01-09-2024, 10:50 PM | #45 |
Remove Before Flight
6869
Rep 1,615
"Sparky" or the "Electric Jet".
I forgot that one, so I edited the list. The name came about because when it was first introduced it had a tendency to burn up battery boxes and catch on fire. R.
Current: M2C, Miata RF-GT, RDX & Element // R1200GS & VRSCF
Previous: M3, Focus ZX3-S2, Superchaged Solara, Samurai, Integra, Pinto & RX-4 // VRSCR, R6S, FZ1 & FZ600 |
01-09-2024, 11:00 PM | #46 | |
Rep 3,506
Knowing the academic and scientific background of my friend, and after having heard the little bit of the specifics of the issue he was able to share, I was surprised to learn his team couldn't nail it down better than that.
2017 M240i: 23.8K, 28.9 mpg, MT, Sunroof Delete, 3,432#, EB, Leather, Driving Assistance Package, Heated Front Seats | Sold: E12 530i, E24 M635CSi, E39 520i, E30 325is, E36 M3 (2)
TC Kline Coilovers; H&R Front Bar; Wavetrac; Al Subframe Bushings; 18X9/9˝ ARC-8s; 255/35-18 PS4S (4); Dinan Elite V2 & CAI; MPerf Orange BBK; Schroth Quick Fit Pro; GTechniq Crystal Serum Ultra Ceramic; Suntek PPF |
flybigjet6868.50 |
01-10-2024, 04:05 AM | #47 | |
Moderator
29655
Rep 13,138
///M is art ↔ Artemis
01-10-2024, 12:32 PM | #48 | |
6869
Rep 1,615
Bonus Trivia: The shortest distance between two points (e.g. Newark to San Diego) is NOT a straight line. You have to consider Great Circle (distance measured on a sphere) as well as winds and weather. Winds in the US usually blow generally W to E-- so even though you might spend more time flying a longer distance out of the wind, you'll save gas rather than going directly into the wind-- it's sort of counter-intuitive, but that's how it works. That's why on a winter East to West coast flight, you might find yourself over the Dakota's instead of down near Colorado. 2. Pretty much the only jets that have dump capability are the big ones-- 747, 777, 787, etc. The smaller 737 & 320 types don't have the capability, as you noted. 3. Maximum landing weight is what Boeing has called a "Bought Weight"; i.e. you can buy the data for a higher landing gross weight-- it only costs money. Realistically, if you can take off, you can land (assuming available runway). You have an overweight checklist, but it pretty much says to just watch your sink rate and to write it up for maintenance. The maintenance guys will take about 1-1.5 hours to do a check of the aircraft-- it's honestly not a big event. 3a. FAR's (which govern pretty much everything in aviation) require that the aircraft can safely land at 10 feet per second (Ow!) at max landing weight and 6 feet per second at max takeoff weight. A normal landing is around 1-2 feet per second. So, as long as you keep your sink rate AT TOUCHDOWN less than 3-400 feet per minute, it's a non-event as far as the aircraft is concerned. 4b. Runway available on an emergency return is usually not a problem for the Guppy; in the 737 world, there really aren't that many runways that are short and sketchy-- as in a handful. And most of them are fairly close to great big ones-- an example is John Wayne/Santa Ana. It's got a 5700' runway. Would I emergency return there above max landing weight? No-- not unless I was on fire, I couldn't put it out, and I had no other options. Instead, there's about 12,000' of runway 36 miles away that I'd aim for (I'm looking at you, LAX). 4. I this situation, I wouldn't dump (even if I could) or Hold (delay) to get down to maximum landing weight-- for all I know up in the cockpit, the tail may be about to fall off. As well, I have a bunch of very scared, very cold and very windblown passengers back there-- get the jet on the ground as soon as you safely can, but don't be stupid-- in other words, take the time to run your checklists, make sure everything you can do has been done, and be ready to successfully fly the approach and landing. R.
Previous: M3, Focus ZX3-S2, Superchaged Solara, Samurai, Integra, Pinto & RX-4 // VRSCR, R6S, FZ1 & FZ600 Last edited by flybigjet; 01-10-2024 at 02:17 PM.. |
5
01-10-2024, 01:46 PM | #50 | |
Rep 6,313
Drives: 2018 340i M Sport
Garage List 2018 BMW 340i M Sport [8.58]
2020 BMW M340i xDrive [9.00] 2018 BMW 340i M Sport [7.38] 2006 BMW 330i Sport [5.83] 2004 BMW 330i ZHP [7.13] 2000 BMW 328i [6.17] |
My primary reason for keeping my belt on is I do not want to go flying around if the plane hits unexpected turbulence.
