View Poll Results: Tire Choice... | |||
Continental DWS 06 | 43 | 49.43% | |
Michelin Pilot Sport A/S 3+ | 24 | 27.59% | |
Michelin Premier LTX | 7 | 8.05% | |
Other | 13 | 14.94% | |
Voters: 87. You may not vote on this poll |
02-11-2019, 10:57 AM | #25 |
Rep 11
In a similar situation as the OP, original runflats are done and looking for options. Living outside of Boulder, CO, my plan is to run dedicated winter tires but not sure if I should put them on my current 19" wheels and buy 20" wheels for summers or just another set of 19s. Any suggestions? Is there a big difference in performance between 20" and 19" wheels on a xDrive 35i? Anything else I should be considering?
02-17-2019, 03:13 PM | #26 | |
Rep 781
02-17-2019, 03:47 PM | #27 |
Rep 1,339
I’ve been reading great reviews of the nokian zline AS SUV all season in 255/50/r19. Any one have any experience with it?
02-17-2019, 07:02 PM | #28 | |
Rep 979
So true ..all seasons are no seasons... this forum has an unhealthy obsession with all seasons and oem parts
MODS | KW S/O | HRE P40SC | Akra Evo |ESS Akra Tune | ESS DCT tune | BMC drop in | StopTech Trophies | TMS Pulley | LUX V3 | BE Bearings and BE ARP rod bolts |
TheUltimateDrivingManiac833.50 |
02-19-2019, 09:18 PM | #29 |
Rep 135
Based on my experience, DWS06's are quite impressive. They are very smooth and grip well during summer days. Cornering is good also with these continental tires. The only negative I can say is that they have a tendency to lose their traction a bit in cold weather.
07-13-2019, 08:09 PM | #30 |
Rep 104
Recommend Nokian ZLine Non RTF
I replaced worn Pirelli 255/55R18 with Nokian ZLine on my 2015 non-M X5. A big factor in my decision is the Nokian ZLine web page shows an F15 X5. Very comfortable ride and responsive handling. Never tried them in snow. I have since traded the 2015 X5 for a 2016 M-Sport and will likely switch to Nokian ZLine 255/50R19s when replacing my OEM Pirelli Scorpian Verde RFT.
07-14-2019, 11:08 AM | #31 |
Rep 174
Tire choice for me starts with the temperature range they will operate in. Blizzacks, for example wear very quickly above 40F. Summer tires on the other hand need warmer temps or they can be greasy when asked for too much traction. The next thing I look at is siping, then water channels. On wide for size tires we run hydroplaning can be a problem. Another problem is road crown which can affect the asymmetric tires adversely
For my money Michelin's give me the best balance of traction vs wear. No doubt there are other brands that provide a good balance for others. The run flat tires are a bit noisy but I like the ability to choose where you can stop for a tow. |
07-14-2019, 01:16 PM | #32 | ||
Rep 648
Some people lack updated knowledge and believe that all A/S tires are still crappy, like most used to be a long time ago, despite huge improvements over time. Cheap A/S tires might still crappy, but high performance A/S tires are quite awesome for summer time use, these days. I still recommend dedicated winter only tires, if you deal with snow and ice in the winter, due to their even better grip... The above condom analogy might have had a point 20yrs ago... Time to get with the times, and not live in the past!! The only unhealthy "obsessions" in this "room" is the refusal to read what tire manufactures suggest based on their extensive testing, while acting like it gives one a hard-on talking crap about all A/S tires and being derogatory against people who successfully use them... Also some people have a weak understanding about summers only and minimum temps for them to not turn into one of the shittiest tires they have ever driven on. Cold summer tires and cold weather (not winter, just below 40-45), can be quite unsafe due to the rubber compound being too hard, almost plastic instead of grippy. To make it more understandable for certain people here; Driving on summer tires when it is under 45F, could be compared to using 5 layered condoms at the same time. Might make you believe you are big and mighty, but you won't feel much... Switch to winter tires too early, and you will wear them down a lot faster than you need to. Now, if I raced my X5, or lived in FL, I would use summers only tires. Summers only definitely has their place, and advantages when used properly. However, I live in a 4 season climate, I drive on the streets, and chose to use high performance A/S tires for the summer time. This makes sure I don't have to risk really shitty grip when it dips below 40-45, during some fall nights before I install my dedicated winter tires, or if I switch to summer set up in the spring, and we get a cold snap. It also shortens the season I have to drive with winters only, on dry roads. If you have ever tried to brake hard with summer only tires that are not up to temp yet on a cold day, you will know what I'm talking about. If you don't believe me, how about reading what TireRack.com says about it: https://www.tirerack.com/tires/tiret...jsp?techid=273 Back to the question about what tires to get: My set of 20" Pilot Sport A/S 3's now have a few thousand miles on them, and they handle great, are not noisy, and ride is much better than the stock tires on 19" rims ever was. I have taken a few sweeping turns at high speed and grip is just phenomenal! I have tried breaking hard, and do they ever grab. Grip is good even when breaking hard with a trailer behind. Thus; I have a lot of confidence in these tires. So based on my limited use, and positive experience with Michelin tires in the past, I would highly recommend the Pilot Sport A/S 3's. Though, not until I have a full season of use with them on the X5, will I be able to give proper feedback.. Anyway: TireRack.com is a great resource when it comes to customer reviews. I recommend reading those reviews, before buying any tire! |
Goodfella1032.50 |
07-14-2019, 05:34 PM | #33 |
Freude am Fahren.
