12-08-2020, 07:00 PM | #133 |
Rep 1,066
Drives: 2015 X5 50i M Sport
2 hour job. My dealer wanted $350+tax. I laughed and asked for oil change only.
2019 Cayenne Turbo
S1nner126.00 |
02-11-2021, 10:58 PM | #135 | |
Rep 1,179
03-08-2021, 02:26 PM | #136 |
Rep 24
Just curious, what's the part number on the NGK spark plugs? Dealer quoted me these spark plugs and I am unsure which to buy as I'm going to change them myself. Thanks in advance.
05-26-2021, 03:47 PM | #137 |
Rep 60
im looking at getting a new set of plugs for my 50i as well and found these on FCP (https://www.fcpeuro.com/products/bmw...sch-0242145541) they say they are gapped to 0.8mm (says thats OEM) but that seems large compared to what people have been saying in this thread. What should the gap be for a stock 50i TU engine? Also, is there a better plug to buy for this engine other than the ones I linked above?
05-26-2021, 05:56 PM | #138 | |
Rep 1,066
https://www.fcpeuro.com/products/bmw...plug-ngk-96987
2019 Cayenne Turbo
05-26-2021, 05:57 PM | #139 | |
Rep 1,066
2019 Cayenne Turbo
06-01-2021, 10:21 PM | #140 | ||
Rep 60
06-02-2021, 07:59 AM | #141 |
Rep 1,066
Stick to the stock gap if it's not tuned.
2019 Cayenne Turbo
Mikegfx437.00 |
06-25-2021, 11:09 AM | #142 |
Rep 77
Stage 2 off-the-shelf tune put down 487 whp and 573 tq. I didn't know to put it in roller mode and thought the dyno operator knew to do so, so we only got one good run with the time I paid for. |
classic_erik2808.50 |
06-25-2021, 02:31 PM | #143 |
Rep 1,066
Saw your post on BM3 Facebook page.
2019 Cayenne Turbo
08-25-2021, 11:00 AM | #144 |
Rep 16
Helpful, but few things I learned along the way
This was a really helpful DIY and learned a lot along the way, but there are a few things in here that are missing because of the mistakes I made. I'm still thankful I did it myself, bc the Dealer in Houston wanted to charge me $363.66, of which $207.62 was spark plugs. I picked those up from FCP for $50. Below are a few things to watch.
-Driver side coil removal. Because it's tucked back so close to the firewall it's hard to get enough leverage to pull it out. I accidently broke the clip off. I was able to order a replacement clip from FCP that's labeled as "BMW Ignition Coil Locking Mechanism 12131437986." After putting on the new clip, use the same extension to slide through the clip, but this time use a long screwdriver and place on the metal bracket just above the coil. I used that as leverage and got a smooth upward pull without breaking the clip -Pay attention to the spark plug socket with a rubber gasket on the inside of it. Of course it helped pull the plugs out, but I didn't realize the rubber gasket stayed on one of the spark plugs after putting it into the cylinder. Trying to pull it out proved to be difficult and rubber particles broke off. Was able to back out the plug and then used my vacuum cleaner hose to pull out the broken particles. If you're using a nonmagnetic spark plug socket, always make sure to use the rubber gasket when pulling the plugs out, but have no rubber gasket in the socket when putting the plugs in. -I also found it helpful to have an extendable magnetic reacher to pull the plugs out and put the plugs in. Helps with not dropping the spark plugs in the engine bay. Hope this info helps with anyone else trying to DIY. The OP DIY instructions are really helpful and this wasn't too challenging when you have the right tools. |
10-13-2021, 10:58 AM | #145 |
Rep 60
So I've had a sort of shudder under medium acceleration since I bought my 50i. This seems a bit worse in very hot weather but it happens most times, it's not severe but can be felt the rpm doesn't fluctuate at all when this happens, just feels like I'm running over some bumps sort of. No warning lights or codes at all.
I recently swapped the plugs thinking it might be an intermittent miss and it might have gotten slightly better but not gone. most plugs looked good to me, driver side rear plug was pretty carbon covered, actually had a carbon bridge between the electrode and ground, the passenger side rear looked oddly clean when compare to the rest of them as well. Are coils the next thing to do or am I looking in the wrong place? |
10-13-2021, 12:01 PM | #146 | |
*Rollin 3rd*
106
Rep 1,232
10-14-2021, 12:08 PM | #147 | |
Rep 7,160
10-14-2021, 12:25 PM | #148 | ||||
227
Rep 338
10-16-2021, 05:29 PM | #149 |
Rep 26
Is this the correct Eldor coil for 2016 x6 50i with the n63tu engine?
https://www.fcpeuro.com/products/bmw...657273#reviews All websites (ecs, turner, fcp) say it's incompatible. The only ones it finds compatible are Bosch brand. Also, what NGK spark plugs will work? Car is stock. |
10-16-2021, 05:57 PM | #150 | ||
Rep 12
10-19-2021, 05:02 PM | #153 | |||
Rep 7,160
N7_Prolific0.00 |
10-22-2021, 11:33 AM | #154 | ||||
Rep 12
