07-09-2019, 01:29 PM | #111 |
Rep 15
07-09-2019, 01:42 PM | #113 | |
Rep 1,449
While the F series started in 2014, the F series X5M and X6M launched in 2015, not 2014 X5M and X6M did not come with run flats from the factory, they came with high performance summers Dealer definitely did whatever they needed to say to sell a car Are you sure you have an F86? Post a few pics on the forum. |
07-09-2019, 02:25 PM | #114 | ||
Rep 2,037
Drives: 2022 X6///M Comp
I thought I was a good person but the way I react when people drive slowly in the left lane would suggest otherwise
07-09-2019, 05:20 PM | #115 | |
676
Rep 1,020
Thanks! |
07-09-2019, 07:42 PM | #116 | |
Rep 15
I think the 335 would be just too wide for my 11" wide rears. That is over 13" of tread, I'd rather keep that around 12" for my new rims. Last edited by JoeMac40; 07-09-2019 at 07:47 PM.. |
07-10-2019, 12:04 AM | #117 | ||
Rep 1,449
No. Try not. Do. Or do not. There is no try.
-Yoda |
07-23-2019, 09:19 AM | #118 |
Rep 2
Winter Woes
Hi,
I know squat about wheels and tires and I've got the 21's on my F85. I put YOKOHAMA Bluearth Winters on last season (285/35R-21 and 325/30R-21) and after three months they started vibrating at speeds over 55mph. I would appreciate any help determining what are my non-OEM winter setup options are. And....I am afraid to ask but are there any all-season wheel/tire options? Thanks! |
07-25-2019, 10:12 AM | #119 | |
Rep 1,449
Visual inspect the tire tread for unevenness, bubbling, or tread issues. Plenty of non-OEM winter options. There are the Yoko Blue Earth that you have and Pirelli Scorpions tires that you can run on 21s. A lot of people go with 20s for winter which are 285/40 square set-up and several brand tires fit those, numerous rims are available for those 20s. No all-season tire for the 21s or 20s in OEM recommended sizes. If you drop front and rears by -10 there are a few, but limited options; however you need to be careful where you live as you may not pass state inspection if you are out of OEM spec. |
07-25-2019, 10:46 AM | #120 | |
Rep 2
Any particular rim options for the 20s that you recommend ? |
07-25-2019, 12:19 PM | #121 | |
Rep 1,449
I'm not endorsing anyone, but there are a few for sale on the forum: https://f15.bimmerpost.com/forums/sh....php?t=1604191 https://f15.bimmerpost.com/forums/sh....php?t=1602659 https://f15.bimmerpost.com/forums/sh....php?t=1596952 |
07-26-2019, 11:40 AM | #122 |
Rep 2,773
Drives: F95 X5MC
Just curious, has anyone installed all-season tires on the stock 21" 612M wheels?
08-08-2019, 11:41 PM | #124 | |
Rep 1,449
What size rims are on the car now?
-Yoda |
08-09-2019, 12:59 AM | #125 | |
199
Rep 351
AwesomeM31634.50 |
08-10-2019, 09:14 AM | #127 | |||||
///M
192
Rep 272
Drives: 2015 F15 X5 50i M Sport
2015 F15 X5 xDrive50i - M Sport - Space Grey Metallic - 21" 612M - Accelera Iota ST68's - Black Dakota - Leather Dash - Poplar Wood - Ceramic - Shawdowline - Anthracite - Adaptive M - Full LED - Executive - DA+ - Surround - HUD - Enhanced BT - Soft Close - B&O - ACC Stop & Go - Multi Contour - 4 Zone Climate - Comfort Seats - Cold Weather - Muffler Delete - Akrapovic Tips - F85 Grille - 35% Tint - BMW All Weather Mats -- Missing DHP, NV, Active Steering, Rear Entertainment, & Cooled Seats
08-11-2019, 05:44 PM | #128 |
Rep 44
Has anyone had problems with 295-30-22 front and 335-25-22 rear? I have Velos rims and had to replace the previous Scorpion Zeros due to poor alignment rubbing the inner edges raw (new used car to me but previous owner had used that size tires for 15-25k miles). However, I replaced with Toyos in same size and soon after the car started pulling left/right under uphill acceleration
Now the car is stranded after dropping power completely (won't go over 50) but no check engine light I'd really like to keep the Velos but do have the stock 21s if absolutely necessary. 285 front is the "proper" size and 295 is 1.3% taller but no one makes 285 + 335 combo, the Scorpions are sold out and I hate runflats anyways |
08-12-2019, 08:35 PM | #129 |
Rep 135
Has anyone heard of these? I'm doing some research on a winter setup and if we have a warm winter I would prefer to use an all season than a dedicated winter setup
https://simpletire.com/delinte-p305-...iABEgLjVPD_BwE |
09-04-2019, 03:45 PM | #130 |
526
Rep 2,822
Drives: X5M F85
Can one increase the diameter equally?
For example; Potentially running 275/40/21 and 315/35/21 = 643.4mm front x 643.65mm rear From stock 285/35/21 and 325/30/21 = 633.15mm front x 630.9mm rear |
09-04-2019, 11:58 PM | #131 | |
Rep 1,449
You should check on a tire calculator site to see the change in rolling diameter to see the percent change, if it's more than 1-2% difference it's not a good idea. You would also need to check to see if that tire spec is recommend to fit on your rim width as well since you are going down in tire width.
-Yoda |
09-05-2019, 10:41 AM | #132 | |
526
Rep 2,822
Drives: X5M F85
Tags |
tire size f85, wheel size, x5m tire, x5m wheel and tire size |
