03-13-2023, 08:19 AM | #1 |
Rep 17
Used x5m preventive maintenance
Hi all,
After searching for a f15 diesel, I ended up buying a X5M F85 2018 from BMW, 110.000km. Sorry, not sorry. The car comes with a 2 years warranty, but still want the car to survive long. Except from failing bearing rods, I dont come across a lot of problems. But still want to do some preventive maintenance like the gear box fluid and differential fluids. I am wondering what the things are I should consider to chance/replace or monitor over the coming period of time. Thanks for the replies in advance |
03-13-2023, 02:47 PM | #2 | |
Rep 95
03-13-2023, 09:03 PM | #3 |
Rep 76
I found this post that had a great list of things to keep up to date with in terms of F85 maintenance:
https://f15.bimmerpost.com/forums/sh....php?t=1851701 I bought mine with 94k kms on it and have since done all fluids (front/rear diff, transfer case, transmission, coolant, intercooler fluid, power steering, brake fluid) since then as i wasnt 100% sure on its previous service history. Also changed out the rear air bags + compressor (the bags are prone to failure on these with around the same Kms) and front/rear pads changed to Powerstops as the OEM were squealing horribly) Been running great. Plan on doing oil changes myself every 5k kms with LM 5w40. |
03-14-2023, 12:38 PM | #4 |
Rep 17
Thanks for the replies. Planning on doing the above stated things coming month.
As I have a 2 years warrenty, I am not sure if I can do “oil changes” etc myself. So will do all these things at BMW, so far they gave an approximate of 1200€ for front-rear differential and the gear box. The brake fluid was changed yesterday as the car gave the message it is due. Regarding the remaining, the car was owned 2 years before by the owner of the BMW dealer itself, so guess maintenance is done properly Also Good to know which Oil you use, as I read a lot of different opinions . |
