07-13-2020, 06:21 PM | #1 |
Rep 4
xDrive40e - Engine knocking noise
Hey guys, I'm from Cluj, Romania and in February this year I bought a 2016 xDrive40e and realized that if the car sits a lot, like more than 2-3 days (due to the pandemic wasn't using it much), at cold starts it was blowing white oil smoke. Researched a bit on that and discovered that the N20 engine has an issue with the oil feed line to the turbo. The fix is to replace that oil line with a revised one that has a built in check valve. When changed the oil feed line the entire turbo has been removed and when fitted back again a kit for turbo replacement parts like gaskets and o-rings was used.
More details about the problem here: https://bmwtechnician.com/2016/05/13...d-line-update/ The smoke issue is currently fixed, but after getting the car out from the auto-shop and inspecting the engine bay, I was hearing a knocking noise, that I don't recall hearing it before. The guys from the shop inspected all the parts they were touching to be sure everything is put back in place and tried to identify the noise, but they are not sure from where it may come from. The final conclusion was that is some sort of a valve that's hearing and it's normal. Another thing to mention is that if I put the car in Sport the noise it's still there but barely noticeable. When putting back in Comfort or EcoPro the sound is back again. To be honest I don't think it's normal and I'm trying to see if anybody has heard such a knocking in the engine bay that is comparable with what I was recording in this YouTube video: Any help is appreciated. Last edited by Baxy; 07-14-2020 at 03:13 AM.. |
07-13-2020, 08:58 PM | #3 |
1636
Rep 2,995
Does the sound increase with the engine speed? Remove the oil cap while it's running to see if the noise changes. Though you might get a code for doing that.
07-14-2020, 01:14 AM | #4 |
Rep 4
scanido The production date of the car is 02/2016.
turboawd If I rev the engine it only increases the frequency of the knockings, the sound seems the same. If I remove the oil cap the sound is still there. The car has no fault codes, runs perfect, no changes in power. Last edited by Baxy; 07-14-2020 at 03:37 AM.. |
07-14-2020, 10:49 AM | #7 |
Rep 247
I'll take a look at mine with the hood up. The N20 is pretty loud, especially at start. Has a kind of diesel sound due to the direct injection. Does it get any quieter when the engine warms up?
07-14-2020, 02:15 PM | #10 |
Rep 247
I can't tell through the video, but is the knocking sound similar to: ?
Guy there said it was a knocking rod. Usually a knocking rod gets worse as the engine warms up... I hope that's not the case here for you! |
07-14-2020, 03:13 PM | #11 |
Rep 1,179
This sounds really similar to the symptoms when I had my bearing going bad. Only did it while warm and increases when RPM increases. You should bring it to a shop ASAP and they can check for metal shavings in the oil.
03-06-2021, 11:21 AM | #12 |
Rep 2
Hi there. Im from cluj to . Sounds you have 2 type of noise there , 1 metalic wich can it be from chain and 1 very deep wich i have same on my 2011 x6 and i cant figure out what it is . I look on my oil level it is at max but when i start the engine and chek on dash board the oil it seamse its to much , so if you have like me full take out 300 ml and see if works for that deep sound . For the metalic sound when whas the chain change ?
03-21-2021, 03:22 PM | #13 | |
Rep 2,736
12-29-2023, 02:28 PM | #14 |
Rep 126
To add some resolution to this thread:
I recently diagnosed a 2018 40e with 70,000 miles. The knocking/thumping sound was identical to the video above. Very in sync with RPM, very similar to rod knock or wrist pin knock sound. I was certain at multiple points along the way that the car had some sort of internal knock. This knock was resonating through the entire engine, into the cabin. Easily could be mis-diagnosed, and overlooked by a shop. Here is my sound from inside the cabin. Engine bay sounds exactly as the post above if you need reference https://youtube.com/shorts/X1mXS4XmQ...7c8J1SL5UHXzIT It was a failure that is only pertinent to these PHEV vehicles that have a front-side, belt driven starter with a one-way-clutch. The way the PHEV specific N20 works, there is a toothed "traditional" starter motor mounted below the oil filter housing. Oriented "backwards", with a toothed gear protruding out front of the engine. This starter drives the only belt on the front of the engine. It engages the one-way-gear on the crank hub to start the engine. The engine can also be started by the hybrid electric motor in the transmission. These two items allow for a somewhat redundant engine starter setup. This starter is commonly mistaken as some sort of PHEV A/C pump, or PHEV alternator. It's nothing more. This clutch/vibration damper/harmonic balancer combo had failed bearings, allowing for the toothed one-way gear to rattle severely enough to send this vibration through the crankshaft and engine. It was difficult to diagnose until I removed the belt and was able to freely spin the one-way-clutch with my hand. It feels similar to any bad pulley or bearing. In this case, it was easy to get it to rattle by hand, but that may not always be the case. The rubber of the vibration damper component looked perfectly fine, and would have passed any visual inspection like one does with a traditional damper/crank pulley. It should certainly be inspected more often. I imagine this will be a future maintenance item for many. This is a new one for me, and I hope it helps someone out in the future. In this case, the sound was most noticeable when the vehicle had warmed up, after the cold-start high idle and open waste-gate cycle. The sound seemed as if it were coming from the exhaust side of the engine, and at times seemed like it could be at the rear or front of the engine. Hard to pin-point, even with a scope or chassis ears. More prominent around 1500 RPM, even had a nice scary death rattle when the engine was decelerating from a rev in neutral. Again, just like engine knock. Part in question is not cheap. If you'd like to save some time and rule it out, you can temporary remove the belt and replace the crank pulley with the standard one from any N20 or N26. The car will fall back on the hybrid motor to start the engine. Part: 11238651961 Number 2 in the realoem diagram for "Belt drive - starter" https://www.realoem.com/bmw/enUS/sho...diagId=11_5841 |
03-17-2024, 02:35 PM | #15 |
Rep 1
Any update ? https://streamable.com/jb4tyc
For me the same sound, like in the first video. And it's make me angry now. |
