04-02-2021, 06:03 AM | #23 |
Rep 74
2013 f15 tpms
How can I check what is missing (hardware) for a 2013 X5 (F15)? FA is without 2VB - I can add it and VO code but I am just wondering if I need some additionl unit (RDC) to be mounted or is it already part of the DSC unit as on newer model. Sensors mounted on wheels but cant found all the codings needed in the CAF files below. Not sure if VO code would work in this case. Any idea?
found in BDC_BODY - coded FEM_01 > RemoteControl 30D0 > RC_RDC_ENABLE = aktiv not found in ICM or ICM-V ICMQL > Daten 3000 > IcmKod_B_S2VBA = verbaut settings not found in DSC2 DSC_CT02M > DSC_CODIERDATEN_ALLGEMEIN 3000 > C_Funktion_RDCi_l = aktiv DSC_CT02M > DSC_CODIERDATEN_ALLGEMEIN 3000 > C_Funktion_RPA_e = nicht_aktiv DSC_CT02M > DSC_CODIERDATEN_RPA_CONTI 3002 > C_RPA_Extra = nicht_aktiv coded HU_NBT > EXBOX 3001 > RDC = aktiv HU_NBT > EXBOX 3001 > RDC_DRUCK_TEMP = nicht_aktiv [Default] HU_NBT > EXBOX 3001 > RDC_FORTSCHRITTSANZEIGE = nicht_aktiv [Default] HU_NBT > EXBOX 3001 > REIFENUEBERWACHUNG_RDC_RPA = rdc HU_NBT > EXBOX 3001 > RPA = nicht_aktiv coded - but error appeared (probably due to the ICM not coded) KOMBI L7_MID > ERM_Konfiguration 3004 > ST_TYR_RDC_ALIVE = aktiv KOMBI L7_MID > ERM_Konfiguration 3004 > ST_TYR_RDC_TIMEOUT = aktiv KOMBI L7_MID > FZG_Ausstattung 3003 > DSC_MIT_RPA = ohne_RPA [Default] |
04-04-2021, 04:50 AM | #25 |
Rep 74
04-04-2021, 12:15 PM | #27 |
Rep 2,511
VO coding is not going to damage anything, if you code it and it doesn't work just simply remove it and code the same modules again. You are overthinking the process.
04-04-2021, 04:09 PM | #28 |
Rep 74
Friends car, he had some coding done using bimmercode already, I did not wanted to overwrite his coding by injecting VO default CAF files there - that is why I attempted FDL coding. Anyway, thanks for hints - will do a backup and then VO code to see if the TPMS starts reading. If not, I will revert to his old coding from the backup.
04-09-2021, 01:53 PM | #29 |
Rep 74
06-09-2021, 03:51 AM | #30 | |
Rep 21
My car has the standard FTM/RPA (flat tire monitoring) system that uses the ABS wheel speed sensor system, with no SA2VB option listed in my VIN Decoding, and the only "FA" from your earlier conversation that I can see listed in my VIN Decoding is the following: S2VFA Adaptive M chassis. Very keen to see if there's anything I can do to have TPMS in my car without having to fit a lot of new additional systems and controllers etc. Thanks.
2014 BMW X5 30D M Sport 7 Seater - Silver (Current)
2014 BMW 640D M Sport Coupe - White (Current) 2016 VW Golf R DSG 5 Door - Red (Current) 2011 BMW 330D M Sport Touring Auto - Silver Grey (Previous) 2011 BMW X5 30D M Sport Silver Grey (Previous) |
06-09-2021, 10:30 AM | #31 | |
Rep 2,511
06-09-2021, 11:47 AM | #32 |
Rep 166
I can confirm. My '14 vehicle didn't have TPMS. Figured I'd try it so fitted valves (from eBay), coded and now have fully working TPMS. Hope this reassures you
07-27-2022, 01:27 PM | #33 |
Rep 6
After several attempts, I finally managed to enable the TPMS on my 2015 X5 x35d. And yes, it's that simple, just
Add 2VB to FA first and then VO code BDC_Body,DSC2,HU_NBT,DKOMBI (The key is to choose the folder and code) Thanks for sharing the useful tips. |
04-26-2023, 09:27 AM | #35 |
Rep 157
Sorry to revive an old thread.
I went through all these steps to switch my 2015 X5 35d from FTM to TPMS but am not getting any readings. After a reset it stays at 0% until it gives a TPM fault. Once I got it to count up (very slowly) to 49% but it stopped there. Could the issue be that I harvested the TPMS sensors from a set of winter wheels we were using on a G01 (2018 X3). Are these sensors not compatible with my 2015 X5? They both are 433 Mhz.... |
04-26-2023, 11:36 AM | #36 | |
Rep 2,511
04-26-2023, 12:48 PM | #37 |
Rep 157
Ordered a new set of OEM sensors from eBay for $138…. Shipping from Slovakia, so will take a couple of weeks to get here.. but the price was better than anything local.. will see if these sensors behave better. Unfortunately I likely need to make this FTM to TPMS switch to import my car into the US, which doesn’t seem to allow indirect TPMS anymore.
04-26-2023, 05:12 PM | #38 |
Freude am Fahren.
835
Rep 1,287
Drives: F15 X5 xDrive35i
F and G series use different sensors.
Freude am Fahren.
04-26-2023, 05:32 PM | #39 | |
Rep 7,488
I informed the tire installer that the wheels didn’t require sensors….and they never batted an eye…installed new valve stems & mounted the new tires on the old wheels. Performed the simple iDrive reset…all 4 wheels showed green…all good/no problems. Not saying you don’t need the TPM system…just putting it out there that it doesn’t appear to be an issue for import and probably the indirect (RPA/FTM) or direct (RDC/TPM) system will meet approval.
07-04-2023, 08:12 AM | #40 |
Rep 113
Drives: X63.0D, 911C4S
Following this thread. What is correct PN for ‘18 F16 (or freq is it 433mhz) since you say they use different tpms?
I want to switch from run flat to tpms and will be in US in two weeks to pick them up. Thanks Last edited by rmacgurn; 07-04-2023 at 03:43 PM.. |
07-26-2023, 10:49 AM | #41 |
Freude am Fahren.
835
Rep 1,287
what's your vin? last 7 digits?
Freude am Fahren.
07-29-2023, 01:51 PM | #42 |
Rep 113
07-29-2023, 01:54 PM | #44 |
Rep 113
