02-13-2021, 09:56 PM | #1 |
Rep 1,025
2018 X5M needs brakes at 18k. Normal?
Like the title says, my ‘18 needs brakes at only 18k miles. Is this normal? That seems way earlier than any car I’ve had before, including many BMWs, X5s, and Ms. And what can I expect?
2017 F-type SVR Black/black
2017 Nissan GTR Red/black 2022 BMW X5M MBB/SO Gone but not forgotten: '12 X5M, '07 AM SuperVantage, '05 Boxster S, '01 BMW M3,... |
02-14-2021, 12:54 AM | #2 |
Rep 199
Are you the original owner? Just asking in case maybe the person before enjoyed a few track days...but in all seriousness that does seem way too early. I'm at 67k miles and just nearing the point where the dealership will swap mine out. Best of my knowledge, the original owner never touched them either.
excu6me on Instagram.
OEM X6M Build |
dom5533.00 |
02-14-2021, 07:51 AM | #3 | |
Rep 1,025
02-14-2021, 08:24 AM | #4 |
Rep 1,006
18,000 miles is way to early for needing brakes. I'm currently at 62,000 and have about 1/4 life left. Have you looked at these massive rotors, they are very robust, and larger than the two-piece rotors on my E63 AMG. And those rotors last up to three sets of pads. And these rotors are thicker. You probably just need a set of pads.
02-14-2021, 11:31 AM | #6 | |
Rep 1,233
Holy smokes...
For comparison, mine has 44K on it and almost needs new rotors and pads. Do you happen to have a BMW extended maintenance plan? If so, check to see if it covers rotors and pads. (My BMW Ultimate Care+ plan covers both) If not, maybe you can get one and have them covered under it? |
02-14-2021, 11:34 AM | #7 |
Rep 592
Drives: 2018 X5M , 14%E2%80%99640i ver
Pm sent
02-14-2021, 08:00 PM | #8 | |
Rep 1,025
02-14-2021, 08:05 PM | #9 |
Rep 1,233
That's a relief!
Is it a CPO? You need to have CPO status to get the best plans.
Either way, might be worth seeing if you can grab a plan that will cover some major items and/or wear and tear items. Having a solid independent shop and/or cool dealer is obviously great too. Good luck! |
02-16-2021, 06:57 AM | #10 |
Rep 1,006
I need to replace my rear rotors and pads soon, the rotor has a visible lip, and the rear pads are thin, and won't pass a safety inspection due in August. Luckily for me, I already have new rotors and ceramic pads just sitting in the corner waiting to be installed.
02-16-2021, 02:19 PM | #11 |
Rep 95
my M6 goes thru back brakes every 15k miles due to traction control. It's user error!
I would think the X5M would probably be better on brakes from traction control issue, but if you have a lead foot (which you should)... then you need to stop that 5400lb monster somehow
2014 M6 Coupe (SG/Silverstone)
2017 X5M (LBBlue/Aragon) 2000 Z3M Roadster (EstB/Black) |
02-16-2021, 02:35 PM | #12 | |
Rep 240
My X5M had all 4 corners replaced at 44k by the dealer on dealers dime.😄 |
02-18-2021, 12:19 PM | #13 |
Rep 1,233
Same here
Literally just under 44K and through a little creative pushing I got the dealer to replace all four corners.
02-21-2021, 06:21 AM | #14 |
Rep 1,006
My shop told me, that they would charge me $500 to install my new pads and rotors. Not bad considering.
02-21-2021, 06:33 AM | #15 |
Rep 1,233
Wow
02-21-2021, 06:38 AM | #16 |
Rep 592
Brakes
Yuille ,is that labor only? 640ijims
02-21-2021, 09:25 AM | #17 | |
Rep 1,339
02-21-2021, 12:55 PM | #18 |
Rep 592
That was the point
02-22-2021, 05:42 AM | #19 |
Rep 1,006
02-22-2021, 05:45 AM | #20 |
Rep 1,006
02-22-2021, 06:55 AM | #21 | |
Rep 1,233
For some reason...
Thanks for the information on the parts costs, that's helpful for the future just in case. |
02-22-2021, 10:54 AM | #22 | ||
Rep 1,339
