      12-14-2016, 03:13 AM   #1
ThunderTiger0806
Drives: bmw x5
F15 RDC Retrofit
hi guys
just want to make RDC retrofit on my 16 x5, which dosen't have 2VB on the list but i been told i only need put 4 sensors into each tyre, and then coding will make it working, is that true? do i need some thing like module or reciever?
thanks
      01-24-2017, 11:21 PM   #2
bms5
Drives: 2010 335d, 2018 540d
Originally Posted by ThunderTiger0806 View Post
hi guys
thanks
I just finished retrofitting 2VB (RDC) on my 2015 X5 35d (Canadian market model with ONLY FTM).
You are correct; simply install the 4 sensors in the wheels, add 2VB to your FA and then VO code the BDC, HU_NBT, DSC and Kombi and it works great!
JISIPO15.50
      11-07-2017, 07:36 PM   #3
TheUltimateDrivingManiac
Freude am Fahren.
Drives: F15 X5 xDrive35i
No antenas or RDC module needed?
I was too lazy to deal with all that wiring, but if it's just wheel sensors - I will do it!
Freude am Fahren.
      11-07-2017, 08:08 PM   #4
Gabrola
Gabrola's Avatar
191
Drives: 340i
Yes! I'm not sure when exactly, but around 2014 they integrated the antenna into the DSC module as standard, eliminating the need for a separate RDC module. So even cars without 2VB will have the antenna ready.
      11-07-2017, 08:39 PM   #5
Freude am Fahren.
Thanks! That's awesome!
Freude am Fahren.
      11-09-2017, 04:42 PM   #6
sky82
Drives: 2007 E92 335i/2014 F15 X5 35D
possible to get a link to the parts to buy for this? thanks
      11-09-2017, 04:50 PM   #7
Freude am Fahren.
All you need are 4 TPMS sensors for your wheels, part number 36 10 6 881 890. You can get them from a dealer or check amazon, ebay, etc.
Freude am Fahren.
      11-09-2017, 05:32 PM   #8
sky82
awesome thanks!
so this will give actually pressure and temp.
after coding of course and getting the tpms part 36 10 6 881 890
as i also have a canadian x5 f15 2014 diesel
      11-09-2017, 08:53 PM   #9
Go check out my website or my vendor listing.
Don't go with OEM VDO, they have bad design on the Valve stem.
It will either leak or came loose easily.
      03-11-2018, 09:56 AM   #10
kariem
Egypt
4
Drives: 2018 X5 x50i M Kit
Thumbs up TPMS fitted to 18 X5 (1)
Hi guys,
I'm Kareem from Egypt, had my '18 X5 i50 for a month now, my first BMW, so far everything is smooth, very nice ride, a bit firm on pot holes and we have alot of them here.
I decided to start coding since apparently it unlocks the secrets of German engineering ! I tried at first with Bimmercode android app since I'm clueless with regards to coding and it was very easy, just check the options you want and hit code. And if things go wrong there's a restore backup option.
Most of the options worked "rear DRL's, handle leds on with reverse, start in Eco Mode,....)
The thing with BMW cars purchased from Egypt, is that the are assembled in Egypt but all parts are imported from USA, even under the Assembly Country Vehicle Profile it says USA ! The fun part is that it comes with European specs, mirrors fold on close with fob, fog lights can be activated with HB, trunk can be opened and closed from inside or fob, fob has only 3 buttons, all factory, there's an entry under Vehicle Profile #[17]Type...[155]ECE " I'm assuming this's the EU spec option ?
      03-11-2018, 10:26 AM   #11
kariem
Egypt
4
TPMS fitted to 18 X5 (2)
So I decided I was ready to code after reading about it for sometime, but reading is never like practise. Anyway, I found that you can enable the display of Temp and Pressure under car settings, I coded that with Bimmerapp and I did get 4 green tires with dashes next to each one "no readings" !!
So after extensive research found that there are two types of systems, one that uses ABS sensors to measure rotational speed of tires and one that uses actual sensors inside the tires, how do I find which one I have, check the stems, rubber is the run flat warning using ABS, metal is the TPMS.
Found that I have the rubber one even though as I read on US production models it's standard from '14 as I read and this's a US production !
Any way so it's time for my first retrofit
Searched online for appropriate TPMS and found alot OEM and aftermarket, decided to go with VDO oem part#S180052056H or SE52056 from *********.
Eventhough I wasn't sure if the car has the required receivers or if it needed a module installation since on older cars they had to add it, but I read on an an f30 that HU_NBT units had the module already built in but still no way to be sure !
As soon as the sensors were delivered I added 2VB to FA, went to the tire shop, removed the rubber stems, fitted the sensors and drove of waiting for the numbers to pop up...nothing ! All I got was measuring tire pressure and no progress indicator or anything
Back to the posts, after extensive reading found that some additional coding is needed to activate the TPMS under 4 modules "Kombi,HU_NBT,Body and DSC"
At first I had VO coded 3 of them only so it was still not operational, once VO code all 4 ECU's reset the sensor from car screen and start driving ,it was ON
JISIPO15.50
      03-11-2018, 10:42 AM   #12
kariem
Egypt
4
Thumbs up TPMS fitted to 18 X5 (3)
In a nutshell, to activate tire pressure and temperature in a car that doesn't have the sensors you would the following :
Hardware
1- Order TPMS sensors part#S180052056H or similar
Software
1-Add 2VB to FA
2-VO code BDC_Body,DSC2,HU_NBT,DKOMBI
Thanks for bms5 for the correct steps
      03-13-2018, 08:44 AM   #13
Freude am Fahren.
All F15s are build in the USA even for the European market. Even the ones from Egypt factory - they receive the kits from the US factory and make final assembly.
Freude am Fahren.
      04-21-2018, 05:07 PM   #14
Vinegret
Drives: X5 f15
Hello, guys.
I am newer in coding. Can somebody explain by steps how to activate TPMS for bmw x5 f15 please?
I appreciate.
      04-21-2018, 10:28 PM   #15
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Originally Posted by Vinegret View Post
Hello, guys.
I appreciate.
Welcome! It's in the coding threads. Please start by searching there.
'06 C55 AMG (sold)
'14 X5 50i (wife’s now)
      02-19-2019, 09:33 AM   #16
kfchai
Drives: X5
Hardware
Software
1-Add 2VB to FA
hi, can i know which part inside thise vocode need to code ?
      02-19-2019, 10:57 AM   #17
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Hardware
Software
1-Add 2VB to FA
Refer to the coding thread for coding questions. Lots of answers there
'06 C55 AMG (sold)
      02-19-2019, 02:57 PM   #18
You just quoted the steps.
      01-17-2021, 02:04 PM   #19
JISIPO
JISIPO's Avatar
Nicaragua
16
Drives: 2017 BMW X5 Xdrive 35i
Hello Kariem! i have the same issue you had! Help!
Hello! Purchased the valves with pressure sensors, used Carly for BMW app, and nothing, only the dashes (-) on pressure and temp.
When you refer to the Bimmerapp, which app is that? Bimmercode??
      01-17-2021, 02:10 PM   #20
charles.soori
Drives: 2016 F85 x5m
I dont think Carly can do vo code. You might have to manually code them but it will be easy to just setup esys and vo code
JISIPO15.50
      01-17-2021, 03:57 PM   #21
JISIPO
JISIPO's Avatar
Nicaragua
16
Software for coding
Hello! What software did you use for coding? I want to do exactly that!
Thank you very much in advance!
Jinnah
      01-17-2021, 09:50 PM   #22
RED_Y_
Drives: 2014 X5 3.5d
Jinnah
E-sys
JISIPO15.50