834
Rep 1,287
Drives: F15 X5 xDrive35i
If you will spend less time typing the messages to long to read and do some actual stuff, you might be able to afford two good sets of summer and winter tyres.
Freude am Fahren.
07-14-2019, 07:39 PM | #34 | |
Rep 73
Thanks! |
1norseman398.00 |
07-14-2019, 08:25 PM | #35 | |
Rep 648
FYI: I have some awesome 19" Michelin winter tires, and I have some awesome 20" Michelin A/S tires for summer use. Though as I'm sure you already guessed, I had to sell a kidney, so I could afford a second set of tires, rims and TPMS, since I'm just a dirt poor poser driving a BMW my parents bought for me. (OK, sometimes I can say shit that is not based on reality too!) The fact that you make this a question about what I "...might be able to afford...", shows how little you grasp of what I wrote, and how little you know of me... The fact that you claim it is "to(o) long to read" Shows me you don't take the time to actually read things, while I do, and thus I simply know more than you do! My input is here to help others with their decision in buying good tires, you are here spouting an outdated opinion, and provide little of facts to back it up. I humbly suggest you take the time to actually read up on the matter, and then come back to the discussion. |
07-14-2019, 09:14 PM | #36 | |
Freude am Fahren.
834
Rep 1,287
Freude am Fahren.
07-14-2019, 09:30 PM | #37 | |
Rep 73
What would really help users like myself is if you maybe told us what exactly you don't like about AS (grip, noise, etc)? The random dude you're referring too had very good input of why he likes all season tires. Once again, thank you for the input. Regards, |
07-14-2019, 11:04 PM | #38 | |
Schumacher
786
Rep 2,278
Drives: E30 325is,E93 M3,X7M50,F06 M6
Are all seasons the best choice, no dedicated winter/summer is. That being said that is not a choice for everyone, so instead of just knocking A/S help the OP with a choice. For a daily driver a high performance all season is more than enough tire and will last a ton longer. Its an X5 for god sake, its not even an X5M, people act like they are on the ring every weekend with these things. OP you will be fine with either the Michelins or the DWS, buy them and stop overthinking. If you dont like them buy something else when they wear or just sell them.
07-15-2019, 12:53 AM | #39 | |
Rep 648
I might write long posts about this, but I'm trying to help you understand the fault in your logic. I still care, I'm not a quitter... You and I have been sparring about this before, and as you might remember, I have always agreed summer only tires are the best choice for summer time on a summer only car. It's kind of funny though! I used to have the same opinion as you, when it comes to A/S tires. However, as I have learned more about them as they have constantly been improving, my opinion has also evolved... My recommendations are based on dealing with 4 seasons, and I have stated this to you before. You still act like this is a black and white, 2 seasons only situation, and all A/S tires are the same crappy stuff from many years ago, when you started repeating your opinion. So you are missing the point I'm making! Dedicated summer only tires, are great for one of those seasons, and can really suck during two, and will definitely suck during the 4th (winter) Just like I won't recommend using winter tires in the summertime, because the rubber compounds are not made for the heat. I can't recommend using summer time only tires, during the 2 seasons in between summer and winter, because they can be outright dangerous during certain weather conditions. Neither do I recommend driving on winter tires for 8 months of the year. I have brought up a the many reasons for my opinion with explanations, while you are still not backing up your opinion with any data showing why you are right. There is only an assumption from your side, that we should unequivocally believe in your opinion because you have been "repeating" yourself for years. At least I added links to what tirerack.com states, to back up my thoughts on this matter. Did you click the link and read the info in regards to cold temp performance of summer only tires, I provided in a previous reply? Anyhow, using your logic, I believe I would actually have to recommend having 3 sets of tires. Summer only for the summer months. A/S tires for the in between months, and winters for the actual winter months. But who wants to change tires 4 times a year? Thus I have pointed out that huge improvements in tire compound technology, makes high performance A/S tires, a good choice for an X5 to use, during 3 of the seasons. |
07-15-2019, 07:55 PM | #40 | |
Freude am Fahren.
834
Rep 1,287
So what else to discuss here?
Freude am Fahren.
07-15-2019, 08:40 PM | #41 | |
Schumacher
786
Rep 2,278
That being said comparing the AS to Summer stopping, the new AS perform way better than they did, most of them are within a half a car length difference to their summer counterparts. Definitely not as good, but not like a car length plus difference either.
1norseman398.00 |
07-15-2019, 10:24 PM | #42 | |
Rep 648
Do you know that you can decrease your braking distance with lighter wheels, less rotational mass to stop spinning!! Example, the popular 469 wheels weighs around 35-36lbs each, together with tires you are looking at around 70-75lbs. My spun forged wheels are around 15-20% lighter than the 469's, and most of the difference is in the barrel (furthest out part of the rim). This might mitigate the small difference in braking distance between a high performance A/S tire and a summer tire. What else. Well I still agree you have a point with summer tires having better grip in the summer time. To help you with your argument, I suggest you also read up on better wet performance with summer tires vs A/S tires, and not be so focused on just braking distance. Hey, I'm just trying be helpful, and suggest another point you can use to further your case! Still, in the big pictures and in the case of the X5, unless I race and/or drive like a maniac during the summer months, I prefer to have really great traction with A/S tires during the 3 "not winter" seasons, over having slightly better traction in the summer time only. Anyway; From a not "some random dude": https://www.lesschwab.com/article/su...t-for-you.html Some more interesting info: http://www.tuneruniversity.com/blog/...t-people-down/ Last edited by 1norseman; 07-16-2019 at 11:41 AM.. |
07-17-2019, 04:35 PM | #44 |
Rep 625