www.bmwcca.org member #388003 - Use me as a referral & you could win a one day ///M Driving School!! ___________________________________________ Last edited by tturedraider; 01-10-2024 at 02:08 PM.. |
01-10-2024, 01:50 PM | #51 | |
Rep 688
tturedraider5087.00 |
01-10-2024, 02:01 PM | #52 |
Rep 6,313
I used not to think much about it when I’d fly, but as I’ve gotten older I’ve become a more nervous flyer. Particularly on takeoff and a little bit on landing. On takeoff I hold on to the armrests very tightly. Because, of course, if anything happens that will save me. I don’t worry too much about falling out of the sky from 30,000 feet, but I’m more aware these days that if something goes wrong on takeoff (particularly with the engines) there’s almost no time to fix it. I guess this incident should actually ease my mind a little regarding the ability to recover from something during takeoff. It’s pretty amazing what these airframes can handle. I’m thinking of the Hawaii Airlines catastrophic airframe failure many years ago and the time a cargo door failed on a 747 and tore out a huge section of the forward cabin and both of those planes landed safely.
www.bmwcca.org member #388003 - Use me as a referral & you could win a one day ///M Driving School!! ___________________________________________ Last edited by tturedraider; 01-10-2024 at 02:07 PM.. |
Joralemon st.772.00 |
01-10-2024, 02:04 PM | #53 |
6869
Rep 1,615
EXCELLENT plan.
01-10-2024, 02:07 PM | #54 | |
Rep 688
Oh yea, I torture myself with these disaster videos. That Aloha airlines is one hell of a mayday! The only 747s that come to mind are flight 800 and of course the Pan Am bombing, but neither of those landed... |
01-10-2024, 02:18 PM | #55 | |
Rep 6,313
www.bmwcca.org member #388003 - Use me as a referral & you could win a one day ///M Driving School!! ___________________________________________ |
Joralemon st.772.00 vreihen1615467.50 |
01-10-2024, 02:24 PM | #56 | |
6869
Rep 1,615
I've been terrified in the jet..... but that was simply because my New Hire First Officer was having a bad day (and the solution there is to take over and then send them off for additional training before letting them near the jet again). The military? A little bit of a different animal-- but that usually involved people who didn't much like me trying to either blow me out of the sky or shoot a bunch of holes in my jet. The other difference is that in the airlines, whenever you have an emergency the FAA/FAR's direct that you MUST "land at the nearest suitable airport in point of time". In the military, maybe not so much. I'm NOT going to land where the Bad Guys are if there's any possibility of another solution (besides, my jet had four engines-- losing one usually just meant that it was a Tuesday). R.
01-10-2024, 02:34 PM | #57 |
Rep 3,040
LOL fuck i'm a soft bastard.
I do a LOT of long haul flying, proper long haul .... and I always have my belt on. Often loose but there in just we hit a pocket and she drops it saves whacking the ceiling. One of the great pieces of artistry is securing a toddler with a seatbelt after 8 hours of screaming and finally fallen asleep across the pacific. Last edited by Alfisti; 01-10-2024 at 02:54 PM.. |
01-10-2024, 02:51 PM | #58 |
Rep 688
01-10-2024, 03:00 PM | #59 |
6869
Rep 1,615
Here's another one for you. Aloha 243 in the late '80's.
Unbelievably enough, despite many injuries there was only one fatality. The flight attendant who was in the aisle got sucked out of the jet. Bad juju. R.
01-10-2024, 03:03 PM | #60 |
Rep 688
Yup, we mentioned this one... Oddly enough — the day that the door got torn out of the Alaskan flight — I was on a flight from Hawaii! Coincidence?
01-10-2024, 04:42 PM | #61 |
Rep 3,019
Drives: A Family Sedan
Fixed
01-10-2024, 06:14 PM | #62 | |
Moderator
29655
Rep 13,138
01-10-2024, 08:07 PM | #63 | |
Rep 5,384
vreihen1615467.50 |
01-11-2024, 01:07 PM | #64 | |
Moderator
29655
Rep 13,138
CNN - Jan 11, 2024 https://edition.cnn.com/business/boe...max/index.html "In the aftermath of last week’s Alaska Airlines in-flight emergency, some aviation experts are questioning the structural design of the section of the Boeing 737 Max 9 that blew off the plane."FAA opens investigation into Boeing quality control after Alaska Airlines incident" CNN - Jan 11, 2024 https://edition.cnn.com/2024/01/11/b...ent/index.html
vreihen1615467.50 |
01-11-2024, 04:15 PM | #65 | |
Rep 6,313
01-11-2024, 05:36 PM | #66 | |
6869
Rep 1,615
Pretty sure I just highlighted the important part of that message from Boeing's point of view. R.
