03-01-2021, 11:16 AM | #1 |
223
Rep 304
Remote Starter installed on F85
Hey Folks,
I recently had a Viper Smart Start system installed on my F85. There are not commercially available immobilizer bypass modules, so it was a custom and somewhat costly endeavor, but work very well and integrates seamlessly with comfort access and remote take over. I took a video showing the system in action. This does require the use of a spare OEM key which gets installed in the vehicle in a secure relay box ( ie only the remote starter can use it to start the car. I purchased a new spare key from dealer so that adds to cost, but it does not need to be programmed for comfort access. Overall very happy with system and works very quickly, and can be started from anywhere in north america over 4G, along with tracked via GPS. LMK if you have any questions. |
03-01-2021, 11:33 AM | #2 | |
Rep 1,233
Running while open
Does it plug and play with OEM wiring/no cutting or splicing? |
03-01-2021, 01:13 PM | #4 | |
223
Rep 304
Unfortunately its a fully custom install, and the shop wouldn't even tell me what components were used save for the dsm550 smart start module. They are very protective about their solution as they are the only ones that can make this magic work. Keep in mind you need to sacrifice an OEM key. I chose to buy a new one from dealer at wholesale pricing. You only need the key coded to your VIN, but do not need it programmed by dealer for comfort access. It gets installed in the car in a secured box, with a relay antenna, but rest assured it cannot be started manually, only by the system. Costs were as follows in Cdn: Base install: $1000 for base remote start install and 1 way remote fob Smart Start Add on: $350 with lifetime service plan Spare OEM key: $350 wholesale price from dealer |
jab23223.50 |
03-01-2021, 02:09 PM | #5 | |
Rep 1,247
I was looking at the Eurostart - what do you mean when you say "but without the comfort access integration"??? On their site it says that "The vehicles keyless entry and comfort access system remains functional while the vehicle is remote started". I'd be mad to learn that this does not mean what I think it means after I get it! Any insight you have would be greatly appreciated. I'm ok with the engine kill upon entry - not ideal, but I can live with that. I lived with nothing this long! =) Thanks!
03-01-2021, 02:26 PM | #6 | |
223
Rep 304
03-01-2021, 02:35 PM | #7 | |
Rep 1,247
Thanks for the clarification.
03-01-2021, 04:44 PM | #8 | |
Rep 1,233
I love your setup. But I'll suck up the engine shutting off and requiring restart in favor of the plug-and-play plus factory remote. Good luck with everything, looks awesome! |
03-01-2021, 04:48 PM | #9 | |
Rep 1,233
CA
The only drawback is the required restart upon entering. But I was just told by the premier Viper dealer in our area that they do it with their Smart Start systems too. Because, according to them, there is no such thing as a perfectly seamless takeover/clean transfer without recycling the key. Maybe that other place on Canada figured it out. But I'm going with the EuroStart because if all things are created equal with my dealers, it's much better to have a dealer/warranty-friendly/reversable system using the factory remote in my opinion. |
03-02-2021, 08:06 PM | #10 |
Rep 427
Keep us posted please. I’ve been thinking about adding a remote start and was struggling with the lack of options or explanations on the available options
Blue By You631.00 |
03-04-2021, 11:22 PM | #11 |
Rep 24
Do you have battery issues? Had a Viper not your model in my Infiniti and it killed the battery every 4 days if it wasn't driven. Had the system checked 3 times and was told it's normal.
03-05-2021, 09:30 AM | #12 |
223
Rep 304
Not yet, but now that I have remote start, I do start and run the car for 15 mins every day just so it doesn't sit too long.
02-21-2022, 04:33 PM | #13 | |
454
Rep 350
2016 BMW X5M F85 | 2019 - Present
2015 BMW X5 F15 5.0i m-sport | 2016-2019 2001 BMW X5 3.0i Sport | 2005 - 2008 |
02-21-2022, 05:37 PM | #14 | |
Rep 1,233
Battery Drain
If the battery gets low enough, just remote start it if it's not inside of a garage and charge the battery. (Can be started from anywhere you have mobile service) Last edited by Blue By You; 02-21-2022 at 05:44 PM.. |
04-11-2022, 05:37 AM | #17 | |
Rep 11
Did you get the a/c controls to work? Was it totally plug and play? |
04-11-2022, 07:28 AM | #18 | |
Rep 1,233
Eurostart
I should probably use it more considering the amount of money I spent. But I barely use it since I just start, run for about a minute while I get situated, and go. Have not tried to figure out the AC or anything like that. But I'll be finding some time to code my rig soon and I'll add that to the list, thank you for the reminder! |
04-11-2022, 03:35 PM | #19 |
Rep 1,233
I just got a refresher on the system. You can set the heated seats to be activated at a certain outdoor temperature. The system will also use the latest climate controls that were active when the vehicle was shut off. (In addition to the OEM ventilation settings you can use instead if you like)
04-11-2022, 06:59 PM | #21 | |
Rep 1,233
Settings
The run time and climate options are set using the steering wheel. Mine was set by the installer and I just sent an email today asking about the procedure for changing the settings because for the life me I cannot find them online. Basic but pretty cool stuff. I didn't use mine that much if at all this winter. Maybe I'll use it more over the summer. |
