |
06-11-2021, 11:21 AM | #5374 | |
Rep 125
I 2nd this as well, would be nice to know as I find it a little annoying living in Florida.
06-14-2021, 05:18 PM | #5375 |
Rep 41
nishfish87 ,
I am pretty sure I found it. Still need to verify on a longer drive. In Expert mode with BimmerCode: SMD/P --> 3008 SITZKLIMA --> SKL_ZEIT_ST3_NACH_ST2 Change from "werte_10" to "nicht_aktiv" Enjoy... Mark |
06-15-2021, 01:22 PM | #5376 | |
Rep 35
06-15-2021, 02:47 PM | #5377 | |
Rep 41
Mark |
06-19-2021, 10:05 AM | #5379 |
Rep 41,104
06-21-2021, 04:47 PM | #5382 |
Rep 41
06-21-2021, 04:56 PM | #5383 |
Rep 41,104
That is only a Bluetooth Update. No Coding is affected.
06-21-2021, 05:24 PM | #5384 |
Rep 2,525
What Shawn said, won't remove anything.You will need to re-add your phones for the BT connection, that's it.
07-06-2021, 12:45 PM | #5386 |
Rep 41,104
07-07-2021, 10:58 AM | #5387 |
Rep 34
Does anyone know if I can change my 2017 nbt Evo touch screen from id5 to if 6 or 6 lite without loosing nav?
I did it several years ago through bimmercode and lost all navigation. Could not regain it even using backup and had to get the dealer to restore. I've since coded many things but have been leery of that because of my experience. |
07-07-2021, 11:01 AM | #5388 | |
Rep 41,104
07-12-2021, 06:33 AM | #5390 |
Rep 61
I've have a 2018 X5 that I used Bimmercode on to unlock a few things. I added Video in Motion for example. Can I find something in the code to do full screen Carplay or do I have to buy Easy Bimmer Code's software?
Also, since I enabled Video in Motion, what can I do with it? Do our disc players handle DVDs? Or maybe an MP4 on the USB? Thx, Craig |
