02-27-2021, 09:00 AM | #1 |
Rep 1,233
12" Wheel Width
Just curious if anyone has tried a 21" wheel with 12" width on the rear? Or a 21" wheel with 10.5" width on the front? Would this setup work with the Michelin PSS OEM spec tires?
02-27-2021, 10:56 AM | #2 |
Rep 1,340
Blue By You631.00 |
02-27-2021, 12:36 PM | #3 | |
Rep 1,233
Nice
02-27-2021, 01:55 PM | #4 |
Rep 592
Drives: 2018 X5M , 14%E2%80%99640i ver
This tells you the tires are fine on rim, but will everything clear suspension? I would think height would be ok , inside widths might be an issue.. dunno!
Blue By You631.00 |
02-27-2021, 05:09 PM | #5 |
Rep 659
I have 21x11 front 21x13 rear, so as long as he has proper offsets there shouldn't be a problem
Blue By You631.00 |
02-27-2021, 06:39 PM | #6 |
Rep 592
Ah, the answer
Blue By You631.00 |
06-25-2022, 03:20 AM | #7 |
Rep 17
06-25-2022, 06:48 AM | #8 |
Rep 175
I am running 21x11 +32 square with 295/35. No rubbing lock to lock and lowered on H&R VTF.
06-27-2022, 12:44 PM | #11 | |
Rep 1,233
Pictures?
But if I could go wider, and use the (better performing and more readily available?) PS4Ss in summer, I would consider selling my setup and going for it. As long as there was no rubbing at all, I imagine the wider tires would have helped my rig perform better especially at my last track event. I would be looking for aggressive offsets to keep the tires flush or just outside of fender wells like I have it right now. Since my OEM 21" setup is 10" front and 11.5" rear, I would probably run 11" front and 12.5" rear, unless the 13" rear made more sense due to available tire sizes. Because I want the tires to sit square and not be stretched or overhang the wheels too much. If you can provide more details and pictures, that would be great. Last edited by Blue By You; 06-28-2022 at 07:45 PM.. |
06-28-2022, 12:42 PM | #12 | |
Rep 1,336
06-28-2022, 05:29 PM | #13 | |
199
Rep 363
Now I just need to get the VTFs and play with ride height somewhat.
2017 X5 ///M
2019 X3 XDrive 30i 2003 Porsche C4S |
06-28-2022, 07:48 PM | #14 | |
Rep 1,233
Same
I had the Conti Sport (whatever the model) on my old wimpy 2010 Lexus RX350 because of the way I drove. And I swear I would be able to get that thing on two wheels before those tires would ever break traction! |
07-04-2022, 09:34 PM | #15 |
Rep 938
Check my signature, i have 21x12 and 21x11 with stock tires. Looks good
F80 M3-DCT MaxPSI CH, BM3 with F80 Paul E85 and Custom Rom track tune MCS 2Way Remotes
Signature SV104 E46 M3 F85 X5M https://www.instagram.com/fastmacm3/ |
07-28-2022, 09:46 PM | #17 |
Rep 659
07-28-2022, 09:55 PM | #18 |
Rep 1,233
Setup
07-28-2022, 10:06 PM | #19 |
Rep 4,106
m3fuz199.00 |
07-28-2022, 10:29 PM | #20 | |
Rep 1,233
Cool
07-29-2022, 09:12 AM | #21 |
Rep 659
I would say over time I wish the front offset was out a bit further, maybe like 5mm. I'm not rubbing on the front so maybe I should have gone half an inch wider in the front rims
07-29-2022, 11:15 AM | #22 | |
Rep 1,233
Spacers
If I could figure out a setup like yours with the PS4S tires, I might sell my stock 612s and use my current summer setup for winter. Just trade everything up. Let me know if you have any insight or if you know anyone else who has been successful with this exact setup flush to flares minus spacers. Thanks Last edited by Blue By You; 07-29-2022 at 12:22 PM.. |
