07-30-2020, 11:25 AM | #1 |
Rep 31
DIY oil pan stripped repair
Hey guys!
I know the topic has been discussed here, I've read all of it, But I didn't see anyone managing or trying to rethread the oil pan instead of replacing it ($$$). It looks like an easy DIY to do. Currently, my oil drain does not have a big leak. It doesn't drip, ( I've checked every day where I park the car, no drops on the floor) but when I touch it with my finger, I can see oil on it. So I am not planning to touch it before the next oil drain (in 8000km). Is it a good idea ? Can/should I apply some RTV (adhesive silicon) on the head of the bolt as a temporarily solution? Or should I be concerned that the bolt my unplug itself at some point and my oil drain completely, frying my engine ? So for the next oil drain, I am planning on doing this: 1) Try to remove the current bolt and drain the oil. 2) Rethread the pan with an M14* 1.5 threading tool with grease on it so it catches the aluminium dust created with the drilling. 3) Insert the new m14*1.5 bolt with a crushwasher to check if it sits tight. 4) Put my old oil back and drain it to remove all debris. 5) Re-insert new blot and check if it leaks. Is there anything wrong with this plan, anything else I should consider, any warnings, tips ?? I figured the worst that could happen if I mess with this drain is changing the oil pan for almost 2k at the dealer. So I might as well try to fix it myself. Thank you for your contributions.. I will post the DIY Tutorial with pics when I do it ! |
07-30-2020, 08:49 PM | #3 |
Rep 31
07-31-2020, 09:44 AM | #5 |
Rep 49
oof, ok. I get that, but the aluminum oil pan is soft so by just re-threading you're eventually going to end up in the same situation again.
07-31-2020, 11:04 AM | #7 | |
Rep 31
I'd say it's soft to the point that it can be rethreaded and if you don't torque it like I did in the ifrst place (-_-) no matter how big the thread ( or the rethread), it will just be fine. I hope I am right.. |
