03-07-2021, 08:57 AM | #1 |
Rep 275
Anyone done a CUSTOM exhaust?
Lots of threads on exhaust, but rather than buy an off the shelf option, has anyone taken a stock F85 to a good local exhaust shop and had them modify it? Any feedback? Catback but pick out a nice aftermarket muffler etc. Thinking of going this route.
03-07-2021, 09:36 AM | #2 |
248
Rep 326
I have, in a way.
I took the stock muffler and cut it open. The pipes that go through the muffler are perforated and surrounded by fiberglass mat. I made small pieces of sheet metal and welded them in place to cover up about 75% of the perforations. Then I stuffed the fiberglass back in and TIG welded the muffler back together. I spent a lot of time experimenting with how much to cover inside and this seems to sound the best. It's every bit as good as an aftermarket system. I also added an X Pipe from a C7 Corvette in the mid-pipe. We do this mod on a lot of C6 and C7 Corvettes.
2021 Individual Grigio Telesto Gray Pearl Metallic X5M C, BC Forged, Dinan tuned, Dinan suspension, MAD Downpipes, Dinan Exhaust. More to come.
Owner, Designer, Tuner- A&A Corvette Superchargers WWW.AACORVETTE.COM |
imtheant127.50 |
03-07-2021, 09:41 AM | #3 | ||
Rep 275
03-07-2021, 01:58 PM | #4 |
Rep 647
Find some who TIG welds so it looks cleaner. For me, I am the type of person who hates mismatched aluminum so I stopped getting things done to exhaust unless I bought a full kit. If you want just sound, you can replace things like secondary cats with resonators, stock muffler with a smaller muffler, etc...
For individual parts, I would look at Vibrant. Most custom shops use vibrant parts. Cheaper than magnaflow also. My experience: Had about four different exhaust set ups on my previous M4. |
03-07-2021, 09:19 PM | #6 | |
248
Rep 326
Funnily enough, I just bought a 16 Carbon Black F85 today. I took my modified muffler off the 16 and put an extra stocker that I had on it before I traded it in. The new one already had a Dinan muffler on it. I'm going to swap them back and forth, but my first iimpression is that I like my modified one better. I have Akropovic carbon tips on it so it looks good too.
03-09-2021, 06:14 AM | #7 | |
Builderbloke
16
Rep 20
If you don't look, there are no events. Only probabilities changing.
03-09-2021, 08:43 AM | #8 |
Rep 647
Basis exhaust logic -
Smaller muffler = louder and more drone (where in the RPM range not sure, you would just have to drive around and find out). Having a valved muffler like stock helps as you can close the valves when needed. adding resonators = very minor decrease in DB, but makes sound deeper. removing resonators = slightly louder. same thing as removing secondary cats. usually adds a tiny bit of drone. Removing primary cat aka adding downpipe = Loud AF. valves help when closed. I have been through a ton of exhaust set ups, both custom and purchased. |
