10-30-2021, 03:49 PM | #5457 | |
Rep 40,829
10-30-2021, 05:27 PM | #5458 | |
Rep 14
Any chance someone can post a screenshot of CAFD_000040F9_013_004_026.ncd loaded on properly launched eSys, where the descriptions are available? I might be able to find my way with that... |
10-30-2021, 05:34 PM | #5459 | |
Rep 40,829
10-30-2021, 05:57 PM | #5460 |
Rep 14
Thanks, but I only need these ones:
10-30-2021, 07:22 PM | #5461 |
Rep 40,829
They aren't all in a row in CAFD.
C_FLA_COUNTRY_WITH_MULTIPLE_REFLECTORS: Kommentar=When active (value=01), enables additional algorithms for better differentiation between strong reflecting objects and traffic participants Coding values: 0 = Inactive (default) 1 = Active COUNTRY_VARIATION: Kommentar=description: region / country for which the system is configured. interpretation: country specific value values: 1 = ECE 2 = Golfregion 3 = USA 4 = CANADA 5 = rest of world 6 = Japan / China C_FLA_BS_ENTER_THRESH: Kommentar=The entrace threshold for the Bright Scene decision (AML) C_FLA_BS_EXIT_THRESH C_FLKommentar=Hysteresis for the parameter BS_ENTER_THRESHA_BS_EXIT_THRESH C_FLA_CC_MESSAGE_3: Kommentar=activation/deactivation of CC-message on sensitivity change. (ID: 377) Coding values: 0 = no CC-message (default) 1 = CC-message active C_FLA_US_SENSITIVITY_MODE: Kommentar=When active (value=01), allows the car user to toggle between normal and US-specific camera sensitivityfor the detection of traffic participants. Depends on the country information of the "Fahrzeugauftrag". Coding values: 0 = Normal (default) 1 = US
10-30-2021, 08:46 PM | #5462 | |
Rep 14
10-30-2021, 08:49 PM | #5463 |
Rep 40,829
11-01-2021, 05:26 PM | #5465 |
Rep 3
kafas and hkfm
I'm doing some coding and I was going by the cheat sheet. It references cadf named hkfm and kafas but I only have hkfm2 and kafas2 and none of the function values appear under there the same as listed in the cheat sheet. am I missing something? today was my first time e-sys coding.
I have launcher pro 2.8.2.162 e-sys 3.27.1 psdz file was 18 I think, I just used the versions in the guide I found on the forum and the psdz file was newer than my istep which it said was good to go |
11-03-2021, 03:44 PM | #5467 |
"Salud"
13905
Rep 4,680
Drives: F01 & F15 / Mineral White
Can the open door and proximity gong/chime be coded Off or Low even when radio volume is up/loud? 🤔
I own a X5 M50i with B&O stereo. Very obnoxious feature that needs to be fixed.... |
11-03-2021, 04:35 PM | #5468 |
Rep 40,829
PM sent.
11-03-2021, 07:44 PM | #5470 | |
Rep 40,829
UPDATE: 06/20/2020 - Uninstall the old version, download and reinstall the new, repackaged version and the updated BFU_XODE.EST Links are there: http://tokenmaster.blogspot.com/2019...r-pro-282.html
Javila43.50 |
11-04-2021, 08:16 AM | #5471 |
Rep 7,494
Yes (at least on the HK audio system)...the VOLUME of the warning gong & PDC (beeps) both can be lowered/raised in iDrive...it's found in SETTINGS ---> TONE ---> VOLUME SETTINGS ...you can then adjust the PDC (beeps) to your liking as well as the GONG.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 11-04-2021 at 08:24 AM.. |
Seattlesquash900.50 |
11-11-2021, 10:57 PM | #5472 |
Rep 25
Hi guys,
I'm just wondering if anyone has figured out how to set a default Edrive mode? My car currently always starts in max edrive, but I want it to start in auto edrive mode. Thanks |
11-27-2021, 04:40 AM | #5475 |
151
Rep 349
I am using a pre-configured hdd and attempting to code my wife's '18 F15.
I was able to use E-Sys once and Activate the FA. I did backups and attempted to code one module. It will not allow me to Activate the FA, now. This is the error I get: Here is the E-Sys about box: Am I too outdated? I do not understand why I was allowed to Activate the FA once, but not again? Thanks in Advance for the help! |
11-27-2021, 11:34 AM | #5477 | |
Rep 40,829
11-27-2021, 11:36 AM | #5478 | |
Rep 40,829
